Results 1 to 4 of 4
Thread: CM HAF 932/922 questions..
    Mar 2005
    UK
    Question CM HAF 932/922 questions..
    To the owners of a 932/922 i have a question or two..
    What are these cases like for noise, i realise they are not designed for low noise output as such. "Normal" Fan noise(i.e wooshing) in and of it self does not bother me to much what does bother me is resonance/vibrational noise from case and fan interactions. What are the HAFs like in this respect in particular would you say ?
    Also would there be an issue using 2.5in to 3.5in drive adaptors with the tool free hd mounting on these cases (for SSD's)
    Aug 2009
    Norway
    The original fans in this case is VERY silent, i couldnt hear it while i had that case. The screws on theese fans are tightened down pretty well, so in terms of vibration, i suppose i could say no. Not alot of that in this case.
    And to your second question, yes that would be an issue, since those drives rely on the HDD to hit those "screws" on both sides. Aka.. being a 3,5" disc.
    But anyway.. i dont see any problem in mounting it in one of the dvd drive bays? Just screw it into place on the opposite side of those hot swap thingys. Hope you understood what i ment here :P
    My mATX Awesome'ness
    CPU - Intel i7 930 @ 4.3ghz
    MB - EVGA x58 SLI LE
    GPU - 6950
    Ram - 6GB kingston 3000mhz
    HDD - intel 80gb ssd - 2x2TB + 2x1TB WD drives
    PSU - Corsair HX 1000W
    Case - Lian Li A70FB
    Mar 2005
    UK
    Quote Originally Posted by The Viking View Post
    http://www.scan.co.uk/Products/Silve...kes-2-x-25-HDD
    This is what i mean for the HD adaptor, surely i could attach anything required by the tool free mechanism in the HAFs to this as once the 2.5in HD(s) are in this device it looks like it takes the same space/screw points as a normal 3.5in HD ?
    Mar 2005
    UK
    Well what do you know . the egg reviews mention Intel SSDs and the HAF932 working ok in the Silverstone adaptor so hopefully that means im sorted in that respect.
    http://www.newegg.com/Product/Produc...82E16817997007
