XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme Mods > Xtreme Graphx Vmods
Reply
Old 06-20-2009, 01:07 PM   #1
AgentGOD
AgentGOD's Avatar
GPU Voltage Tuner - All-new intuitive voltage tweaker!
Code:
GPU Voltage Tuner v1.4
by AgentGOD
Home Page: http://www.ultimate-filez.com  http://www.epichardware.com
Donation : http://www.ultimate-filez.com/?page=donate
Description:
	This program allows easy GPU voltage adjustments on GPUs with volte
	rra-based voltage regulators and it uses the award-winning and criti
	cally acclaimed RivaTuner for these adjustments.
	WARNING! By using this program, you agree that the author is NOT
	responsible for ANY consequences as a result of using this program.
	You, the user, are liable for any damages occured. Be a smart overc
	locker and monitor those temperatures and voltage levels!
Compatibility:
	Most GT200 GPUs are supported, some G92 GPUs, and all RV770/790 GPUs
	above 4870, and several custom PCB boards. If you aren't sure, just
	try it and see if it works ;)
	Tested on: Visiontek Radeon HD 4870 X2, BFG GeForce GTX 295,
		   SAPPHIRE Radeon HD 4870 X2, ATI Radeon HD 4890,
		   ASUS EAH4870 X2 Tri-Fan, and more!
Requirements:
	- RivaTuner (v2.24 is the minimum version)
	- A compatible GPU with volterra-based voltage regulators
	- Latest GPU drivers
	- A modern Windows-NT based operating system (XP and above). Both x86 and x64 are supported.
	- Microsoft(R) Visual C++ 2008 Runtime (x86), can be found here:
  	  http://www.microsoft.com/downloads/details.aspx?FamilyID=9b2da534-3e03-4391-8a4d-074b9f2bc1bf
 	- Microsoft(R) .NET Framework v2.0 (minimum), can be found here:
  	  http://www.microsoft.com/downloads/details.aspx?FamilyID=0856EACB-4362-4B0D-8EDD-AAB15C5E04F5
Instructions:
	First, you need to put the full path to RivaTuner in RivaPath.txt (with a
	trailing backslash [\]).
	I designed this program with automation in mind, so most settings should
	already be correct. But if they aren't you can correct them. For example,
	in the GPU Information section, if the selected voltage is not the "3D"
	performance voltage, please select the correct one. You can change the
	"Current GPU #" drop-down to anything you want, it's for your information.
	What you set under "GPU Voltage Tuning" for "Number of GPUs" will affect
	which GPUs' voltages get set. Again, it should be automatically detected.
	Voltages available range from 0.8625v to 1.6000v, so be careful what you set!
	If all of the voltage VIDs are displayed as "0xff", then you selected a
	non-existant GPU under "Current GPU #".
	* Note: Do not have RivaTuner running prior to running GPU Voltage Tuner, it
	  will refuse to work properly.
	* Also, if you are unsure whether the automatically detected and selected vo
	  ltage is correct, you can check by loading up a full-screen game with GPU-Z
	  or RivaTuner logging the GPU voltage in the background. If it is incorrect,
	  simply select the correct load voltage.
	* If you wish to set voltages higher than 1.45v, you'll need to unlock higher
	  voltages through the Advanced Settings menu by right-clicking the voltage
	  drop-down.
Credits:
AgentGOD    - coding this program, duh :D
Unwinder    - for RivaTuner, excellent GPU tweaking program
justageek95 - for originally exposing the ability to set voltages
3oh6	    - for writing an excellent in-depth guide on voltage setting
tommyk2005  - for testing on BFG GeForce GTX 295 :)
Screenshot:
Download link:
http://www.ultimate-filez.com/files/VoltageTuner.zip
I made this for even easier use than the other programs introduced by other fine members of XS. It works more automatically as well.
Enjoy! Please test it!
__________________
.:: Gaming PC Specs ::.
