Cold Copper ®
"WATER FLOODGATE RESERVOIR"
I present you my new high flow reservoir for be use with my home made *Pump Expansion Chamber (PEC)*. their measures are as follows: 92mm L 100mm H 65mm W. it has two inlets and two outlets for Fittings with ID of 14mm
Hole LED
i give you the link for two videos
with UV light. its final look
http://www.youtube.com/watch?v=dxwjVQZkwCc
Final test performance to 1200 LPH: no BUBBLES. Two inlets of 14mm and two outlets of 14mm.
http://www.youtube.com/watch?v=xInYIrHuY-U
