Our classical aquabox celebrated its 5th birthday last December and of course it can't compete with todays requirements so it was time for a new version: the aquabox Professional
Currently we are overworking our whole aquabox series to integrate new features and using new materials. The aquabox Professional inherits the flow path where the water is pushed towards the plexiglas cover. The strength of the flow (or visual effect) can be adjusted with two headless screws. The water runs down along the cover so fog or waterdrops have no chance and also air is "filtered" out to avoid any trouble in highflow systems.
A stainless steel cover with the accurately fitting plexiglas and the counter sunk bolts add a fresh new style to the reservoir compared to the old aquabox.
The new variant is made of Delrin in black or white. The white version features four additional holes for 5 mm LEDs to get some nice light effects.
Three G1/4" threads at the back allow different ways of connecting the aquabox to your loop. Two more threads at the top allow to refill the box without lying down the PC to its back. Three sealing screws are already included in the scope of supply.
A real highlight is the patent-protected mounting system with magnets. As an option you can get a stainless steel mount with three magnets. The magnets will be pushed into three small holes at the back of the aquabox. Two additional position gibs allow an easy removal and latching. A guide plate from the mount also helps to get it into its right position. You can see how it works in this YouTube video.
Before you think "WTF?! Magnets in a PC?" you don't have to worry. We already tested these magnets by attaching them directly to a HDD and nothing happened. We also know from a magazines "HDD survival test" with even a stronger magnet that no data was damaged. Anyway, as precaution we would not recommend to use a HDD directly above or below the aquabox Professional.
And if you still don't trust it: you don't have to use the magnetic mounting system at all
The price is not final but we are targeting 40.00 EUR (~46.00 USD w/o German VAT). The magnetic mount will cost 9.90 EUR (~11.00 USD w/o German VAT).
If you have suggestions let us know!
We are planning to start the final production next Monday so the first ones will be ready mid next week. It is very likely that we will do a production video since it looks really impressive when a plane Delrin block transforms into a reservoir in only a few minutes.
And finally - here are the photos
aquabox Professional black
aquabox Professional white with different LEDs
Magnetic mounting system
*** UPDATE ***
Making of video on YouTube in HD.
