The NOTalis project was the result of E.E.L. Ambiense's recent 4 day visit to Minnesota. We've talked about getting together for the last couple of years. We both agreed that a Mini ITX project wouldn't suck up too much of his 4 days. He suggested the Silverstone SG05. E.E.L. made some conceptual drawings from home so we had a plan. The SG05 arrived 2 days before he did. I brought it to the machine shop on Thursday to mill a new bezel design. E.E.L. was inspired by the Nautilus submarine's window from Jules Vern's 20,000 Leagues under the sea (disney movie 1954).
We titled the project "NOTalis" because it sounded funny.
The both of us had always talked about experimenting with instant rusting techniques and products. We're both fans of Piloux's Blackmesa HL2 case mod. A historical chapter in case modding. We planned to use the same product Piloux used. I believe we found the current version by Sophisticated Finishes. Piloux never explains his application techniques in detail which forced us to experiment a lot. It can be a little frustrating to use this product because you must wait for the results. You just learn to keep busy with other things, like sleeving a PSU or cutting a 240mm fan grill. We discovered on the last night that a heat gun sped up the rusting process.
We only spent two evenings working on the project. We were both amazed we didn't need more time, but we work very efficiently together.
Since it was E.E.L.'s first time here. I brought him to some interesting local businesses and eateries. We spent a great deal of our time just talking shop. So this get together was historical for us. We made a point to record everything knowing it would be shared here with you.
We'll be including these PC Cable management clamps with the case
http://www.mnpctech.com/CableClamp.html
Silverstone SG05 Mini ITX case
OEM 120mm fan location (modified to 140mm)
3/4" thick block of 6061 aluminum
140mm intake design inspired by "Nautilus" submarine window from Jules Vern's 20,000 Leagues under the sea
...where is the rest
