Results 1 to 19 of 19
Thread: At last... Mobile Athlon II and Turion II
    Jun 2009
    India
    Talking At last... Mobile Athlon II and Turion II
    http://www.newegg.com/Product/Produc...82E16834114717
    http://www.newegg.com/Product/Produc...82E16834157036
    http://www.newegg.com/Product/Produc...82E16834114708
    http://www.newegg.com/Product/Produc...82E16834157039
    http://www.newegg.com/Product/Produc...82E16834114716
    http://www.newegg.com/Product/Produc...82E16834157046
    Knew it was coming... its here at last!
    Now there will be some real competition to Core 2 in mobile arena where 65nm K8 was having hard time keeping up with 45nm power consumption.
    ##wikipedia edit##
    Caspian (45 nm SOI)
    Dual Stars core
    L2 cache: 1 MiB per core, fullspeed (For Turion II and Athlon II), or
    L2 cache: 2 MiB per core, fullspeed (For Turion II Ultra)
    Memory controller: dual channel DDR2-800 MHz
    MMX, Extended 3DNow!, SSE, SSE2, SSE3, AMD64, PowerNow!, NX bit, AMD-V
    Socket S1
    HyperTransport (1600 MHz, 3200 MT/s, 12.8 GB/s CPU-RAM + 14.4 GB/s CPU-I/O transfer rate)
    HyperTransport (1800 MHz, 3600 MT/s on M600 models only)
    Power consumption (TDP): 35 watt max
    Clock rate: 2000, 2100 MHz (M3xx, L2 cache: 1 MiB)
    Clock rate: 2200, 2300 MHz (M5xx, L2 cache: 1 MiB)
    Clock rate: 2400, 2500, 2600 MHz (M6xx, L2 cache: 2 MiB)
    35W TDP:
    M300: 2000 MHz – Athlon II Dual-Core
    M320: 2100 MHz – Athlon II Dual-Core
    M500: 2200 MHz – Turion II Dual-Core
    M520: 2300 MHz – Turion II Dual-Core
    M600: 2400 MHz – Turion II Ultra Dual-Core
    M620: 2500 MHz – Turion II Ultra Dual-Core
    M640: 2600 MHz – Turion II Ultra Dual-Core
    Are there more ways to love than to break a perfectly working computer?
    Don't think so.
    Aug 2009
    The last laptop you linked has the M520 but none were listing the M6xx processors yet. A M640 is what I'd consider getting my father as a replacement for his Pentium M @1.83GHz with DDR2 533. So any official word on whether these are Regor chips with half of the L2 disabled in the lower models?
    Apr 2006
    los angeles
    its good to know that amd will finally be updating their turion line, but at the same time intel is updating their line with mobile i7s
    Seti@Home Optimized Apps
    Heat
    Quote Originally Posted by aNoN_ View Post
    pretty low score, why not higher? kingpin gets 40k in 3dmark05 and 33k in 06 and 32k in vantage performance...
    Xtreme Cruncher
    Jun 2006
    Quote Originally Posted by DedEmbryonicCe1 View Post
    This one is Regor 100%:
    http://products.amd.com/en-us/Notebo...6=&f7=&f8=&f9= (this one is a full fledged Regor,with full L2 and 128b SIMD)
    I suppose that the ones with 1MB of total L2 are Regors too,with half of the L2 disabled.They(M5xx and not M6xx) should also have a support for 64bit SIMD too,and not full 128bit SIMD execution units support like full Regor cores(Phenom I/II and i7/C2 also have 128bit SIMD support,while K8 and Yonah don't).
    Quote Originally Posted by Newblar View Post
    Minority of users actually need Quad Core in their notebook.
    Aug 2009
    http://images.anandtech.com/reviews/.../models-lg.jpg
    The mobile i7's from Intel aren't in any direct competition with the AMD chips mentioned above. The 10W-20W difference in TDP means a lot in a notebook as far as size and weight. I would also be skeptical about how often a 55W laptop part like the 920XM could reach it's turbo boost speeds without having to throttle back down.
    From the AnandTech review:
    The new Clarksfield i7-920XM isn't substantially faster than the old Core 2 QX9300 when it comes to running highly threaded code. The problem is that when running highly threaded code, Clarksfield's Turbo modes aren't able to fully activate. We end up with a Core i7 running at 2.26 GHz compared to a Core 2 running at 2.53 GHz, and overall performance is relatively close.
