Results 1 to 25 of 214
Thread: KILL your i7 980X AT ONCE (and RMA it)...
Threaded View
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    Lightbulb KILL your i7 980X AT ONCE (and RMA it)...
    Well yes - you read it well!......
    An EASY way to KILL your i7 980X cpu is VERY SIMPLE... and
    IF your cpu sucks under LN2 or so, an EASY way to kill it is the following:
    Power up you mobo (it doesn't matter what mobo you have)
    Go into cpu features
    Disable Hyper Threading.
    Select 2 Cores for slow die
    OR
    Select 1 Core for FAST die
    Save and exit and.........you're ready - No overclock no nothing -
    Here's my story:
    I had a decent i7 980 Cpu, benching Vantage ~5900MHz
    I putted on the GIGABYTE UD7 mobo
    I was playing OK UNTIL I tested the Super-Pi 1M
    Disable HT
    Test 1M
    Disable 4 cores and I left only the 2 of them
    Playing 1M OK
    Playing and fooling around with 2 cores for a couple of sessions
    OK
    ENABLE ALL cores and HT
    NO Windows at 5800MHz which was EASY before
    NO Windows at 5600MHz
    NO Windows at 5400MHz
    NO Windows at 4000MHz
    Booted into Windows with full cores and HT at DEFAULTS = NO GO
    I said f(l)uck!...The cpu degraded THAT FAST....
    NO
    Another Cpu on EVGA
    Decent one too
    Playing, testing it and fooling around with full cores and HT and LN2 = OK
    Next day I had no LN2 to play with so I did some testing on air with DEFAULT EVERYTHING
    Testing Super-Pi with 2 cores = OK
    I then go into bios and pick ONLY ONE CPU Core with No HT.
    Save and exit.
    Boots and freezes
    Pressing Reset
    NO BOOT
    CPU = DEAD!....
    I then call to a friend of mine who is on air and he doesn't Overclock at all.
    I go to him
    Get into bios and disable HT and pick one core
    Did you do it?
    Yes?
    OK - Now save and exit -
    OK
    George it doesn't booting!....
    I go - clear c-mos and retry.
    George no go, what happened? you killed my cpu?
    Am I at your home? How could I kill your cpu?.....
    SHI(f)t!!!
    So if Intel hasn't predicted such behaviours, RMA THE BIATCHES guys.....
    DEFAULT with ONE core enable and no HT = DEAD.....
    RMA - Period
    I suggest to the motherboard manufactures to leave into their bioses ONLY the option of the Hyper Threading and REMOVE the option form the core's selectance with a bios update.
    INTEL PWA FOR EVER
    Dr. Who my arss...
