Results 1 to 10 of 10
Thread: XFX HD 4890 Black Edition: OC-Lock over 1.066 MHz GPU-Clock??
    Nov 2003
    europe - germany - cologne
    Hello
    i have two XFX 4890 BE with 1.000 MHz GPU-Clock default.
    But there is a little problem: i canīt go over 1066 MHz GPU
    1066 is benchstable with 1.38 Volt
    If i set 1067 and more the cards crash immediately. no 3D-Load.
    I test 1.45 volt, but no chance.
    I tested each card separate.
    ATI Catalyst 9.5 and 9.6
    Rivatuner and other programs.
    Aircooling and water, but no chance.
    Some other people with the XFX BE have this problem too.
    Is it a hardware lock?
    What can i do??
    Sorry for my bad english...
    System1
    System2
    Engineering The Xtreme
    Feb 2007
    MA, USA
    you tried more than 1067?
    Nov 2003
    yes.
    1070
    1075
    1080
    System1
    System2
    Feb 2007
    MA, USA
    I think maybe it is an issue with AMD gpu clock tool (what you are using right?)
    Nov 2003
    i test Rivatuner and GPUTool.
    System1
    System2
    Dec 2006
    Denmark, Horsens
    I got same problem. 1066Mhz without problems, 1067Mhz = Green screen
    OCTeamDenmark Crew - Cooled and sponsored by CoolerKit.dk
    Dec 2008
    Washington DC
    Try contacting xfx see if they have a bios update.
    Motherboard: GigaByte P67UD4 f6 | CPU: Intel 2500k 4.5ghz 1.26v | Memory: GSkill 2x4gb @ 1600mhz 1.34v | PSU: SeaSonic X650 Gold 650W | Video: AMD 6970 Koolance water block 880c/1450mem 1.035v | HDD: WD 640gb cavier black: VelociRaptor 300gb: Intel x-25 g2 80gb | Sound: Asus xonar D1 | OS: W7 64bit
    Xtreme Legend
    Mar 2005
    Australia
    who says you are actually giving it 1.45vcore
    check your DMM
    Team.AU
    Got tube?
    GIGABYTE Australia
    Nov 2003
    Quote Originally Posted by Sgt.McRuff View Post
    done. But no new bios
    Quote Originally Posted by dinos22 View Post
    check your DMM
    good idea. i will check it later.
    System1
    System2
    Dec 2006
    Denmark, Horsens
    check your DMM
    I dont think it is the problem. It also make green screen in 2D