    I can't find the MSRP for the Turion II Ultra's but considering the top desktop Regor is $76 I don't expect that the binning AMD has done for the mobile market drove the price up to the slowest i7 mobile, the 720QM, at $364.
    Oct 2004
    What I would want is one with 15" screen or smaller with a HD4670/4650.
    Apr 2006
    los angeles
    ive always been keeping arrandale in mind, but those new intel i7 mobiles dont look too good for battery performance
    i would very much like to see high powered ati igp or discreet with the new regor based laptops.. would be a nice upgrade for my dad and his old dothan lappy
    Heat
    Jun 2009
    India
    Quote Originally Posted by SnipingWaste View Post
    You mean this
    -HP Pavilion DV6-2144NR NoteBook AMD Turion II M520(2.3GHz) 15.6" 4GB Memory 320GB HDD 7200rpm DVD Super Multi ATI Mobility Radeon HD 4650-
    Comes on 22/10
    Don't think so.
    May 2004
    Quote Originally Posted by I_no View Post
    You mean this
    Comes on 22/10
    almost 7 LBS
    Desktop:
    Antec 300
    Foxcon A7AD-S 790GX
    8GB Gskill PC-1066@5/5/5/12
    PII X940 BE @3.6GHZ
    Sunbeam Core Contact
    2x 640GB in Raid 0+1
    4870 512MB@800/1000
    Vista Business 64bit W/ SP1
    Jan 2009
    SF
    wow finally, I've been waiting for awhile.
    Oct 2004
    You mean this
    Comes on 22/10
    What I want is a barebone 14" amd notebook with a hd4670/4650 so Im able to work on it when needed with out having to disassemble the whole notebook.
    Xtreme Enthusiast TheBlueChanell's Avatar
    Dec 2006
    This is good stuff. I would like something in the 12/13.1" form factor. Any news on a 45nm Netbook part? Neo's replacement.
    Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
    --- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
    HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
    --- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
    HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
    HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
    Aug 2009
    The single core M1xx model(s) (1 core disabled) still have a TDP of 25W... Maybe there will be something later and it's just not announced yet? That or AMD doesn't want to downclock the good dual-cores enough to reach something suitable for a netbook.
    Jan 2008
    Vancouver,British Columbia, Canada
    I see no AMD Turion II Ultra Dual-Core Mobile Processors (6xx series) CPUs on the newegg.
    http://products.amd.com/en-ca/Notebo...&id=578&id=579
    Is newegg getting a quarterly check from Intel as well?
    World Community Grid's mission is to create the world's largest public computing grid to tackle projects that benefit humanity.
    Our success depends upon individuals collectively contributing their unused computer time to change the world for the better.
    Oct 2005
    Screw Regor I want Turion II on the desktop, any chance of that? Kind of weird to see intel and amd going in different directions with their cache setups.
    Aug 2009
    It's a different socket so no. The difference between a 240E and a M640 is minimal. Maybe the mobile version is binned slightly better but since we don't get exact TDP ratings anymore, just the ballpark <=35W or <=45W they could be closer than you think.
    Dec 2008
    Sweden, Linköping
    Quote Originally Posted by SocketMan View Post
    Have patience, soon more OEMs will release their mobile lines with AMD CPUs
    SweClockers.com
    CPU: Phenom II X4 955BE
    Clock: 4200MHz 1.4375v
    Memory: Dominator GT 2x2GB 1600MHz 6-6-6-20 1.65v
    Motherboard: ASUS Crosshair IV Formula
    GPU: HD 5770
  18. #18
    Sep 2005
    Blackhole
    Thought you might be interested in my Tigris Laptop review
    http://tipidpc.com/viewtopic.php?tid=210319&page=1
  19. #19
    Banned
    Jan 2003
    EU
    What i would really like is a netbook with a ultra low voltage turion II/athlon II and ati igp.Because for now only choice seems to be crappy atom with even crappier igp or decent celerons with crappy however igps from intel.AMD could REALLY stir this segment.I cant comprehend why arent they doing this, this segment seems to be growing at a rapid pace.
