Page 1 of 2 12 LastLast
Results 1 to 25 of 45
Thread: 6GB Gskill Trident F3-16000CL9T-6GBTD [lots of screenshots]
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Talking 6GB Gskill Trident F3-16000CL9T-6GBTD [lots of screenshots]
    Received a new triple channel memory kit from folks at Gskill - 6GB Gskill Trident F3-16000CL9T-6GBTD. The Gskill Trident F3-16000CL9T-6GBTD is supposedly using Elpida BBSE memory ICs, while not as capable as Elpida Hyper 50mm ICs for >DDR3-2000Mhz 7-8-7-x speeds, they still hold their own for looser timings.
    I'll post my preliminary results here in preparation for a larger triple channel memory kit comparison review in the works
    System:
    First hour using this kit and managed an overclock on these for 8x 32M Pi @DDR3-2124Mhz 9-9-9-24 1T at 1.72v. Asus P6T6 WS Revolution bios sets latencies pretty tight so good pi performance even for Win7 OS
    Both 8x 32M Pi and single 32M Pi runs done in same windows session.
    Shows promise, so now to let this memory kit get to know my Xeon W3540 + Asus P6T6 WS Revolution pairing
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Timings and CMD Rate comparison
    Some preliminary memory tests for new 6GB Gskill Trident F3-16000CL9T-6GBTD triple channel memory kit in preparation for a larger triple channel memory kit comparison review in the works
    • 20x200bclk : 2000Mhz 99924 2T tRFC 98 1.66v 1.47500v
    • 20x200bclk : 2000Mhz 99924 1T tRFC 98 1.66v 1.48125v
    • 20x200bclk : 2000Mhz 89824 2T tRFC 98 1.66v 1.48125v
    • 20x200bclk : 2000Mhz 89824 1T tRFC 98 1.66v 1.48125v
    • 20x200bclk : 2000Mhz 79721 2T tRFC 88 1.66v 1.48750v
    • 20x200bclk : 2000Mhz 79721 1T tRFC 88 1.72v 1.50000v
    • 20x200bclk : 1600Mhz 67618 2T tRFC 88 1.66v 1.37500v
    • 20x200bclk : 1600Mhz 67618 1T tRFC 88 1.66v 1.37500v
    • 23x175bclk : 2100Mhz 99924 2T tRFC 98 1.70v 1.55000v
    • 23x175bclk : 2100Mhz 99924 1T tRFC 98 1.72v 1.55000v
    • 23x175bclk : 2100Mhz 89824 2T tRFC 98 1.72v 1.55000v
    • 23x175bclk : 2100Mhz 89824 1T tRFC 98 1.72v 1.55000v
    DDR3-2000Mhz 9-9-9-24
    2T vs 1T
    Gskill Trident DDR3-2000Mhz kit is rated for 9-9-9-24 2T timings, so to start with testing the difference between 2T vs 1T.
    System:
    DDR3-2000Mhz 9-9-9-24 2T
    CMD Rate = 2T
    VDIMM = 1.66v
    QPI/DRAM = 1.475v
    Super Pi 32M
    Hyper Pi 8x 32M
    Everest
    Linx v0.6.2 All memory test 3x run
    Load
    Complete
    DDR3-2000Mhz 9-9-9-24 1T
    Need to bump QPI/DRAM uncore volts a tad for 1T.
    CMD Rate = 1T
    VDIMM = 1.66v
    QPI/DRAM = 1.48125v
    Super Pi 32M
    Hyper Pi 8x 32M
    Everest
    Load
    Complete
    Memory Addict
    Aug 2002
    Brisbane, Australia
    DDR3-2000Mhz 8-9-8-24
    2T vs 1T
    Now to tighten the timings @DDR3-2000Mhz 8-9-8-24 and test 2T vs 1T CMD Rate at same 1.66v vdimm and 1.48125v QPI/DRAM uncore voltage.
    System:
    DDR3-2000Mhz 8-9-8-24 2T
    CMD Rate = 2T
    VDIMM = 1.66v
    QPI/DRAM = 1.48125v
    Super Pi 32M
    Hyper Pi 8x 32M
    Everest
    Load
    Complete
    DDR3-2000Mhz 8-9-8-24 1T
    CMD Rate = 1T
    VDIMM = 1.66v
    QPI/DRAM = 1.48125v
    Super Pi 32M
    Hyper Pi 8x 32M
    Everest
    Load
    Complete
    Memory Addict
    Aug 2002
    Brisbane, Australia
    DDR3-2000Mhz 7-9-7-21 tRFC = 88
    2T vs 1T
    Further tightening of timings @DDR3-2000Mhz 7-9-7-21 with tRFC = 88 and test 2T vs 1T CMD Rate at same 1.66v vdimm and 1.4875v QPI/DRAM uncore voltage for 2T and 1.72v and 1.5v QPI/DRAM uncore voltage for 1T.
