Results 1 to 20 of 20
Thread: Inside the Hydro Copper EVGA FTW Fermi block
    Aug 2008
    GTX 470
    Load Heatsink: 83c
    Load Waterblock: 38c
    GTX 480
    Load Heatsink: 95c
    Load Waterblock: 49c
    http://www.evga.com/forums/tm.aspx?m=271190
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    x2 Samsung 850Evo 500GB
    x 1 500 Samsung 860Evo NVME
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Full Cover GPU blocks
    360 x1, 280 x1, 240 x1, 120 x1 Radiators
    Sep 2009
    Ontario, Canada
    Pretty shoddy machining, but at least it gets good temps. The heatpipe/VRM cooler is interesting....
    May 2008
    Ashburn, VA
    Looks like Swiftech used the pin-matrix design they used in their XT.
    • Intel Core i7 860 @ 4.2GHz
    • EVGA P55 FTW
    • 4GB G.Skill Ripjaws DDR3-2000
    • BFG GeForce GTX 260
    • Coolermaster Cosmos S
    • Swiftech Apogee XT Block
    • Swiftech MCP655 (D5 Vario)
    • Black Ice GTX 480 w/ (8) Yate Loon High-Speed Fans
    • Swiftech MCRES-Micro Rev2
    Xtreme Mentor
    Aug 2008
    Australia
    Looks a bit dodgey. As long as it works I guess. I wonder what EK can come up with.
    Xtreme n00berclocker
    Mar 2006
    San Jose, CA
    Quote Originally Posted by dM@n View Post
    The delrin cover says Swiftech on it.
    Quote Originally Posted by 3oh6
    damn you guys...am i in a three way and didn't know it again
    Quote Originally Posted by Brian y.
    Im exclusively benching ECS from this point forward
    Mar 2009
    Yep. Similar to the XT.
    BTTB - Gigabyte Z87X-OC - WCed I7 4770k - 2x8gb Ballistix 1600mhz - Zotac GTX 780
    Asus Xonar Pheobus - OS -> Toshiba Q 256gb - Games -> 2x Agility 4 256gb Raid0
    Corsair HX850 - Tecnofront HWD BenchTable - Asus VE278Q 5760x1080
    Serveur - Asus Z77m PRO - 2500K - NH-C12P - 4x4gb G.Skill Ares 1600mhz
    Agility 4 128gb - Corsair CX430M - 1TB Black - 2TB green - 2TB Red
    KatPat - Gigabyte 990FXA-UD3 - FX-8320 - PH-TC14CS - 2x4gb Viper 1600mhz - GTS 450
    Samsung Evo 120gb - Corsair HX750 - Bitfenix Survivor White - Asus VE247H
    Aug 2008
    Nice, didnt catch that. That must have been a killer deal for Gabe. I think Swiftech GPU blocks are the most innovative and its good to see EVGA feels the same way.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Xtreme Mentor
    Oct 2007
    USA
    The XT has MUCH smaller pins. Glad to see pins in this hot GPU, better heat reduction. Channels just don't cut it no more I guess.
    All stock for now, no need for more, but it's gonna be soon methinks.
    Giga Xtreme 58 mobo i7 965 ES D0 step Corsair 1600 6 gig
    SLI GTX470 EVGA
    EK HF nickle blue top CPU block (free from Eddie)
    Koolance 470 waterblocks
    One big loop, two 120x3 rads. Pa 120.3 and XSPC RX 120x3. Swiftech 35x pump with V2 restop. GT AP15 fans.
    Banchetto Tech Station
    120 GB SSD, and a few other drives.
    1000W UltraX3 PSU, 900 watt (1500VA UPS
    23.999" Acer GD235hz and 24" Acer H243H
    Xtreme Mentor
    Aug 2008
    Australia
    Quote Originally Posted by Conumdrum View Post
    I don't want to start a water block argument, but the EK HF tested in Vapour's review performed better than the Swiftech XT. The EK HF has channels, the XT has pins, so that shows channels do still cut it, and in fact outperform pins. Further, the HF, while performing better, also has less flow restriction.
