New EK-Supreme HF (High Flow) CPU Block
After 2 successful years of EK-Supreme CPU water block, EK is almost ready to release its successor.
The EK-Supreme HF (high flow).
Block will be based on same concept as EK-Supreme.
Blocks main improvements are:
-better flow up to 100% higher flow compared or EK-Supreme
-better cooling performance
Enclosed in the box:
-EK-Supreme HF water block
-4 different jet plates + 1 blank
-Universal supported mounting plates:
oIntel: 775, 1366, 1156, xeon
oAMD: AM2, AM2+, AM3, 939, 754, opteron
-Universal CPU retention backplate
-Thermal grease Arctic Cooling MX-2 (2g)
- You may not post replies
- You may not edit your posts
Forum Rules
