Results 1 to 12 of 12
Thread: fit - Noctua NH-D14
    Oct 2007
    fit - Noctua NH-D14
    hello, Someone knows if the Noctua NH-D14 fits in the bloodrage with the
    Kingston HyperX 3 x 2gb, the ones with the extrange heatsink.
    this one:
    i7 920 C0 @ 4.3 GHz - Foxconn Bloodrage - Noctua NH-D14
    6 GB DDR3-2000 @ 2050 8-9-8-24-1T
    Intel SSD X-25M G2 160 GB - Raid 0 @ 4 Velociraptor's
    PSU ABS Tagan 1300W Modular - Case Thermaltake Tai-Chi
    EVGA GTX480 SC SLI - HT Omega Claro Halo XT - Dell u3011
    Keyboard G19 - Razer DeathAdder - Pad Steel 5L - Sennheiser HD-650
    Jan 2008
    Irving, Texas.
    I wouldn't bet on it. The heat spreaders on those things look /really tall/. Even where spreaders are concerned, they look taller than any set I've seen. There already isn't much in the way of space in the general area underneath the NH-D14. It's just tight
    XClio 1000, Gigabye GA-MA790XT-UD4P
    AMD Phenom II 955BE @3.2 GHz, Noctua NH-D14
    CORSAIR 950TX 950W, 4GB Corsair XMS3 DDR3 1600
    Sapphire 4850x2 CFX
    Win7 Ultimate
    Quote Originally Posted by stangracin3 View Post
    and the more i type the more BS comes out of my keyboard. LOL
    May 2009
    Belgium
    To be 100% sure if it'll fit you only have one option, start measuring!
    Info found here :
    http://www.noctua.at/main.php?show=f...d=34&lng=en#13
    System 1 (mine):
    CPU: i7 920 D0 stable at 4.0 GHz cooled by Scythe Mugen 2000
    GPU: PowerColor HD5850 (950/1250 1.2V)
    Motherboard: Gigabyte GA-EX58-UD5 Memory: 6GB DDR3 GeiL @ 1528 MHz
    System 2 (gf's):
    CPU: i7 920 D0 currently at 4.2 GHz cooled by Noctua NH-D14 (needs more tweaking/testing)
    GPU: Club3D HD5850 (awaiting OC)
    Motherboard: Gigabyte GA-EX58-UD3R Memory: 6GB DDR3 Corsair @ 1600 MHz
    Mar 2007
    Bulgaria/Sandanski
    GA-X58A-UD9
    I7-970
    KHX2000C9D3T1K3 3 x 2GB
    HALE90-1000-M
    Test Bench V1.0
    Oct 2007
    ok, i need to check my mb, and the space there then.
    Thanks for the info and photos.
    Feb 2005
    Ugh... I need more fan headers. I try not to use those 4-pin Molex adapters.
    OP: I think you can remove the heatsinks if you don't mind voiding the warranty.
    PC:
    ATCS 840 (black) -=- M12D
    X58A-UD5 / i7 920 [3.0 Core, 6.6 QPI, 3.6 Uncore] + ICD7 + Noctua NH-U9B
    6GB HyperX DDR3 @ 1800 C8 [150x12] / ATI FireGL V7700 + DELL P2210 + Sceptre 17" extended -=- Intel X25-V + WD Black(s) + BenQ DW1655 + Samsung S243N
    Stereo: ECHO AUDIOFIRE 4 --> [custom Mogami TRS ICCs] --> Samson 201a --> [Mogami] --> JBL L830s
    Mar 2010
    Angeles/ HK/ Shenzen
    ...or you could take out one of the fans or change to a smaller one
    Feb 2005
    Quote Originally Posted by duron View Post
    It would take some ghetto-rigging to use a smaller fan, but I want to know how the D14 performs with just the 140mm fan.
    PC:
    May 2010
    Sydney - Australia
    does anybody know if Noctua NH-D14 would fit in Antec Nine-Hundred case ?
    Oct 2007
    Quote Originally Posted by SolidGoldstein View Post
    I am curious about this too. I wonder if anyone can chime in on how the D14 performs with only a fan sandwiched in the middle.
    Corsair 700D
    Intel i7 920 @ 4.20|Asus P6T6 Revolution|G.Skill 6gb DDR3 1600|Zotac GTX480|Intel x-25-M 80GB x 2 / Raid0
    H2O
    |Perfecting the Obsidian series case. Build log to follow soon...|
    Mar 2010
    Now that some AM3+ mobos are rotated will this still Fit w/o hitting the PSU or RAMS?
    specifically this mobo
    posted By chew*
    Jun 2006
    Quote Originally Posted by Darth_Penguin View Post
    I did not take any temp readings but having the 140MM fan (only) and it makes a really audible turbulent noise!
