Results 1 to 25 of 52
Thread: Are You Having RIIIE Post Issues? (Possible Reason Inside)
Threaded View
    Oct 2009
    Louisville, KY
    Second EDIT: We may have found the issue. It seems to be an incompatibility with certain Intel chips. My batch is 3911A, Brettjv's batch is 3912B, and we've found a member on the Asus forum who's having this same issue with no other batch than 3911A!
    So do I RMA the processor?
    EDIT: I've linked Asus Tech Support to this thread to show that this is not just my issue. It's happening to others as well. Hopefully they can use the information contained within to fix it!
    With my 920 I was having an issue where after restarting the board for any reason, it would no longer boot. Using the RC Poster, the board would hang on "CPU Initial" every time. The only way to get it to boot was to turn off the board, turn off the PSU, wait a second for the board to power down, then turn the PSU and board back on.
    Incidentally, the "CPU Initial" hang also occurs when there is no processor installed at all. I know it's not my 920 as it works flawlessly in my Gigabyte board.
    I received my RMA board from Asus and it has this issue as well.
    I just wanted to see if anyone over here had this issue as well. Brettjv over at OCN had it and I wanted to see if it was common. His issues can be seen in this thread.
    Note: I've tried BIOSes 0402, 0602, 0704, different memory, different video cards... everything. It's the board.
    i7 920 / X58A-OC / Dominator GT 2000 7-8-7 / 5870 Lightning
