Hello all,
I am curious as to the overclockability of the Phenom II X4s, retail samples on air.
What were you able to achieve?
3.4GHz - 3.6GHz
3.6GHz - 3.7GHz
3.7GHz - 3.8GHz
3.8GHz - 3.9GHz
4GHz+
Hello all,
1x965BE C3 ~ 4000mhz 24/7(or prime95 max indoor)
1x965BE C3 ~ 3950mhz 24/7(or prime95 max indoor)
2x955BE C3 ~ 3900mhz 24/7(or prime95 max indoor)
1x955BE C3 ~ 4120mhz 24/7(or prime95 max indoor)(Super pi1m 4400mhz+ indoor temp with air) same week like the another 955BE C3 i did test.
OT:
1x940BE C2 ~ 3700mhz 24/7(or prime95 max indoor)
1x940BE C2 ~ 3800mhz 24/7(or prime95 max indoor)
Outdoors around 4.3 (20c, 33c load hehe)
Indoors with my crap cooler around 3.95
Smile
955c2 was 3.85
965c3 is 4.1
LEO!!!! amd phenom II x6 1100T | gigabyte 990fxa-ud3 . . 2x2gb g.skill 2133c8 | 128gb g.skill falcon ssd sapphire ati 5850 | x-fi xtrememusic. . . samsung f4 2tb | samsung dvdrw . . corsair tx850w | windows 7 64-bit. ddc3.25 xspc restop | ek ltx | mc-tdx | BIP . . lycosa-g9-z2300 | 26" 1920x1200 lcd .
965 c2 4008mhz prime stable on air.
965 c3 4.2 stable on water 4.5 3ghz northbridge on phase 5.18 cpu-z validation
955 c3 4.6 3.3ghznb stable on phase 5.3 cpu-z validation![]()
My pot is bigger than your pot
WHAU!!!!
My 3.8-3.9 vote counts only for a C2!
Strix X470-F, 1.2.0.6b | 5800X3D + Galahad 360, 3xP28 | 4x8GB Flare X 3200C14 @3200C14 1T+GDM | Strix 2070S A8G @1830/1750 | SB Z | SN750 500GB, MX500 1TB, DT01 2TB | O11D XL: 6xNB PL-2 | RM750
965 C3 almost 4.2 with air cooling.. haven't try with sub-zero so far.
3.6~3.7 GHz with my 955 C2
U120EX Air cooling only
My aircooling machines
1x x4 955 C2: 3915MHz (24/7)
1x x4 965 C3: 4030MHz (24/7, but im using most profil 1.35V and 3720MHz)
ROG Power PCs - Intel and AMD
3.8Ghz on air, just under 4Ghz one water
I personally cant get past 4.0ghz im currently 24/7 WCG stable at 3.940 and my max load temperatures are around 45-46Cbut i am 12hours of prime blend stable at 4+ghz... therefore i now use world community grid for all of my stability testing... doesn't make any sense.
[MOB] AM3 Asus M4A79T Deluxe
[GPU] ATI HD 5870 1gb 925 mhz
[RAM] OCZ Reaper 4gb 1600 mhz
[CPU] AMD Phenom II 965 4.0 ghz
"What doesn't kill you, only postpones the inevitable..."
Water Cooled Apevia X-Plorer | Custom Window | Lapped Phenom II 955 | Lapped Phenom 9850
1x 940be @ 3.75ghz
1x 965 be c3 @ 4.125ghz
720 be c2 @ x4 3400 - 24/7
965 be c3 @ 4000 - 24/7
1090T | CH4F | HIS HD5850 | TT EvoBlue 750W | TT Spedo Advance | CM Aquagate Max | Samsung S27A350
Asus Crosshair IV Extreme
AMD FX-8350
AMD ref. HD 6950 2Gb x 2
4x4Gb HyperX T1
Corsair AX1200
3 x Alphacool triple, 2 x Alphacool ATXP 6970/50, EK D5 dual top, EK Supreme HF
