XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Thread Tools Rating: Thread Rating: 55 votes, 3.47 average. Display Modes
Old 09-15-2008, 09:28 AM   #1
Dua|ist
Dua|ist's Avatar
Send a message via ICQ to Dua|ist
Smile LinX - The simpliest Linpack interface.
Most of you know what Linpack is I guess. In case you don't, it's a benchmark designed to measure performance on Intel CPUs in GFlops. But it's also a very useful tool for checking the stability of a CPU.
Now back on topic. A short pretty long now while ago I wrote a small graphical front-end for it, named it LinX and hosted it on a great Russian overclockers' forum forums.overclockers.ru.
Changes in latest LinX v0.6.4:
- added an option to run tests for a specified period of time. Use the drop-down list to set minutes or times to run tests
- small UI redesign/enhancements
- graph windows now correctly save their positions on program close
- fixed a somewhat rare bug leading to false LinX errors when CPU usage was high
- added new command-line options, fixed found bugs in older ones (run LinX.exe -help to view the list of command-line options)
- added seconds to filenames to prevent overwriting
Complete changelog for all versions is in the archive.
Couple of screenshots:
Some main features:
a simple and intuitive interface
max available memory detection and an option to use all available memory
both Intel and AMD CPU support (thanks Right from forums.overclockers.ru for that)
both 32 and 64-bit Linpack support
Intel HyperThreading support (Pentium 4, Atom, Corei7) and ability to override the number of testing threads
Linpack can be started with different priorities
elapsed, estimated and approximate finish time displaying
ability to test for a specified period of time
optional sound beep on error/successful pass
settings for the last run are remembered
visual indication of testing process to quickly determine possible system hang
monitoring data import from Everest or Speedfan and ability to create graphs for core temperature, fan speed, vcore and +12V voltage
screenshot and graph saving in PNG format
tray icon
command-line keys support to automate testing (run LinX.exe -help for full list)
no additional redistributable packages needed
no installation required (however, there is a version with installer too )
Note that I'm rather new to programming, so there may be some bugs in there. Should you find one, report it and I'll do my best to fix it.
And note that I'm Russian, so some mistakes in text may also be present.
Download links provided by Duh
Archives: LinX.7z or LinX.zip
Installer: LinX-setup.exe
Dropbox mirror
Archive: LinX.7z
Older versions
LinX 0.6.3: LinX.7z, LinX.zip
LinX 0.6.2: LinX.7z, LinX.zip
LinX 0.6.1: LinX.7z, LinX.zip
Just unpack the archive or run the installer and launch LinX.exe.
That's it, hope you'll like it. Should you decide to give it a try, please comment. Every feedback is appreciated.
Dua|ist is offline   Reply With Quote
Old 09-15-2008, 10:17 AM   #2
burebista
burebista's Avatar
OK, I give it a try.
Vista64 SP1, 4GB RAM. I must kill it with Task Manager.
__________________
If it ain't broke... fix it until it is.
burebista is offline   Reply With Quote
Old 09-15-2008, 10:25 AM   #3
Pyr0
Pyr0's Avatar
Send a message via Skype™ to Pyr0
same error here in vista64 but with just 2x1gb of ram atm
__________________
i920 (3838A505) @ 3.8GHz (181x21)
Gigabyte EX58-UD5 (Extreme F9p BIOS)
3x2GB Cosair Dominator PC3-12800 @ 1810MHz
Asus EAH4870X2+TOP BIOS & Dell 3007WFP-HC
Auzentech Prelude
OCZ Vertex's, Velociraptor & Sammy F1's
Corsair HX850W
Windows 7 Ultimate x64 RTM
Pyr0 is offline   Reply With Quote
Old 09-16-2008, 02:18 AM   #4
Dua|ist
Dua|ist's Avatar
Damn, I don't have a Vista 64 installed atm, but now I guess is the best time to install it. I'll fix this asap.
