Hi all!
I am not memory addict, but i decided to do this type of memory testing thread as well
I got this kit from G.Skill few months a go and I have used it in all my pretesting phases and in more serious test. Kit is still in very good shape and no issues so far.
First some pics of memory sticks. I like them a lot.
I have to admit, that I have had some issues with this particular kit. I first tested :7-8-7 / 8-8-8 / 8-9-8 / 9-9-9 etc.. I was wondering that what is going on, cause this memory just does not like to overclock. I then decided to try different combinations and realized that I have to use tRCD - Row Address to Column Address Delay one step higher than in my other kits and then everything is going perfectly fine.
Test setup:
Single stage cooled @ -42C° (Designed for VGA's, not for this use)
Intel Core i7 950
EVGA Classified 760
Thermaltake TP 1200W x 2
4x ATI Radeon 4890
G.Skill Perfect Storm F3-17066CL9T-6GBPS (355€ in Finland)
Windows Vista 32-bit
Then some screenshots:
First some P55 action -DDR3 2500 9-10-9-24-1T (1.8V) (Dual channel 4GB)
Core i7 triple channel tests:
This memory does not like tight timings too much
6-7-6-18-1T / DDR3 1700+
7-8-7-22-1T / DDR3 2000
7-9-7-22-1T / DDR3 2135
8-9-8-22-1T / DDR3 2200
8-10-8-24-1T / DDR3 2400
3DMark05 8-10-8-24- 1T / DDR3 2400
Max speed on single stage. Would have done this at 8-10-8 as well, but uncore was getting too high:
This kit is perfect for any type of use. It can handle some nice overclocks and it is stable and strong in normal 24/7 use as well. These chips can handle voltage, so sudden death should not be the issue with these.
I can sincerely recommend these to everyone. Only negative thing is the price at the moment, but if some chips are binned, they will not be free.
Thank you G.Skill and Frank!
Thanks for checking this thread![]()