    System:
    DDR3-2000Mhz 7-9-7-21 2T
    CMD Rate = 2T
    tRFC = 88
    VDIMM = 1.66v
    QPI/DRAM = 1.4875v
    Super Pi 32M
    Hyper Pi 8x 32M
    Everest
    Load
    Complete
    DDR3-2000Mhz 7-9-7-21 1T
    Need to bump QPI/DRAM uncore volts a bit but vdimm alot for 1T to pass Hyper Pi 8x 32M Pi test!.
    CMD Rate = 1T
    tRFC = 88
    VDIMM = 1.72v
    QPI/DRAM = 1.5v
    Super Pi 32M
    Hyper Pi 8x 32M
    Everest
    Load
    Complete
    Memory Addict
    Aug 2002
    Brisbane, Australia
    DDR3-1600Mhz 6-7-6-18 tRFC = AUTO
    2T vs 1T
    Drop mem clocks down but tighten timings @DDR3-1600Mhz 6-7-6-18 2T vs 1T at 1.66v with much lower 1.375v QPI/DRAM uncore voltage.
    System:
    CMD Rate = 2T
    tRFC = AUTO
    VDIMM = 1.66v
    QPI/DRAM = 1.375v
    Super Pi 32M
    Hyper Pi 8x 32M
    Everest
    Load
    Complete
    DDR3-1600Mhz 6-7-6-18 1T
    CMD Rate = 1T
    tRFC = AUTO
    VDIMM = 1.66v
    QPI/DRAM = 1.375v
    Super Pi 32M
    Hyper Pi 8x 32M
    Everest
    Load
    Complete
    ODOC
    Aug 2006
    Copenhagen - Denmark
    Hey George , thats a killer writeup your started
    Not to mention your kit is dang sweet ...
    keep pushing it
    Moderator
    Nov 2006
    and here we go George with +20 test great work
    thanks for sharing
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thanks guys
    Apr 2006
    Italy
    good kit and review
    2100 C8 is possible?
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by Sav View Post
    good kit and review
    haven't tried yet, guess will do that next 2100 8-9-8-24 2T vs 1T vs 2100 9-9-9-24 2T vs 1T
    Moderator
    Nov 2006
    Quote Originally Posted by eva2000 View Post
    noithing change in my case george max 5/10 MHz using XMP profile
    Champion
    May 2006
    Bangkok, Thailand
    Nice stuff eva and thank you for greats review
    Sorry For My English
    OverclockZone Team
    THAILAND
    Xtreme Guru
    Apr 2005
    Finland
    Did you try 9-10-9-x ?
    These BBSE mems seem to like high TRCD value and it allows for a serious jump in clock, more than changing CAS. I run my Ripjaws 2x2GB @ DDR3-2292 9-10-9-22 1.665v as 24/7, haven't tested going higher cuz my CPU is so crappy (1.4125v bios for 191x21). I'm pretty sure they'd be capable of 9-10-9-x @ ~DDR3-2400 if I used 1.68v. These mem ICs remind me of TCCD for DDR1, likes high frequency and losened timings and doesn't require a lot of volts either.
    Intel? Core i5-4670K @ 4.3 GHz | ASRock Extreme6 Z87 | G.Skill Sniper 2x8GB @ DDR4-1866 CL9 | Gigabyte GTX 970 OC Windforce 3x | Super Flower Titanium 1000W | ViewSonic VX2268wm 120Hz LCD | Phanteks PH-TC14PE | Logitech MX-518 | Win 7 x64 Professional | Samsung 850 EVO & 840 Pro SSDs
    If all people would share opinions in an objective manner, the world would be a friendlier place
    Mar 2009
    Germany
    BBSE Chips Rocks
    Nice Clocks , Top Thread and Pictures
    Jun 2006
    Northern California
    I think I may get this set for my new 920 EVGA Classified build, looks nice, and decent price at the Egg.
    In Progress:
    EVGA X58 Classified w/EK-FB full board block | Core i7 920 w/ Enzotech Sapphire | 6GB Gskill Trident F3-16000CL9T-6GBTD | ATI Radeon 4870 1GB | Hitachi 320GB HD x2 | Hitachi 1TB HD x2 | PCP&C Silencer 750W PSU | D5 Vario w/EK-D5 v2 | MCR320-QP w/cheap Yates (for now)
    Dec 2005
    Philly
    The G.Skill Tridents are awesome for the price!!! I picked up a set for $150.00 from Newegg 2 weeks ago to play with while my Kingston 2000 CL8 Elpida Hypers are out for RMA. Hoping they send me Hypers back. If not then 12GB Triple Channel BBSE
    Here are a few quicks shots of how I made out. Pretty much same results as eva2000. Having trouble getting 2100Mhz CL8 LinX stable without really high QPI voltage.