    Xtreme Mentor
    Oct 2007
    USA
    Well, maybe so. I'll say it looks like in the long run for overclocking controlling the VRM temps is what matters. In my case, I'll pretty much sit back and wait till the fall. See whats on the market. Be a good time to make a move before the next crazy Christmas announcements. Til then I'm done.
    SLI GTX470 EVGA
    Oct 2007
    Quote Originally Posted by CryptiK View Post
    I think you are misunderstanding him, there is a HUGE difference between the very small channels on the HF, and the much larger channels found on most full cover vid card blocks, including the EK ones. I don't think he meant to mean that channels were worse period, just the way they are typically used in vid card blocks.
    Xtreme Member JaD's Avatar
    Oct 2002
    I'm disappointed to notice how the heatpipe seems to have no direct flow...
    Anyway it's wrong to say that VRM temps are the only ones that count, this might be partially true for recent ATI cards but Nvidia's designs didn't ever rely much on VRM temps. GPU cooling is fundamental, especially on Fermi chips.
    It surprises me however that most of you failed to notice how Swiftech used this very kind of pin matrix in all of their komodo blocks for a long time.
    Feb 2009
    Quote Originally Posted by JaD View Post
    kool block shtty cooling for other chips. those unisink or w/e its call thingy dont cool as good as it looks either. i think vrm should b lil worry if it gets too hot no.. 280 vrms get hot with swiftechs unisink on them its hottest part on card 60c + . n u get gfx coruption flashes
    dd blocks full cover no lil unisink
    Aug 2008
    I think the heat pipe to the block is enough. While the water doesnt directly cool the VRM's it does cool the heat pipe which is cooling the VRM's. This has been shown to be pretty effective with the old 4870 block and MCW60.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    I am Xtreme
    Jun 2007
    Imperial Palace, UDE of Pitatopia
    It's not a bad design, my only concern would be if the heatpipe had enough capacity for OC'ing.
    Circles SucQ!
    Aug 2008
    Well, how did these work out:
    Anyone know? Maybe Gabe could provide some VRM temps...
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Sep 2008
    Las Vegas
    Hmm... so how will this compare to the DD
    Project HAF 932 Water-Cooled
    __________________
    New OC Validation
    - Q9650 4.0 Ghz For Now -
    - GTZ, Feser 360, D5 Vario, EK Multi-Option -
    - eVGA 750i FTW! -
    - eVGA GTX 480 H20 & GTX 295 -
    - 2x2GB Dominators PC2-8500C5D -
    - WDCaviar Black 640GB AALS x2 (Raid0) -
    - FreeAgent Pro 500GB Ext x2 -
    - Enermax Revolution 85+ 1050w PSU -
    - X-Fi XtremeGamer -
    - CM HAF 932 H20 -
    - Dell U2410 IPS LCD -
    - Logitech G11 & MX-518 /G9 -
    - Sony 24x Optical w/ LightScribe -
    - BOSE Companion 3 -
    - ATH-AD900 Cans & UE Triple.Fi 10 Custom IEM's -
    - Nikon D40 w/18-105mm & 55-200mm VR's -
  18. #18
    Sep 2009
    Home- Minnesota
    DD all Cu, gona cost more, but I'd go for that.
    Donate to XS.org
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." -Ben Franklin
    "Every government degenerates when trusted to the rulers of the people alone. The people themselves, therefore, are its only safe depositories." -Thomas Jefferson
    "He that would make his own liberty secure, must guard even his enemy from oppression; for if he violates this duty, he establishes a precedent that will reach to himself."-Thomas Paine
  19. #19
    Dec 2008
    Ostend - Belgium
    It's nice to see that they use Swiftech blocks for their watercooled models.
    The question is if there's going to be a European model and if it's going to use the same Swiftech blocks?
    Perhaps they did learn from their mistake with the EVGA GTX 285 Hydro Copper.
  20. #20
    Aug 2008
    Quote Originally Posted by the finisher View Post
    If I know swiftech, this is all Cu as well with a nickle or chrome plating.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    Swiftech Apogee XL2
    Swiftech MCP35X x2
