just FYI, there are already few with new 6cores
SYSTEM BIOS UPGRADE REQUIRED; Certain Intel Processors May Cause Unpredictable System Behavior
NOTICE: The information in this document, including products and software versions, is current as of the Release Date. This document is subject to change without notice.
Release Date: 2010-04-12
Last Updated: 2010-04-12
DESCRIPTION
CAUTION: This system BIOS upgrade is considered a critical fix and is required to correct the issue detailed below. OEM strongly recommends immediate application of required critical fixes. Failure to perform the required action could leave the workstation or desktop in an unstable condition, which could potentially result in system lockups or failures, or data loss.
Intel has provided a microcode update to OEM as a critical software fix. This Intel microcode update addresses an issue that may result in unpredictable system behavior. OEM is making available system BIOS upgrades that integrate the updated Intel microcode to address this issue. While the potential for occurrence of this issue is extremely rare, OEM strongly recommends upgrading the system BIOS to the version listed in the RESOLUTION section (or later). Intel has indicated that the microcode update has no known measurable performance impact and provides a complete and comprehensive resolution to this issue.
This issue was identified in a synthetic test environment during rigorous quality control testing. To date, OEM has not observed this issue in a production environment.
This issue will be documented in an updated version of the Intel Processor Specification Update for all affected processors.
Click here for the Xeon 3600 Intel Processor Specification Update.
Click here for the Xeon 5600 Sequence Intel Processor Specification Update
Click here for the Intel Core i7 Processor Extreme Edition Specification Update.
IMPORTANT : This condition is not specific to OEM Desktops and can affect any desktop or workstation that uses the Intel Core i7-980X Extreme Edition Processor, Intel Xeon Processor 3600 and 5600 sequences.
While the implications of the issue are difficult to quantify, any of the following symptoms can occur:
The system may stop responding to keyboard or mouse input.
A system operating in a Microsoft Windows environment may generate a blue screen.
A system operating in a Linux environment may generate a kernel panic.
SCOPE
This issue may affect any of the following workstations or desktops that may be offered with these Intel processors; the Intel Core i7-980X Extreme Edition Processor, Intel Xeon 3600 and Intel Xeon 5600 Sequences and the BIOS versions listed below.
To prevent the unlikely occurrence of this issue, upgrade the workstation or desktop system BIOS to a version listed for your specific system. System BIOS listed includes the required Intel microcode updates to address this issue. Applying the latest system BIOS ensures that the most current version of Intel microcode is installed in the system.