Case: Antec Nine Hundred
CPU: Intel C2Q Q9650 @ 4.0 GHz (9x445), 1.31v (cooled by Xigmatek HDT-S1283) [IntelBurnTest{Linpack} stable]
GPU/Monitor: Visiontek HD 4870 X2 @ 800 MHz/4000 MHz +SyncMaster245BW 24"
Motherboard: ASUS P5Q Deluxe (BIOS 2005)
Memory: 8 GB (4x 2 GB) OCZ Reaper HPC DDR2 1066 @ 1069 MHz, 5-5-5-18, 1.90V
Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
PSU: OCZ GameXStream 700W
O/S: Microsoft® Windows Vista Ultimate X64 SP2
.:: HTPC Specs ::.
Case: Silverstone LCB13B-E ATX
CPU: Intel C2Q Q6600
GPU/Monitor: Gigabyte Radeon HD 4350 +Philips 42" 1080p 120Hz
Motherboard: Gigabyte GA-EP45-UD3R
Memory: 4 GB (2x 2 GB) OCZ Reaper HPC DDR2 1066
Hard Drive: 2x Western Digital Caviar Black 1 TB (RAID 1)
Sound: 7.1 surround through HDMI
PSU: OCZ ModXStream Pro 500W
AgentGOD is offline   Reply With Quote
Old 06-20-2009, 01:50 PM   #2
AgentGOD
AgentGOD's Avatar
Originally Posted by i found nemo View Post
uhhh..... says it's configured incorrectly
You're missing these:
http://www.microsoft.com/downloads/d...d-074b9f2bc1bf
http://www.microsoft.com/downloads/d...D-AAB15C5E04F5
__________________
.:: HTPC Specs ::.
Old 06-20-2009, 01:54 PM   #3
i found nemo
Xtreme Mentor
i found nemo's Avatar
lol i just deleted my post. trying it out with 2008 runtime
i'm stupid, sorry for my stupid :P
__________________
Originally Posted by ToTTenTranz View Post
"ATI/nVidia drivers suckz0rs!!! I had two gazillion driver BUGZZ per second with ATI/nVidia cards and when I changed to nVidia/ATI everything got PEEERFECT! Zero BUGZ! And performance went up 2000%, the weather got better, my car suddenly has 200hp more than before and my girlfriend likes my sexual performance again!!!"
i found nemo is offline   Reply With Quote
Old 06-20-2009, 11:38 PM   #4
AgentGOD
AgentGOD's Avatar
Please give feedback people!
__________________
.:: HTPC Specs ::.
Old 06-20-2009, 11:49 PM   #5
Mean Machine
Mean Machine's Avatar
Send a message via ICQ to Mean Machine
It says my HD4890 doesn't have a Volterra regulator and thus isn't compatible.
__________________
I beat ME4ME in the 2009 Swedish GOOC Qualifiers!
I was equally bad as ME4ME at the ROG OC Showdown!
Mean Machine is offline   Reply With Quote
Old 06-20-2009, 11:50 PM   #6
AgentGOD
AgentGOD's Avatar
You'll need to apply that special patch to RivaTuner v2.24 for RV790 (can be found in the 4890 Overclocking Guru3D article).
For saving your time, the link is here to the file:
http://files.guru3d.info/guru3d/generic/RivaTuner.zip
Here's the article itself if you need it:
http://www.guru3d.com/article/overcl...deon-hd-4890/2
__________________
.:: HTPC Specs ::.
Old 06-21-2009, 12:00 AM   #7
Mean Machine
Oyeah, probably should've read the readme first. :P My bad.
__________________
Old 06-21-2009, 12:02 AM   #8
NaMcO
NaMcO's Avatar
Works just fine with my other PC's HD4890. Set to 1.3750v and able to attain 1GHz core speed easily. Used in Windows 7.
__________________
Rampage 2 Extreme · GTX295 SLI 1792MB FTW · Core i7 920 4.2GHz · Corsair HX 850W · SupremeFX X-Fi
6GB GSKill Trident PC3-16000 · Intel SSD 80GB RAID0 & Samsung F3 1TB RAID0 · Silverstone TJ07 · Samsung 24"
NaMcO is offline   Reply With Quote
Old 06-21-2009, 12:10 AM   #9
AgentGOD
AgentGOD's Avatar
So it correctly detects the load voltage, and number of GPUs?
