Results 1 to 25 of 954
Thread: AMD "Thuban" Core (Phenom II X6) XS Overclocking Charts
Threaded View
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    Hello-
    It is my intention to start an overclocking chart for the new AMD Thuban core CPUs for members of XS.
    Please read this information carefully before submitting your entry!
    If you want on the chart, please post the following information here and then PM me the post number.
    Here is an example. Please copy and paste this form, as my program needs it formatted in such a way to import your data. ALSO, please specify when posting if you are updating a previous entry (and specify which one) or adding a new one. It is conceivable that people may have more than one of these, so I don't want to assume your intentions.
    • CPU Model: AMD Phenom II X6 1090T BE
    • CPU Stepping: CCBBE CB 1011BPMW
    • CPU Frequency: 4000 MHz
    • CPU vCore: 1.475V
    • CPU Multiplier: 14x
    • CPU Turbo: Disabled
    • CPU NB Speed: 2200 MHz
    • HT Ref Speed: 200 MHz
    • RAM Speed: DDR3-1333
    • RAM Timings: 7-7-7-24-2T
    • RAM Configuration: 4 GB (2 x 2 GB)
    • RAM vDIMM: 1.65V
    • Motherboard: ASUS M4A79T Deluxe
    • Chipset/Socket: AM3, 790FX + SB750
    • Cooling: Air (Freezer 7 Pro)
    • Temps: 40C Idle / 65C Load
    • Operating System: Windows 7
    • 32/64-Bit: 64
    • Stable/Suicide/Untested: Untested
    Stable = Tested stable for 8+ hours as defined below.
    Untested = Has not crashed or shown signs of instability but no formal testing has been done. May or may not be fully stable.
    Unstable = Has shown signs of instability. It has BSOD'd, crashed, restarted, mis-calculated results, errored during WCG, is acting funny, etc.
    Stable, for the purposes of this chart, is defined as a minimum of 8 hours of OCCT, Intel Burn Test, LinX, y-cruncher in stress test mode*, or Prime95. Prime set to blend or OCCT set to medium data set are currently the preference since it tests both the cores and memory systems simultaneously. You must have a screen shot of this in order to be added to the chart as stable as of May 1, 2010.
    * Launch the program, press 2, enter, 0, enter, x GB (x being nearly how much RAM your system has free according to task manager), and press enter. The program will periodically indicate how much time has been consumed for the testing.
    Load voltage is best reported as your actual voltage, not your VID (what is set in BIOS) if available. Many motherboards droop or overvolt versus the specified VID when under a load, and that can be a significant change. A multimeter is best, but integrated sensors are better than nothing. Report just your highest vCore be it under load, BIOS, or idle instead of your average.
    Temperatures are best reported as your CPU temperature instead of core temp. Core temps aren't reading properly with these new chips yet. Programs don't seem calibrated for their values quite yet and will report temps -10 to -20C versus actual core temp.
    The quick version for what to expect (stable) from an average Thuban CPU:
    On Air: 3900-4100 MHz is typical. 4000 MHz even is very common.
    On Water: 4000-4250 MHz is typical. 4100 is probably reasonable, but ymmv.
    Cold (SS Phase, Chilled, etc): 4300-4500 MHz. We don't have a lot of samples of CPUs having been stress tested under cold, so this is as much guess as observation.
    The charts, sorted by CPU frequency first, then vCore, then NB frequency. After that they're sorted by Poster and finally post number.
    Thanks to the new forum software upgrade, full-sized images are no longer possible within the thread itself. Grumble. Click on "View Full-Sized" above any image you want to see.
    View Full-Sized
    View Full-Sized
    View Full-Sized
    View Full-Sized
    View Full-Sized
    Need help locating your "stepping"?
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
