Hi all!
THERE WILL BE NO DOWNLOAD LINKS AT THIS POINT AND PLEASE DO NOT PM ME ABOUT THIS(This should not be offending, if someone find it that way)
We have been doing some work to solve the problem in 4890 overclocking. We all have seen this issue, when we have tried to push our 4890 cards higher.
We got new bios with requested fixes to test few days a go and I decided to try it out today with my dual head CF/SLI single stage.
Temperatures were like under -30C on load and -40c on idle, so much more is coming when I will put these cards under LN2
I have no info when this bios will be officially released, but it will happen sooner or later.
See the results yourself:
Single card fillrate 1225MHz:
Single card 03 1200MHz (4890 record?)
Single card Vantage 1200MHz (4890 record?)
Maximum clock speed at -30c 1340MHz
Then I installed second 4890 in to the setup. This card is ES and it is not good clocker. (1030 on air)
Results:
Dual card fillrate 1200MHz
03 Dual cards at 1150MHz
Vantage, Dual cards at 1150MHz
I will get some better 4890 cards tomorrow and I will try to do some 05 and 06 scores with them. Let's hope, that the 975 will do at least 5.3GHz in 05
I'm satisfied if these cards will do at least 1.3GHz on LN2
Bench day will be thursday and hopefully my lucky mascot Massman will be helping me in here.