What about your GTX 280's?
__________________
.:: HTPC Specs ::.
Old 06-21-2009, 12:17 AM   #10
NaMcO
NaMcO's Avatar
Completely. All i had to do was set the voltage to 1.3750 (value i came up with previous tests) and Voilá
Here's a screenie:
The GTX280's are in another build which is undergoing a huge modification, i can try them individually here later on (mobo doesn't support SLI).
__________________
Old 06-21-2009, 12:19 AM   #11
AgentGOD
AgentGOD's Avatar
Excellent, now we know it works on RV790s and single-GPUs properly Thanks for your feedback!
Only GPU I was able to test personally was my 4870 X2, and that's dual-GPU obviously
__________________
.:: HTPC Specs ::.
Old 06-21-2009, 01:11 AM   #12
spajdr
Xtreme OC addict
spajdr's Avatar
Send a message via ICQ to spajdr Send a message via MSN to spajdr Send a message via Skype™ to spajdr
Not working here with my Sapphire 4890 1GB Vapor-X.
I used modified config to rivatuner.
Still getting error that i dont have volterra regulator.
(Windows 7 x64 7201 version).
Is there something else im missing or just my card dont have volterra regulator?
__________________
ASUS Rampage II GENE + Intel i7-920 @ 3.8 GHz + Noctua NH-U12P SE1366
6 GB DDR3 OCZ Intel Extreme XMP 1600MHz / Palit Geforce 295GTX 1792MB watercooled
2 x 30GB SSD OCZ Vertex RAID 0 (games) / 1x 30GB SSD OCZ Vertex Turbo (system)
24" Dell G2410 / Nexus RX-8500 850W / Coolermaster HAF 932 / Asus OC STATION
spajdr is offline   Reply With Quote
Old 06-21-2009, 04:36 AM   #13
dinos22
...you two characters
dinos22's Avatar
thanks for this
just tried it and it works great
Asus 4870X2 Tri-fan EAH edition
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 06-21-2009, 04:51 AM   #14
dinos22
dinos22's Avatar
btw VMEM voltage is showing in Rivatuner monitoring
does it mean we could adjust it via software as well
could you integrate that as well PLEASE
__________________
Team.AU
Got tube?
Old 06-21-2009, 06:51 AM   #15
Lestat
I am Xtreme
Lestat's Avatar
Send a message via AIM to Lestat Send a message via MSN to Lestat
doesnt work on my Evga GTX285, says i dont have the Volterra
Windows 7 x86
__________________
no more computer......
Heat Ebay XB360 GamerTag VvvlestatvvV
Lestat is offline   Reply With Quote
Old 06-21-2009, 09:19 AM   #16
Royalk
still not work with GTS 250 (G92) with the RT8841 PWM
Royalk is offline   Reply With Quote
Old 06-21-2009, 10:40 AM   #17
Shahryar_NEO
Shahryar_NEO's Avatar
it doesn't work on my HD4850 ! ( non of these voltage tuner softwares work on this card until now ! )
Shahryar_NEO is offline   Reply With Quote
Old 06-21-2009, 11:24 AM   #18
The-Fox
The-Fox's Avatar
I can't set any voltage to my Sapphire 4870X2 - "Error setting voltage X.XXXX to GPU0."
Restore for voltages fails too - "Error Restoring Voltages"
Any Ideas ?