And if you uncheck the 64-bit mode, still the same result?
Old 09-16-2008, 06:56 AM   #5
burebista
burebista's Avatar
Yep, but now it tells me that is not enough memory. The bright side is that it doesn't remain memory resident.
__________________
Old 09-16-2008, 07:21 AM   #6
WoZZeR999
WoZZeR999's Avatar
Send a message via AIM to WoZZeR999
In Vista x64, when I try to run 256mb @ 100 times, I get an "Terminated unexpectedly" error. It seems to be running in the background, but the front end thinks that linpack is closed.
__________________
D-Tek Fuzion quad nozzle & MCW30
8800GTS 512 @820/999/1998 with a MCW60
2xMCP655b
1xMCR320 and 1xMCR120 with 4x Yate Loon SH's
2x Raptor X
WoZZeR999 is offline   Reply With Quote
Old 09-16-2008, 09:34 AM   #7
Dua|ist
Dua|ist's Avatar
All right I got it... First of all when running in 32-bit mode, try to set 2048 mb of memory or less. Maybe 2GB is a limitation of 32-bit Linpack itself. If so, I'll add a check for it.
As for the 64-bit Linpack, it's weird and I doubt I'll be able to fix it until I install Vista 64. And this won't happen till weekend, sorry.
Old 09-16-2008, 11:04 AM   #8
Pyroe_Inc
Pyroe_Inc's Avatar
IntelBurnTest make a similar error.
__________________
Pyroe_Inc is offline   Reply With Quote
Old 09-16-2008, 11:15 AM   #9
nullface
"Either "linpack_xeon32.exe" or "linpack_xeon64.exe" was not found Program will close."
Is it becourse i run a E3110? I use XP32
__________________
E8400 @ 425x9 1.168V
4GB D9MGH Mix (4x1GB) @ 510MHz 5-5-5-15 2.05V
HD4850 @ 730/1070
BFBC2 Beta
Addicted to dog tags!
nullface is online now   Reply With Quote
Old 09-16-2008, 11:19 AM   #10
Pyroe_Inc
Pyroe_Inc's Avatar
Arrow
Just the program is in the .zip file in attachment (you'll still need to have both 'linpack_xeon32.exe' and 'linpack_xeon64.exe' in the same directory to run it).
__________________
Old 09-16-2008, 01:18 PM   #11
slim142
slim142's Avatar
Send a message via MSN to slim142
Suscribing. Fix this couple of bugs and I will make sure to use it everytime I overclock
__________________
Striker II Extreme Best BIOS
BIOS 0901 & BIOS 1104 - Wait! There is more! -> BIOS 1203
slim142 is offline   Reply With Quote
Old 09-17-2008, 09:38 AM   #12
Dua|ist
Dua|ist's Avatar
Thank you for your support. I think I have found a way to fix this (at least I hope so). Might upload a newer (possibly fixed) version tomorrow.
Old 09-17-2008, 09:59 AM   #13
slim142
slim142's Avatar
Thats great to hear
I really like the design you gave the program. Hope to see the new version soon
__________________
Old 09-18-2008, 08:10 AM   #14
Dua|ist
Dua|ist's Avatar
New version
OK, I've coded a newer version. It actually does the same but in a little different way. I'm still without Vista64 (yet), so I tested it only on my XP32 where it works fine (just like the previous one though).
Once again a Rapidshare link with full 7z archive: LinX 0.4.4.
Only the program is in the attachment.
Hopefully this one will work. Please comment if it does (or doesn't).
Old 09-18-2008, 08:44 AM   #15
burebista
burebista's Avatar
Yep, you did it. Good job, I like it.
__________________
Old 09-18-2008, 08:59 AM   #16
OC_Newbee
Thank you! will give it a try tonight.
