Page 1 of 2 12 LastLast
Results 1 to 25 of 44
Thread: >> NEPTUNE V3 << TJ07 "SaNxU" PROJECT
    Aug 2006
    Spain, Barcelona
    NEPTUNE V3 TJ07 "SaNxU" Project
    After my last Project (Neptune V2) I started a new project, some parts are recycled but I think it’s not an update from the V2. So, V3 it’s a NEW project!
    Concept:
    Nowadays most Silverstone TJ07 are Murdermod’s, and so I like to go out from the routine and try an innovative new project. Going with an out reservoir, liquid cooling tubes will be more showy that the sleeved cables, not only a simply front, etc.
    Hardware:
    CPU: Intel Core2Duo e8600
    Motherboard: Asus Striker II Extreme
    RAM: Corsair Dominator DDR3-1600
    MAIN GPU: Zotac Geforce GTX275
    PHYSICS GPU: Asus EN8800GTS 640
    SOUND: X-fi Titanium Fatality (PCI)
    OS HDD: 2x WD raptor 150GB ADFD (Raid 0)
    DATA HDD: Segate 1Tb
    PSU: Silverstone Zeus 850W
    DVD: LG DVD
    Watercooling:
    1rst LOOP:
    CPU block: EK-Supreme LT Plexi-Cooper
    PUMP: Laing DDC + EK TOP (black acetal)
    RAD: Magicool 360 blue UV
    RESERVOIR: XSPC 5 ¼ (bay res)
    TUBE: Feser blue UV (19 out - 12,7 in)mm (3/4 out - ½ in) inches
    FITTINGS: Feser&Phobya Compression Fittings
    2nd LOOP:
    MAIN GPU block: EK-FC275 GTX Plexi-Cooper
    PHYSICS GPU block: EK-FC8800GTS Plexi-Cooper
    HDD block: DangerDen 2x HDD Acetal
    RAD: COOLSTREAM XT 480 (4x120)
    PUMP: Swiftech MCP 655 + EK TOP (black acetal)
    RES: Custom “Ketchak”
    Case and Accesories:
    Case:
    CASE: Silverstone TJ07 Black Window (ATX position)
    Fans:
    1st LOOP RAD: 3x Ac.Ryan 12cm Blue UV
    2nd LOOP RAD: 4x Ac.Ryan 12cm BLUE UV (FRONT) / 2x Scythe ULTRAKAZE 3000rpm
    REAR CASE: 2x Ac.Ryan 9cm Blue UV
    LCD’s / Controllers:
    MAIN LCD: Alphacool 240x128 Blue-Black USB
    Controller: Aquacomputer Aquaero 4.0 white/BLUE with powerbooster
    Sponsored by:
    SaNxU
    Jun 2004
    First shot! Thats gotta be quite nice worklog with TJ07 on 2 loops.
    Extreme ways I know will part the colors of my sea, perfect color me | Arthur's WC Worklog with Lian Li PC-9
    Aug 2006
    Spain, Barcelona
    4x120 Radiator
    4x120 Radiator with support:
    This 4x120 Radiator will be placed at bottom of the Tj07 longitudinally at left. It will have:
    • 4 Ac.Ryan Blue UV fans at the exterior face.
    • 2 Scythe UltraKaze at interior face.
    Interior side will have armaflex to prevent vibrations, and will put armaflex to the custom support too.
    Let’s talk with some pictures:
    Support:
    Radiator:
    Radiator + Support:
    Radiator Scythe fans:
    Fittings:
    Black “normal” fittings:
    Feser vs Phobya Compression fittings:
    Best regards
    Dec 2008
    Somewhere in Norway
    Are the Phobya Compression fittings smaller in diameter than the BP's?? On the widest part of them? And what sizes can you get the Phobya fittings in?
    CPU: Q9650 MOBO: Asus P5E64 WS EVOLUTION PSU: OCZ MOD X STREAM 900W
    GPU: HIS HD 4870x2 Coolance Water cooling RAM: 4x1gb OCZ DDR3 Platinum 1600 7-6-6-20
    CPU COOLER: Swiftech GTZ waterblock HD: WD VelociRaptor 300GB SATA 3,5"
    OPTICAL: Sony NEC Optiarc AD-7203S CASE: Nexus NZXT
    Aug 2006
    Spain, Barcelona
    MAIN GPU: Zotac GTX275 & EK-FC275:
    This Zotac GTX275 will be cooled by EK-FC275 Plexi-Cooper. It already have a black PCB, so I won’t put acrylic cover to this VGA.
