Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: 4890 water block installed on 5870
    Feb 2009
    Fremont N.H. USA
    Hi guys I tried my heatkiller water block on my 5870 and at first everything lined up except 2 screw holes on outside of card. I decided to give it another try and I managed to get one of the outside screws in. The bottom card is running at 18c at idle.I am about to install block on top card.
    Xigmatek Elysium Case
    Intel I7-3770K
    Asus Sabertooth Z77
    16 Gigs Ripjaws 2133mhz Ram
    Mushkin 240 SSD
    Lightscribe Dvd Burners
    EVGA GTX 680
    Aquacomputer Gpu Block
    Cooler Master Hybrid 1050 Watt Pws
    EK Supremacy Cpu Block
    Xspc RX360 Rad
    Xspc XS360 Rad
    Phobya 250 Balancer Res
    2 x Mcp 350 Pumps
    L-l-look at you, hacker.
    Jun 2007
    Perth, Western Australia
    The thread title is a little misleading - this isn't a 5870 FC block installed, this is a HK-4870/90 block installed on a 5870 card.
    Can we have some closeups of the misaligned screws?
    Rig specs
    CPU: i7 5960X Mobo: Asus X99 Deluxe RAM: 4x4GB G.Skill DDR4-2400 CAS-15 VGA: 2x eVGA GTX680 Superclock PSU: Corsair AX1200
    Foundational Falsehoods of Creationism
    Xtreme Guru
    May 2009
    Southfield, MI
    Peak temps would be nice too. I hope the screw didn't get cross threaded.
    Project Millertime: The Core I5 build
    Crunching/folding box on air: AMD Athlon X2 7750 Black Edition; Sapphire Radeon HD 4830; Gigabyte MA78GM-US2H; Lian Li PC-V351; Windows 7 RC
    Feb 2009
    Fremont N.H. USA
    I just installed the heatkiller 4890 water block on my 2 5870,s. I didnt mean to mislead anyway in last post by the title. This block is from a 4890 and the 4 holes around gpu line up fine. Take a look for yourself and tell me what you think.
ID:	97908   Click image for larger version.
Name:	5870 # 1.gif
ID:	97909   Click image for larger version.
Name:	5870 # 2.gif
    Intel I7-3770K
    Asus Sabertooth Z77
    Mushkin 240 SSD
    EVGA GTX 680
    Xspc RX360 Rad
    Xspc XS360 Rad
    2 x Mcp 350 Pumps
    Nov 2005
    very nice!!
    Jul 2008
    Portugal
    Wow, 21 and 25 celsius not bad AT ALL
    ASUS Sabertooth P67B3ˇ nVidia GTX580 1536MB PhysX ˇ Intel Core i7 2600K 4.5GHz ˇ Corsair TX850W ˇ Creative X-Fi Titanium Fatal1ty
    8GB GSKill Sniper PC3-16000 7-8-7 ˇ OCZ Agility3 SSD 240GB + Intel 320 SSD 160GB + Samsung F3 2TB + WD 640AAKS 640GB ˇ Corsair 650D ˇ DELL U2711 27"
    Feb 2009
    Fremont N.H. USA
    The screw did not cross thread I made sure of that.Will try to get Peak temps soon. I just finished with install of 2nd block you can see the blocks and idle temp in the other thread I posted.
    Intel I7-3770K
    Asus Sabertooth Z77
    Mushkin 240 SSD
    EVGA GTX 680
    Xspc RX360 Rad
    Xspc XS360 Rad
    2 x Mcp 350 Pumps
    Moderator
    Aug 2007
    Back and forth between Florida and Maine
    I deleted the other thread and merged the posts into this one to give you one thread to respond to and minimize confusion.
    Nice temps.
    Jan 2008
    Quote Originally Posted by rmorse27 View Post
    Peak temps soon.
    Nice job, looking forward to this data (when you run @ load, can you have four gpu-z windows showing all sensors on both cards?)
    Bring... bring the amber lamps.
