Results 1 to 14 of 14
Thread: EK Waterblock shorts out GTX480
    Aug 2008
    Exclamation EK Waterblock shorts out GTX480
    http://www.ekwaterblocks.com/index.p...t01returnid=17
    Dear valued customer,
    Some users reported problems when booting GPU.
    We on the other hand experienced no problems during tests, therefore we could not predict that kind of problem during designing the blocks.
    However we have made a simple yet effective solution.
    Anyone experiencing same problem, please contact our support and we will send you PVC washer for metal reinforcer.
    Another solution is also, that you simply remove metal reinforcer (which is not mandatory for installation, only optional).
    Thank you for understanding.
    Good to see EK noticed this early and have already worked a fix.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    x2 Samsung 850Evo 500GB
    x 1 500 Samsung 860Evo NVME
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Full Cover GPU blocks
    360 x1, 280 x1, 240 x1, 120 x1 Radiators
    Feb 2008
    Quote Originally Posted by StAndrew View Post
    Given I've seen something similar happen to my 5970, due to air cooling though (the Accelero Xtreme 5970 - it eats one DVI port) this repsonse seems a little weak; If you short something, you likely damage it. Simply getting a new washing hardly seems a good fix, if the card is fried.
    Hpoefully though, no damage was caused...
    Mar 2005
    Slovenia - EU
    All Resellers and distributors have those washers now awailable.
    And these blocks 470 and 480 blocks are shipped from EK with GPU reinforcer washer since April 27th.
    If you don't get it with the delivery, just do not use GPU reinforcer metal plate or ask for the washer at seller or EK support.
    Quote Originally Posted by creidiki
    EKs are like waterblock pr0n
    I am Xtreme
    Feb 2007
    Quote Originally Posted by RampantAndroid View Post
    The moment you take off the stock heatsink you assume the risk. EK is not responsible. That is just how this market works.
    "Thing is, I no longer consider you a member but, rather a parasite...one that should be expunged."
    Dec 2006
    Not responsible for card damage, but irresponsible as a block manufacturer.
    By the way, I have 2 of the EK-FC480 blocks and the TIM pads included in the "old" kit are not thick enough for proper contact on the mosfets. Hence the 1.5mm pads included now in the "new" kits. I have used EK blocks on every card since the 8800 (9800GX2, GTX280, GTX295) and this is out of chartacter for EK...
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    Quote Originally Posted by Lancelot View Post
    Actually, it's not. If you carefully search the LC section, you'll find a long history of EK's follies and foibles.
    Circles SucQ!
    Dec 2006
    You will also find a long history on every other manufacturer. For the most part, I have been pleased by the products I have purchased from EK. The quality and performance is usually very good, but shorting out GPU's is not cool...hopefully this PVC washer will fix the problem.
    Xtreme Guru
    Dec 2009
    Latvia, Riga
    And those unwilling to risk can buy card with some fullcover preinstalled. (It would make harder to sell card in future upgrade cycle without air cooler though)
    Xtreme Cruncher
    May 2008
    /home/pwolfe
    I'm confused, does this mean that I should remove my 470s and take that reinforcer off now? Or is something else going on here.
    Xtreme Mentor dengyong's Avatar
    Nov 2006
    A great place again
    Quote Originally Posted by pwolfe View Post
    Did you install it with insulating washers ?
    Mar 2005
    Slovenia - EU
    No need to be.
    We have also tested with reinforcer and had no problems.
    Some are experiencing unstable system and problems with booting.
    If they removed the reinforcer or using washer card worked perfectly.
    Meaning the card did not damage the card.
    Oct 2007
    London, UK
    I also was in the first batch, so didn't recieve the reinforcer washer and thicker thermal pad. Asked for them and said was sent after my block, but never got them. It's working fine however with out the washer and a fat dallop of IC7 in place of the thick thermal pad.
    Quote Originally Posted by creidiki View Post
    We are a band of fearless modern-day alchemists who, for fun, run solutions through sophisticated, if overpriced, separator setups, and then complain when we succeed in separating said solution.
    I am Xtreme
    Feb 2007
    Sounds like Eddy is doing right by hit customers.
    Dec 2006
    Malaysia
    hmmm eddy i had the first batch gtx480 nickel backplate
    thats shorting out my gc.
    and the screws were wrong for the side which i saw was corrected on the website manual
    i was given m3x4
    website online manual corrected to m3x6
    prob is the backplate shorting..
    its touching those transistors thingy where the sponge thing was
