Results 1 to 19 of 19
Thread: Best Way To Apply TIM - Shin-Etsu X23 (Solved.)
    Crunching For The Points! NKrader's Avatar
    Dec 2005
    Renton WA, USA
    Title says it all. heard its some tough stuff to install.??
    NK
    Mar 2008
    Minnesota
    I won't tout it as the "best" method but after 100 applications of the stuff the easiest and most effective method I have found is to put the syringe in a cup of warm/hot (from the tap) water for a minute or two and then put a small bead across the die of the CPU (varies depending what CPU exactly)
    I have noticed that this stuff can indicate if your IHS/block have any residue from cleaners though, if the surfaces are clean (ie: alcohol or AS cleaning solution) it will stick pretty well, if they aren't (ie: lighter fluid/just rubbed clean with a towel) it won't stick well at all.
    i5 2500K @ 4.9GHz+ 8GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 6 Asus P8P67 Pro CrossFire 6970's @ 950/1450
    Xeon X5677 @ 4.5Ghz 6GB G-Skill RipJaws DDR3-2000 @1600Mhz CAS 7 Gigabyte EX58-UD5 4870x2
    i7-880 @ 4.2Ghz+ (still playing) 4GB G-Skill RipJaws DDR3-2000 @2300Mhz CAS 9 Asus Maximus III Formula MSI Hawk 5770
    Mar 2007
    The best way I've found to apply is to heat the block and CPU IHS with a hairdryer until they are both nice and toasty.
    If you place a hot drop of TIM onto a cold IHS, the TIM will get cold before you can get the block on, pretty much totally defeating the purpose of warming (other than getting it out of the tube more easily).
    If you preheat the IHS and block though, it keeps the TIM warm as you tighten the block, helping to get a nice thin layer.
    Asus G73- i7-740QM, Mobility 5870, 6Gb DDR3-1333, OCZ Vertex II 90Gb
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    u put some in your mouth.
    chew on it a few times, and then spit it out on the cpu.
    Should get it all nice and soft.. and then clamp on!
    do not take me seriously...
    It normally depends for me on the cpu.
    Q series dual die, i will put 2 pea size dots on approx location of die and then mount block.
    I7, i do a line down the long side in the middle, and 2 dots on each side, and then clamp.
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
    Feb 2010
    Cairo,Egypt
    Quote Originally Posted by NaeKuh View Post
    LOL,can you tell me how does this candy taste?!
    *****:Hi
    Me:Hi,how old are you?
    *****:14,U?
    Me:I am 15,where are you from?
    *****I am from USA,U?
    Me:I am from Egypt
    *****:what?!!!!,you must be joking
    Me:why?
    *****: Don't you ride camels and have no forms of Technology ?
    Me:LOL
    Dec 2005
    Renton WA, USA
    nuh uhh ur a lier..
    thanks
    Xtreme Cruncher
    Aug 2009
    Huntsville, AL
    I dot dot, twist twist, and mount slow and easy. It's awkward trying to get this stuff to go down in a line. I never thought about heating the IHS.
    upgrading...
    Dec 2005
    Renton WA, USA
    Quote Originally Posted by meanmoe View Post
    lol its not that bad.. is almost the same as as5... was easy mount..
    Mar 2008
    Minnesota
    Quote Originally Posted by iandh View Post
    I only do it to get the TIM out of the tube easier and it sticks much better to the IHS by heating the TIM. I just let my CPU's convenient source of heat do the spreading
    I am Addicted!
    Feb 2006
    i place the syringe on the back end of my gpu for a few and warms it up quite quickly. gets plenty warm to stay soft enough to mount heatsink. but thr dryer idea sounds good as well
    Dec 2005
    Renton WA, USA
    i just set it on the back of my reciver while I was cleaning old tim off then it was perfect.. just did the pea method im like 10c cooler now across the board..
    Mar 2008
    Minnesota
    Quote Originally Posted by NKrader View Post
    Nice! I have basically every popular (and some unpopular) TIMs and the best performance I get is consistently Shin Etsu X23. I know some reviews show others topping it, but I have been unable to reproduce anything that beats my beloved X23.
    Luckily we did a "group buy" on another forum and paid only $1.25 per tube or so
    Dec 2005
    Renton WA, USA
    yea i woulda got indigo but im too poor at the moment.. paid like 4$
    Mar 2007
    Quote Originally Posted by tool_462 View Post
    I know what you're saying... just some of these TIM's are so thick that even after a couple weeks of heat and mounting pressure I've popped the block just to see a pitiful partial spread with thick layer of TIM still sitting there.
    It almost seems like the particle structure in some of them will become "locked" if you apply high pressure when cold... kinda like with the cornstarch solution from science class.
    It really depends on what you're using though.
    Dec 2005
    Renton WA, USA
    i dont know how the spread is as i dont like pulling back up and giving it a chance to get air.. but temps are like 10c lower than ciramique
    Mar 2007
    Sweet, well that would be good enough for me...
    Apr 2005
    I had to use that same hair dryer method to apply IC Diamond TIM.
    The first IC7 sample I got never made it out of the tube... I think it was a bad batch
    I have some x23-7783D here as well, and it's a little easier, but I still use that same method.
  18. #18
    Nov 2009
    Nice tip, took me ages to apply my X23.
    And I already cleaned mine with 90% alcohol.
    Using the preheat method should gain better results.
    I wasted so much of the X23 cause it was so hard to apply.
  19. #19
    Dec 2005
    Renton WA, USA
    haha was just sitting here at my desk, was holding this stuff cuz it was just sittin on my desk lol and i put it in my mouth like pencil.. lol thought of this thread almost instantly..