    4770K and 3770k
    MVI Gene and MV Gene
    2 kits TeamX 2400Mhz 2x4GB @ 2600Mhz 10-12-12--28-1T
    Asus 670GTX DCII
    Corsair AX1200 ~ Corsair TX850
    (2) OCZ Vertex 4 RAID0 ~
    Samsung BluRay Burner SH-B123L
    800D~EK Supreme HF Nickel~EK Coolstream 360~BP Matte Black Modded MCP655
    BP Mod Top V2~EK Res~Distilled Water~Silvercoils
    Memory Addict
    Aug 2002
    Brisbane, Australia
    high QPI/DRAM (cpu vtt) volts is always necessarily for stability for high mem/bclks
    Quote Originally Posted by ZoLKoRn View Post
    thanks
    Quote Originally Posted by RPGWiZaRD View Post
    interesting haven't tried 9-10-9, next up i guess
    Quote Originally Posted by Marvin82 View Post
    BBSE Chips Rocks
    thanks
    Updated results http://i4memory.com/f83/6gb-gskill-t...results-19504/
  18. #18
    Mar 2007
    Pune, India
    indepth testing as always eva
    plenty of screenies :p
  19. #19
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by aditya View Post
    Indeed, very cool!
    These are arriving soon, going to use some info from these posts.
    Donate to XS forums
  20. #20
    Memory Addict
    Aug 2002
    Brisbane, Australia
    thanks aditya and zalbard.
    Max memory clocks @9-10-9-24 1T at 1.76v
    Folks are reporting higher head room mhz with 9-10-9-x timings for Elpida BBSE, and I can confirm that is correct. With 9-9-9-24 this trident kit maxing out 32M around DDR3-2124mhz with ceiling of semi-stability around 2160mhz. With 9-10-9-24 timings same trident kit pushed 32M pi @DDR3=2220mhz and managed validation @DDR3-2281Mhz all at 1.76v vdimm and 1.65v QPI/DRAM uncore volts.
    System:
    Max Validation @DDR3-2281Mhz 9-10-9-24 1T at 1.76v
    Max Screenshot @DDR3-2267Mhz 9-10-9-24 1T at 1.76v
    Max Super Pi 32M @DDR3-2220Mhz 9-10-9-24 1T at 1.76v
  21. #21
    Team ID - Indonesia
    Oct 2003
    Jakarta - Indonesia
    Awesome writeup George Thanks for sharing
  22. #22
    Jul 2009
    Germany _ Frankfurt
    Thanks for sharing, very nice memory, hope can also get one kit on eBay
    www.vitesse24.de
    www.vitesse24.de
    C2Q q6600 3.3GHZ @ 1,184V
    4,5GHZ@ 1,52V ( 9* 500 )
    Corsair Dominator 10000 2gb, 8888 2gb, 9136 1gb
  23. #23
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Quote Originally Posted by Benny Lodewijk View Post
    Quote Originally Posted by aslanwas View Post
    thanks guys.. will try tRCD 11 as well see if there's any more raw mhz left in the memory
  24. #24
    Xtreme Guru
    Apr 2005
    Finland
    Told ya tRCD 10 would help and I think that's where this BBSE ram shines. I didn't try 11 myself, but I'm satisfied with DDR3-2292 9-10-9-22 anyways at 1.665v. Ofc P55 and X58 can't be directly compared but pushing near 2300 in tripple channel is awesome for X58 for this price.
  25. #25
    Memory Addict
    Aug 2002
    Brisbane, Australia
    well seems tRCD 10 is loosest P6T6 WS Revolution bios will go lol.. can't select tRCD 11 heh
    New personal best cpuz memory validation and first time breaking DDR3-2300Mhz for triple channel on X58 @DDR3-2305Mhz 9-10-9-24 1T at 1.78v. Previous best was @DDR3-2298Mhz 9-9-9-24 with 3GB Samsung HCF0 modules.
    System:
    Max Validation @DDR3-2305Mhz 9-10-9-24 1T at 1.78v
    QPI/DRAM = 1.65625v
    VDIMM = 1.78v
    Uncore frequency = 4608Mhz
    Super Pi 2M @DDR3-2256Mhz 9-10-9-24 1T at 1.78v
Tags for this Thread