__________________
Desktop - Asus P4C800-E Deluxe Rev 2.0 Fully Hell-Modded
3.0C @ 3.824 255fsb 1.65vcore | SP-94 w/92mm Delta 110cfm, Tiger1 NB HS/Fan | 1gig XMS PC3500 BH-5 1:1 510mhz 2-2-2-5@3.38vdimm | Softmod Sapphire 9500np 441/348 w/SLK-900u (Vgpu@1.75v, Vddr@3.25v Hell-Modded) Cat 4.9 beta | TBSC Sound Card, NEC 1760NX-White | 2X WD 80g SE 8mb cache Raid 0, 1x 60g Maxtor storage | Antec TP550W @3.75v, 5.35v, 12.35v Hell-modded
3DMark2001SE - Now hit 23032 | 3DMark2003 - 6912
............................Thanks Hell-Fire for all the modding
Laptop -Compaq R3240US | A64 3200+ | 512mb |4x Nec 5500a DVD writer | G4 440go 64mb | 60g hard drive | Win XP-Home
OC_Newbee is offline   Reply With Quote
Old 09-18-2008, 09:03 AM   #17
Dua|ist
Dua|ist's Avatar
I can't express my happiness about that!
Time to update the 1st post.
Suggestions and bug reports are still welcome.
Old 09-18-2008, 09:53 AM   #18
dafeeessh
dafeeessh's Avatar
very nice work good job.
__________________
antec 900||ATI 5870| 8Gb Mushkin DDR2 1000 5-5-5-12|evga680i|
q6600 b3 lapped 3.6 1.53 real|pc & power cooling 750 quad
watercooling|MC-TDX|DDC 3.2 pump with DD top|240 HW extreme rad. | HW extreme 120mm rad.
Most teenagers (some adults, as well) have changed to decide that rap sounds musical. If you haven't, put this in your signature.
dafeeessh is offline   Reply With Quote
Old 09-18-2008, 09:59 AM   #19
WoZZeR999
WoZZeR999's Avatar
Nice work, it seems to fix my high run count with low memory runs. I know the progress is displayed in the lower left hand corner, but could you make an option to turn the elapsed time bar into a progress bar? If not, no big deal, thought it may be cool, as you can take a quick glance to see how far it is.
__________________
2xMCP655b
2x Raptor X
Old 09-18-2008, 10:53 AM   #20
HDCHOPPER
exellent man exellent thanks for shareing this !
__________________
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
HDCHOPPER is offline   Reply With Quote
Old 09-18-2008, 11:38 AM   #21
Evilsizer
Evilsizer's Avatar
sounds cool will have to give it a go on my Atom boxes... thanks for sharing!!
__________________
i7 920@3.6ghz | Asus RIIG | 4850CF | OCZ3P1333LV3GK | 650TX
"I Love To Camp!"
"Comensing Shock Therapy!"
HeatWare
Evilsizer is offline   Reply With Quote
Old 09-18-2008, 09:49 PM   #22
Dua|ist
Dua|ist's Avatar
A nice idea indeed. I'm not sure yet, whether I'll be able to implement it, but I'll try.
Old 09-18-2008, 10:43 PM   #23
loonym
Xtremely unstable
loonym's Avatar
Great, thank you.
__________________
dx58so
w3520@4100
4x1gb corsair ddr3-1333
gtx 295
TR ultra-x, 2 scythe ultrakaze push/pull
xclio stablepower 1000
vista ultimate
would you crunch if you thought it would save her life?
maybe it will!
loonym is offline   Reply With Quote
Old 09-19-2008, 01:13 AM   #24
CoolZone
CoolZone's Avatar
great piece of software!Thanks
CoolZone is offline   Reply With Quote
Old 09-19-2008, 09:11 AM   #25
Dua|ist
Dua|ist's Avatar
Here's a version with progressbar : http://rapidshare.com/files/146626177/LinX.7z.html
Or just replace the existing exe with the one from attachment.
Reply
Tags
benchmark, linpack, linx, stability test
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