Aside from that, great initiation AgentGOD, once again you proved to be very very helpfull to the XS community
__________________
PC: Intel Core i7 920 D0 | Kingston Hyperx T1 6GB 2000Mhz 8-8-8 RAM | Foxconn Bloodrage GTI | Sapphire 4870X2 | Perc 5/i - WD 640AAKSx4 RAID0 | Asus 2014L1T | Dell 2407WFP | Lian Li G70 Silver Watercooled
WaterCooling: Q² Project by The-Fox
CPU Loop: Swiftech Apogee GTZ | Feser X-Changer 480 | Swiftech MCP655 Vario w/ DetroitAC top | EK Multioption RES 250 Rev.2 | Tygon R3603 1/2" | YL D12SL@1350RPM x4
GPU Loop: EK-FC4870 X2 Nickel | Swiftech MCR320 | Swiftech MCP655 Vario w/DetroitAC top | EK Multioption RES 150 Rev.2 | Tygon R3603 1/2" | YL D12SL@1350RPM x3
The-Fox is offline   Reply With Quote
Old 06-21-2009, 11:37 AM   #19
AgentGOD
AgentGOD's Avatar
Windows 7 x86
That's because it doesn't. NVIDIA switched the VRMs on you on the GTX 285 to a cheaper one that doesn't support software adjustments.
Any Ideas ?
Did you try running the application as admin?
__________________
.:: HTPC Specs ::.
Old 06-21-2009, 11:39 AM   #20
SNiiPE_DoGG
I am Xtreme-ly inactive
SNiiPE_DoGG's Avatar
Send a message via AIM to SNiiPE_DoGG Send a message via MSN to SNiiPE_DoGG Send a message via Skype™ to SNiiPE_DoGG
so are you guys still havign to apply 3d load before setting the voltage with this program or does it bypass that step?
__________________
Account no longer active, see contact info to get in touch
SNiiPE_DoGG is offline   Reply With Quote
Old 06-21-2009, 11:40 AM   #21
AgentGOD
AgentGOD's Avatar
Given that the auto-detection works correctly (that's also the kind of feedback I'm looking for), it should bypass that step and automatically select the correct load voltage. If it doesn't you can always manually select the correct one.
__________________
.:: HTPC Specs ::.
Old 06-21-2009, 11:42 AM   #22
SNiiPE_DoGG
ok I dont have my 4890's running right now but when I do I will test for you
__________________
Old 06-21-2009, 11:48 AM   #23
AgentGOD
AgentGOD's Avatar
It needs to have volterra regulators :P
Oh by the way, the owner of Guru3D (which as you all know is the official host of RivaTuner) has asked me to take down the link to the utility for user safety reasons (prevention of people setting 1.6v on stock cooling and killing their cards).
What do you guys think? We should have a vote on this.
__________________
.:: HTPC Specs ::.
Old 06-21-2009, 11:53 AM   #24
Paxi
Paxi's Avatar
Send a message via ICQ to Paxi Send a message via MSN to Paxi
Adjusting VMEM Voltage would be awesome
__________________
System #1:
i7 975 for bench, W3540 @ 4,4 Ghz HT On, Asus P6T 0603, 3x2048 Corsair Dominator 2000CL7, Sapphire 4870X2 @ 825/1000 (Asus TOP Bios), Corsair HX1000, 1x150GB Velociraptor, 1x1TB WD Green, 1x500GB WD Caviar
Cooled by:
Loop 1: D-Tek Fuzion rev1, Laing Ultra 18W /w XSPC Res Top, Thermochill PA120.3 /w Scythe Ultra Kate 2kRmp Pull
Loop 2: XSPC 4870X2 Acetal, Laing DDC-1T /w XSPC Res Top, Thermochill PA120.2 /w Medium Yates Push/Pull
4,6Ghz (21x220) 1,42Vcore with Single Stage (HT enabled)
http://img402.imageshack.us/img402/1251/83962063.jpg
AMD @ testing
X4 955, Asus Crosshair III, same Rams as on Intel Setup, Sapphire 4870X2 @ Stock, PC Power&Cooling 910W
Paxi is offline   Reply With Quote
Old 06-21-2009, 11:53 AM   #25
SNiiPE_DoGG
why would you remove the utility? if someone is dumb enough to set 1.6v to their card and kill it then they deserve a broken card. It's not like they can do anything about it killing their card.
__________________
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
