*** please mod at your own risk ***
watercooled + mods should reach 950/1900/2500
good luck!!
good luck!!
2500mem @ stock cooler
2500mem+875core is the result of the hard vcore mod
You posted a vcore mod and your showing a memory inrease? What did you do for the mem mod? Most cards can do 875 sotck vcore afik.
1st post updated
@GFDuke.. 2500mem^ was a result of vcore mod
@everyone.. if you do not understand/do not like my mods please dont attempt.. rather try this instead:
http://www.xtremesystems.org/forums/...&postcount=205
as for rest of the mods ill let other modders chime in
benchzowner gtx480 thread: http://www.xtremesystems.org/forums/...d.php?t=251935
hey man big thanks from everybody in the o/c community...it takes a real man to make there mods public.
i'm so glad you did not have a little pip squeak team mate or w/e telling you not to go public with your mods.
you always helpout on mods and i am greatfull
i understand and will try the mods but am playing with my 470 today.
_________________
Thx for the work done here NapalmV5, as I've sayd it's GREATLY appreciated, you're THE MAN !
Best regards
p€p|n0r@ng
thanks guys! youre welcome!
i need better cooling than stock cooling to push over 1000 core
note: those of you on watercooling use 1000-1500uf 16v caps and youll see/get/sustain nice fps increase![]()
are those melted power connector pin through-holes on the pictured card from soldering or heat?
All along the watchtower the watchmen watch the eternal return.
thanks for mods!!
just think about two of these in SLI watercooled at 950/2500 stable.. holy moly.. THAT is performance.
updated to include 10ohm/10kohm resistance @ vcore/vmem
and +/- cap indication
gpuz 0.4.3
http://www.techpowerup.com/downloads...-Z_v0.4.3.htmlAdded OCP adjustment for CHL8266 (GTX 480). Use it via command line parameter /chl8266ocp without parameter to query, with numeric value seperated by space to set. This is a permanent change that will not be reverted by powering down the system.
•Added fix for ADT7473 coldbug (GTX 480) via commandline parameter /fixcoldbug
what about that line?.. does it work?
Nope, Cold Slow remains unchanged.
It's not related to the ADT7473 temp sensor.
Coding 24/7... Limited forums/PMs time.
-Justice isn't blind, Justice is ashamed.
Many thanks to: Sue Wu, Yiwen Lin, Steven Kuo, Crystal Chen, Vivian Lien, Joe Chan, Sascha Krohn, Joe James, Dan Snyder, Amy Deng, Jack Peterson, Hank Peng, Mafalda Cogliani, Olivia Lee, Marta Piccoli, Mike Clements, Alex Ruedinger, Oliver Baltuch, Korinna Dieck, Steffen Eisentein, Francois Piednoel, Tanja Markovic, Cyril Pelupessy (R.I.P.), Juan J. Guerrero
What is it related to?
I haven't figured it out yet, it might be the second temperature sensor ( "on-die" ).
It may be not.
FWIW somebody with some knowledge on programming can write an app to give us control of the Vgpu, OCP, OVP, OTP and possibly eliminate the cold bug ( I'm 1000000% sure it can be eliminated with a BIOS ) with a few lines of code ( wish my coding skills were up to the task, but I only remember how to write "Hello world" in C nowadays)
nbitor 5.6 supports gtx480
if you have the card try it?
download 5.5 then pay author to get 5.6
www.mvktech.net
It's definitely not there
Unless Mavke finds out what causes the cold slow, you won't find a "tick" option in NiBiToR.
900/1800/2200 @ stock cooler
another 480 responding better to vcore + cap mods
single channel ram ^ dual channel ram later on