    GTX275:
    EK-FC275:
    Size Comparison:
    CPU block:
    Without fittings:
    With fittings:
    Best regards
    Aug 2006
    Spain, Barcelona
    Quote Originally Posted by M40TURBO View Post
    Feser&BP's:
    • Absolut external: 25,8mm
    • Tube exterior: 19mm
    • Tube interior: 14,5mm
    • Absolut internal: 12mm
    Phobya:
    • Tube interior: 14mm
    • Absolut internal: 11mm
    So, You can se that the completly external diameter of bouth are the same, but the completly internal diameter of the feser&BP are 12mm in front of the 11mm of the Phobya. Then, i think that Feser&BP will work a little bit better.
    Jul 2009
    Germany
    Looks Great and the Photos are very nice
    Looking forward to this
    Aug 2006
    Spain, Barcelona
    Quote Originally Posted by scor12 View Post
    Thanks! your pics are a little bit better I think
    I'm looking forward to your worklog too
    Regardss!
    Aug 2006
    Spain, Barcelona
    First of all, I’ve purchased a tripod and changed my camera, let’s see which ones:
    The camera: Canon Powershot S45
    The tripod: Vivitar V-2400
    And now let’s test how the new camera&tripod works with some pics of some new components:
    EK D5-TOP V2:
    Time to show every detail of new V2 version of EK D5-TOP. This one is black acetal, but can be white acetal too.
    As you can see one of the screws that press the thin part to the main part are a little bit different, don’t know why…
    One of the raptors:
    The sleeving:
    The sleeving color that I’ve choose for this project is CARBON BLACK, It’s different from the common black.
    The tube:
    The tube is a Feser Blue UV 12,7/19 mm
    Best regards
    Aug 2009
    Got any updates?
    Aug 2006
    Spain, Barcelona
    I'm waiting for all the fans and mdpc sleeving and others...
    Aug 2006
    Spain, Barcelona
    Hi another time, have been past a lot of time with no updates, so, here is:
    The pics I think that are a little bit better than the old ones, let’s see if all its ok…
    Black Sleeving & Others:
    Well, amazing job of Nils:
    Black&Blue 4x120 Radiator fans:
    The fans are this: Coolermaster SickleFlow 120 2000 RPM Blue LED
    And some real pics:
    With light:
    Without light:
    Now with the radiator: (as you can see the bolts are ugly, I will change it for the shorter black ones purchased at Nils.)
    All fans are fitted to an only one 3-pin, and reporting the RPM only for the first one.
    Black 3x120 Upper Radiator fans:
    This is only a pic that show the fans, in the following updates will see why the SLIM ones, and were will be putted with the 3x120 radiator.
    Tube&Coolant:
    The tube has been shown before, but the coolant will be Feser One Blue.
    Best regards!
    Jan 2009
    United Kindgom
    Hi SaNxU, Nice work you doing here.
    Your photos are not coming out right. i think you need to read this page.
    http://www.diyphotography.net/homest...ighting-needed
    You have to get few white lightings on the thing you taking picture of. Remember dont use the flash from the camera. Always use lightings.
    Jun 2007
    Long Beach, CA
    Looking good there SaNxU I just bought those cooler master blue fans myself they are very nice... I was wondering what RPM did you get on the Sythe fans below in the picture and it says on newegg site they are rated at 46 CFM with 36 dBA seems loud to me. Have you tested them yet how do they sound to you?
