Its my first log here is XS so i hope you guys like it.Im located in Singapore btw. (I had made a log previously under the same name here, but i decided to redo it as that was a long while ago. I also retook the pictures as it was pretty badly taken back then.)
Why Name It As Project Supernova?
Theme in mind is Orange/Black and Chrome. Hence the name
System Specifications
Will get new hardware once the case is ready to harbor it. I have this nasty tendency of taking an extremely long time to get my mods done so if i bought the hardware first before starting the mods, they tend to get obsolete before i even get the chance to use them. But for now, these are my current system specs. (pretty old school stuff as compared to the present gen of hardware)
CPU: Q6600 @ 3.8ghz/1.55v (P95 Stable) / 3.2Ghz stock vcore (24/7 Usage)
Mobo: EVGA 680i rev A1
Rams: 8GB OCZ reapers 800mhz CL4
GPU: 8800GTX SLI
Case: Lian Li PCA71b
PSU: Silverstone Zeus 750w
HDD: Seagate 320 GB
OD: Samsung 22x DVD-RW
Cooling Hardware
1st Loop (CPU)
Pump: MCP 655
Rad: Alphacool 360
Fans: Xigmatech x6
Tubing: Primoflex
Coolant: Feser one Red
Block: Dtek Fuzion V1 with Nozzles
Reservoir: Ek Multioption 100
2nd Loop (GPU)
Pump: MCP 655
Rad: Black Ice GT Stealth 240 x2
Fans: NMB minebeas x6
Tubing: Primoflex
Coolant: Feser one Orange
Blocks: *To be confirmed*
Special Thanks to...
VRZoners - From VRzone.com (For their support and ideas)
Bianco and Pissing Intel from VRZ/XS (for the great contacts)
Froze, also from VRZ/XS (For the great MO's)
Navanod from VRZ (For great poison)
And to ALL XS members for some insanely good modding ideas and tips.
And special thanks to Charles_h for kicking off the murderbox revolution.
