I'm doing a new build from the ground up. I want something that is easy to build for a novice builder (me), that can hold plenty of water cooling stuff, and that has good looks. I've basically gotten it narrowed down to only a few cases. I'm looking for a full tower or cube case.
It doesn't have to be particularly portable, because I don't plan to lug my 30" monitors around but rather leave them set up in one spot. Just bought them, they're on the way here via Con-way Freight, should have them in a week. I'm so excited!! Now to quickly build a system to power them.
Here are my main case options:
Corsair 800D. Least expensive, noob friendly. Limited water cooling room.
http://www.newegg.com/Product/Produc...82E16811139001
http://www.performance-pcs.com/catal...ducts_id=26505
Lian Li PC-343B. Lots of room. Would need to powder coat the interior.
http://www.performance-pcs.com/catal...ducts_id=25186
http://www.performance-pcs.com/catal...ducts_id=21901
http://www.frozencpu.com/products/64...tml?tl=g1c2s35
Murdermod TJ07. Best looking but also most expensive. Quad in the bottom of the tower case is nice.
http://www.murdermod.com/murdermod-t...ermod-tj07.htm
Mountain Mods Extended Ascension. Biggest, room for huge boards. Would go with anodized aluminum and many many fans and radiators. The only currently available option that would fit the EVGA Classified SR-2 motherboard.
http://www.mountainmods.com/computer...o-c-21_96.html
Mick64 Case. Well designed, but no idea about availability or price.
http://www.xtremesystems.org/forums/...d.php?t=217611
There might also be some other case that I've overlooked or that is coming out soon. If so, please post a link to it and tell me the advantages of choosing that case over another one on the list. Thanks for your help in choosing!