    CPU: Intel Core i7-4770K 4.8GHz
    MOBO: GIGABYTE GA-G1.Sniper M5 MATX 1150
    MEMORY: G.SKILL Trident X 8GB 2400MHz 9-11-11-31 1T
    GPU: 2 x eVGA GTX 780 SC
    SOUND KRK Rokit 5 Limited Edition White Studio Monitors
    SSD: 4 x Samsung 128GB Pro's Raid 0
    PSU: SeaSonic Platinum 1000W
    COOLING: 2 x Alphacool NexXxoS UT60 Full Copper 420mm 6 x Swiftech Helix 140mm Fans
    CASE: Lian Li PC-C32B TECH STATION MOD build log coming soon
    MONITOR: ASUS VG278HE Black 27" 149Hz
    O.S: Windows 7 Pro x64
    Aug 2006
    Spain, Barcelona
    Quote Originally Posted by shazbom View Post
    Incredible information, many many thanks. I'll try to improve my photograph skills a little bit, thank you.
    Quote Originally Posted by Lu(ky View Post
    I've bought the 2000Rpm ones, I didn't test it so far, but the noise I think it wont be a problem because the aquaero will make a good job tweaking the fan speed of all the fans of the mod... we'll see...
    Aug 2006
    Spain, Barcelona
    Another update! this time a little bit important than others
    Let's see the beginning of the building:
    4x120 Radiator in the TJ07
    First of all the box that covers the ON/Reset button. As known by the people that have tj07's the reset button is not easily to touch, so I decided to put another Reset button that will be shown in another update
    And the case will use this feet:
    D5 & DDC With Ek tops
    2xUltra kaze 3000rpm With sleeving
    Alphacool Black LCD
    Front Bay CPU-loop Reservoir
    Asus8800gts Physics
    As you can see the PCB is green, so.... NO PROBLEM!
    3x120 CPU-Loop Radiator and grills & fans
    Some misc
    2x150gb Raptors with the DD waterblock
    Waiting for aquaero and other misc from bitspower!
    Best regards
    Aug 2006
    Spain, Barcelona
    Let's see the continuation of the building:
    3x120 rad complete
    Completed the rad, waiting to be mounted at the top of the case.
    It have a inline probe for the aquaero.
    Power supply sleeving
    Only the pic of the 24 and the 8 pin.
    Big resevoir
    Its custom build by Ketchak from spain!
    Aquaero
    Lower part of TJ07
    GPU's
    Best regards!
  18. #18
    Sep 2008
    Belguim
    looking good
    proud to be from Belguim ^^
    Lightpainting and hardware are my life!
  19. #19
    Mar 2009
    Nice work.
  20. #20
    Jul 2009
    Germany
    Nice Job on your Angel Mod
    I like the Mod with the mesh and the rad
  21. #21
    Sep 2008
    Toronto, Ontario
    lookin great so far... will be waiting for updates :P
    i7 920 D0 @ 4.01ghz 1.25v
    Rampage III Extreme
    24gb Corsair Vengeance @ 1600mhz 8-8-8-24-1T
    eVGA GTX 1070 Founders Edition
    Silverstone 1000w
    Corsair 800D
    Liquid Cooled - CPU/MB - EKWB Supreme HF/Full Cover MBWB, Iandh 225 res, D5 w/XTOP rev. 2, Feser x-changer 360, Bitspower fittings
  22. #22
    Aug 2006
    Spain, Barcelona
    Quote Originally Posted by nigelke View Post
    looking good
    Quote Originally Posted by Liderc View Post
    Nice work.
    Quote Originally Posted by eKirts View Post
    Thanks!!!!
    Now a little update with only 2 pics, but bouth I think are imoportant!
    1st: Black Plexy top for the Asus 8800GTS physics to cover the green PCB.
    2nd: Plexy mid plate to cover all the holes that have TJ07's plate. It have a 12cm blue UV plexy mesh and an black aluminium one.
    Better pics of the plexy mid plate in the next update!
    Best regards!
  23. #23
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    Nice update, SaNxU. Good work on your fan cabling.
  24. #24
    Aug 2006
    Spain, Barcelona
    Quote Originally Posted by shazza View Post
    Thanks! All of the fan cabling its due that I wanna control all the fans with the aquaero
    Well some other pics of new black bitspower fittings:
    CPU WATERBLOCK:
    GPU (1) WATERBLOCK:
    RESERVOIR:
    And finaly some mesh misc for the 2x92mm rear fans and for the pci slots:
    Best regards!!
  25. #25
    Nov 2009
    Netherlands
    Great pictures!
    But do you mind telling me why those barbs are mounted on the vga cooler? Are they for draining your loop?
