Results 1 to 16 of 16
Thread: At a loss..and need some help.
Threaded View
    Jan 2009
    Angry At a loss..and need some help.
    Updated:
    Okay, motherboard outside the case. Works fine...
    Motherboard inside the case...sometimes boots, other times the motherboard hangs on 2E.
    I stripped the board down to cpu and ram when in the case, same grounding problems. I put those insulating washers on the mobo screws..same problems. I took the I/O backplate off, same problems.
    Has anyone had grounding problems with a 790FX-GD70??
    I'm really at a loss here what to do now..it's really starting to get to me..
