The one thread I've seen on the performance of the Swftech "unisinks" for the 58xx series cards was not very impressive. Anybody have any results to share?
__________________
Crunching XS:WCG+GpuGrid
Car Rads
The Hole-Geothermal
Bong! Bong! Bong!
Chill, man, chill
HVC
PlateHX Conversion
OK...
So basically a gutted stock heat sink with the fan removed cools better then a unisink.
Ummm Gabe any comments?
Nadeshiko: i7 990 12GB DDR3 eVGA Classified *In Testing... Jealous?*
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
I hear that if you remove the thermal pads and use AS5 (or some other paste) you can drop the temps dramatically. The Swiftech sync has a much larger surface area than the stock plate so it should cool much better. The short fall has to be the thermal conductivity of the pads used.
Intel 8700k
16GB
Asus z370 Prime
1080 Ti
x2 Samsung 850Evo 500GB
x 1 500 Samsung 860Evo NVME
Swiftech Apogee XL2
Swiftech MCP35X x2
Full Cover GPU blocks
360 x1, 280 x1, 240 x1, 120 x1 Radiators
I actually started that thread that was linked in the first post. I got the unisink and have been totally underwhelmed with the performance. I immediately question the quality of the thermal pads used. Does anyone know of any quality, proven thermal pads that I could try instead? I guess using TIM instead could be possible, but I'm curious if the clearance is tight enough that paste would be viable?
I always use TIM. Using a razor, spread it over your component nice and thin. Tighten the heatsync down and enjoy! TIM always beats pads.
Intel 8700k
16GB
Asus z370 Prime
1080 Ti
Swiftech Apogee XL2
Swiftech MCP35X x2
__________________
Car Rads
The Hole-Geothermal
Bong! Bong! Bong!
Chill, man, chill
HVC
PlateHX Conversion
i suggest stop using as5.......try arctic ceramique...i tried this on contacts and it never killed any of my video cards....
if ou have a dc-dc circuits that aren't efficient you'll have a heat source...using heat sinks on them does increase the surface area for the heat to transfer...but you still need active cooling ie fans.
if you use swiftechs heatsinks they'll do their job...but you'll still need fan/s even gabe had 100C ...using the heatsinks passively...
what shorting are you talking about? if there's a short your gpu is probably dead or just needs a refit..
Sure can:
http://www.xtremesystems.org/forums/...4&postcount=67
This should help.
Intel 8700k
16GB
Asus z370 Prime
1080 Ti
Swiftech Apogee XL2
Swiftech MCP35X x2
Bingo! Thanx!![]()
__________________
Car Rads
The Hole-Geothermal
Bong! Bong! Bong!
Chill, man, chill
HVC
PlateHX Conversion
That's awesome! I'm gonna give that a shot tomorrow and report back my temps! Just to make sure, OCZ Freeze is non-conductive also, correct? I'll buy ceramique if need be, but I want to make sure what I have doesn't work before I go on an adventure to find that tomorrow!
I'm sure you guys mean replacing the pads with tim on the mem and such right, or did they start putting pads on the cores?
I'm looking to stay with air, but I was wondering if I could replace the pads with tim and cool it off a few degrees
555x2 @ 4.2 / h50
Crosshair 3 formula
2x2g ripjaws
5970, hx1000
No pads on core, just memory and mosfets.
Intel 8700k
16GB
Asus z370 Prime
1080 Ti
Swiftech Apogee XL2
Swiftech MCP35X x2
You want non-conductive and non-capacitive. I switched to MX-2 a couple of yrs ago because it fits the bill....plus it's good down to -45F.
Doesn't say if it is non-capacitive:
OCZ Freeze
__________________
Car Rads
The Hole-Geothermal
Bong! Bong! Bong!
Chill, man, chill
HVC
PlateHX Conversion
Ok. I know I can find ceramique at microcenter, so I'll pick some up today and see what happens.
Couldn't find ceramique, but I just grabbed a tube of mx-3 which says nice and big on the packaging that its electrically non-conductive and non-capacative!Results hopefully to come tonite
Sorry about hijacking the thread, but... I was actually considering attempting to use TIM on digital PWMs (both CPU and VTT) of x58 Classified instead of thermal pads to improve thermal performance... Stock heatsink is pretty good, so I think I might be able to lower the temps... Any opinion?
Feel free to reply here or post here.
Thanks.
Edit: not going to bother with TIM I think, thanks to those who replied. The form of both PWM and heatsink seems to be more fit for thermal pads, so going to stick with what's intended.![]()
