I would like to introduce our newest high performance CPU water block, the Koolance CPU-360. (No doubt, you guessed the model number already...)
The CPU-360 uses an advanced microfin cold plate-- 0.25mm fins, 0.30mm channels-- o-ring sealed impingement plate, and an optimized flow path to yield extremely high performance. This is done with much lower coolant restriction than the previous CPU-350. Here are details I yanked from our website description:
The CPU-360 contains a copper cold plate with brass top. As with all Koolance products, nickel plating is added to improve corrosion resistance. Two universal steel mounting brackets are included for mainstream Intel and AMD processors. The CPU-360 has standard G 1/4 BSP threading.
The below sockets are supported:
- AMD socket AM2, AM2+, AM3
- Intel socket LGA 1156
- Intel socket LGA 1366
- Intel socket LGA 775
We shipped review samples out earlier this week, so we hope to have some head-to-heads very soon. The CPU-360 will become available on Monday, Feb. 8th!
Tim