    [SIGPIC][/SIGPIC]
    Jul 2008
    Portugal
    It's not cooling this guy here, though:
    Oct 2007
    London, UK
    Quote Originally Posted by NaMcO View Post
    Now that makes you think what else apart from the GPU core is not in contact with the block...
    Quote Originally Posted by creidiki View Post
    We are a band of fearless modern-day alchemists who, for fun, run solutions through sophisticated, if overpriced, separator setups, and then complain when we succeed in separating said solution.
    Jan 2008
    [IMG.]http://www.tech-caffe.com/gfx/block.jpg[/IMG]
    Is that a ram chip broken off?
    PI in the face
    Nov 2008
    no it is not
    Quote Originally Posted by L0ud View Post
    So many opinions and so few screenshots
    Feb 2009
    Fremont N.H. USA
    peak temps
    Here are some peak temps when playing cod waw. I check the other temps and there is nothing that jumps at me.
Name:	5870 # 1 peak.gif
ID:	97911   Click image for larger version.
Name:	5870 # 2 peak.gif
    Intel I7-3770K
    Asus Sabertooth Z77
    Mushkin 240 SSD
    EVGA GTX 680
    Xspc RX360 Rad
    Xspc XS360 Rad
    2 x Mcp 350 Pumps
    Jan 2008
    rmorse27, MVDDC Phase Temp #1?
    [SIGPIC][/SIGPIC]
    Jun 2007
    Those are some pretty massive disparities between the first and second card. Temps, clocks, power-draw - is Crossfire enabled?
    Rig specs
    Feb 2009
    Fremont N.H. USA
    There where disparities on air and yes xfire is enabled. I am ordering some heat sinks for that area that,s not covered. Everybodys a critic.
    Intel I7-3770K
    Asus Sabertooth Z77
    Mushkin 240 SSD
    EVGA GTX 680
    Xspc RX360 Rad
    Xspc XS360 Rad
    2 x Mcp 350 Pumps
  18. #18
    Jan 2008
    He's just asking because your second gpuz is showing idle clocks of 157/300 while your first card is in 3d. And, 34C / 22C implies your only running 1 card in 3d. Try different Cat AI settings.
    [SIGPIC][/SIGPIC]
  19. #19
    Jun 2007
    Hey, I'm not criticising anything - but if I was you, I'd be very concerned about my second 5870 running at a core clock of 157MHz and a mem clock of 300MHz, when the first is running at 890/1225. Either GPU-Z is reading wrong, which is unlikely given that it's picking the first card up just fine, or the second card is stuck in 2D mode.
    Rig specs
  20. #20
    Feb 2009
    Fremont N.H. USA
    sorry about critic remark,if its stuck in 2d does that mean cards is bad or maybe just the driver?
    Intel I7-3770K
    Asus Sabertooth Z77
    Mushkin 240 SSD
    EVGA GTX 680
    Xspc RX360 Rad
    Xspc XS360 Rad
    2 x Mcp 350 Pumps
  21. #21
    Xtreme Guru
    Jan 2005
    Tre, Suomi Finland
    If that chip is not cooled the card is sure to DIE. SOON.
    Quote Originally Posted by jaredpace View Post
    Seconded. I'm guessing something in excess of 100ēC.
    You were not supposed to see this.
  22. #22
    Jul 2009
    Gatech atm
    ATI drivers disable the second card when the game is not using cfx? also i have seen that occur in various situations. Try a benchmark program instead furmark for example. but i would get some cooling on those chips uncooled before you get to the benches.
  23. #23
    Dec 2008
    EU
    Quote Originally Posted by largon View Post
    yes. try it and (possibly) fry it.
  24. #24
    Jul 2008
    Portugal
    Quote Originally Posted by Jowy Atreides View Post
    Nope, looks like a MOSFET, which probably is.
    Yeah i'd take care of cooling it. Watch out for it @ OP, might kill the card
  25. #25
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    that part is the mosfet for the ram power, it needs a heatsink but anything works from the looks of it even the little enzo ones
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
