Page 1 of 3 123 LastLast
Results 1 to 25 of 52
Thread: Swiftech Gtx285 Heatsink Released
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Announcing the release of the GTX285 heatsink for Geforce GTX285 graphics cards.
    Specifications.
    Material: black anodized aluminum extrusion
    Dimensions (Inch): 8 1/4 " (L) x 3 5/8" (W) x .7" (H)
    Dimensions (Metric): 210mm (L) x 92mm (W) x 18mm (H)
    Weight: 8 oz (248 g)
    Installation: high thermal conductivity pad
    MSRP: $28.95
    Shipping now.
    CEO Swiftech
    V3 Xeons coming soon!
    Nov 2005
    New Hampshire
    Nice looking Gabe. What's the HS made of?
    The XS WCG team needs your support.
    A good project with good goals.
    Come join us,get that warm fuzzy feeling that you've done something good for mankind.
    Quote Originally Posted by Frisch View Post
    If you have lost faith in humanity, then hold a newborn in your hands.
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by Movieman View Post
    post edited to included specs.
    CEO Swiftech
    Nov 2005
    New Hampshire
    Quote Originally Posted by gabe View Post
    Nice, and IMO short money for that.
    I am Xtreme
    Aug 2008
    out of curiousity, i have a dtek fuzion for gpu's , will this heatsink work with it?
    Mar 2006
    Los Angeles CA
    Quote Originally Posted by Hondacity View Post
    Not without modding.
    Quote Originally Posted by Chruschef in regards to Thermaltake water cooling
    you'd be better off cooling your components with a fire....
    May 2008
    Finally! I had almost given up hope.
    Aug 2006
    I like that heatsink vey much.
    I am Xtreme
    Aug 2008
    Quote Originally Posted by IanY View Post
    i like it too full cover waterblocks for triple sli is heavy..... :|
    Aug 2006
    Oklahoma
    Great
    I only wish i had a 285. Still on the ole 88gtx.
    _______________
    Q66@3.8ghz
    Rampage/Maximus SE hybrid W/C. 4 gigs OCZ reapers.
    4890,s CF Dual loop rocketfish case.
    ^^^^^All shaken, (from the earthquake) not stirred^^^^^
    Quote Originally Posted by Vapor View Post
    There's a lot less voodoo in watercooling than is assumed
    The only thing future proof in electronics, is the electricity itself.
    Any one who relies on only one source of information is a fool.
    Xtreme Mentor
    Sep 2007
    Dallas
    Looks great. Nice alternative to a full cover block if money is tight and you already have a MCW60.
    CPUID http://valid.canardpc.com/show_oc.php?id=484051
    http://valid.canardpc.com/show_oc.php?id=554982
    New DO Stepping http://valid.canardpc.com/show_oc.php?id=555012
    4.8Ghz - http://valid.canardpc.com/show_oc.php?id=794165
    Desk Build
    FX8120 @ 4.6Ghz 24/7 / Asus Crosshair V /HD7970/ 8Gb (4x2Gb) Gskill 2133Mhz / Intel 320 160Gb OS Drive, WD 256GB Game Storage
    W/C System
    (CPU) Swiftech HD (GPU) EK HD7970 with backplate (RAM) MIPS Ram block (Rad/Pump) 3 x Thermochill 120.3 triple rads and Dual MCP355's with Heatkiller dual top and Cyberdruid Prism res / B*P/Koolance Compression Fittings and Quick Disconnects.
    Oct 2008
    The Mid East
    Would you guys consider this GPU cooler better than the koolance one for to the 285?
    Current Build : Antec 900 | Intel (Q9450) @ 3.22GHz | Asus P5E3 Premium | OCZ 2x2GB DDR3 PC3-12800 Reaper 1600Mhz 7-7-7-24 | EVGA GTX 285 | 2x WD 150GB VelociRaptor | Samsung 1TB HD | HP DVD Lightscribe | Windows Vista Ultimate x64bit | Corsair HX620W |
    Cooled By : Apogee GTZ | Koolance VID-NX285 | MCP355 Pump | XSPC Premium Res| Swiftech MCR320-QP Rad | Yate Loon D12SL-12D Fans | XSPC 7/16" Clear/UV Blue tubing | Bitspower Compression Fittings |
    Nov 2004
    Boston, MA
    Ordered! In answer to your question Defratos, some people dont like the additional heat added to their loop from components, such as, memory and vregs that can easily be air cooled. Also, gpu only solutions tend to cool a few degrees better than full cover waterblocks.
    **Georgia Tech Grad, I am an Electrical Engineer with a specialization in RF IC design and Analog circuits.**
    Intel I7 3770K Delidded
    Gigabyte Z77X-UD5H
    2x4gb Gskill 7-8-7-16
    EVGA GTX680 Signature OC
    Crucial M4 256gb
    Seasonic X-750
    Watercooling Loop: Raystorm Acetal, EK GTX580 Full Cover, MCR420, MCR320, MCP35X2 & 7 x AP-15 Gentle Typhoons
    Heatware: gte460z
    Banned
    Jan 2009
    gabe you should make a special part that makes it really easy to connect all the waterblocks with 2 - 4 blocks
    its hard to explain but lemme see if there is similar part from heatkiller http://www.performance-pcs.com/catal...ducts_id=25224
    make it so that when you install 3 gpus or 4 or 2 you can use a D-link connecter to connect it without making the blocks full cover
    Oct 2007
    Killadelphia, USA
    can this use for the 250 GTS too?
    Water Cube: Sunbeam UFO CUBE Acrylic Case
    Mobo: Asus CrossHair II Formula
    CPU: AMD Phenom II 920@258X14=3.6Ghz@1.45V
    CPU Water Block: D-Tek FuZion V2
    Memory: Mushkin 996599 Kit XP2-8500 6GB-
    Video Card:BFG Geforce 250GTS 1GB X2 SLI Geforce PhysX ENABLED
    SSD: INTEL SSDSA2M040G2GC X 2 RAID0 80GB
    Pumps: Swiftech MCP350 Modded to MCP355 In-Line 12V DC Pump with XSPC top &
    XSPC "Bay-Res" Pump/Reservoir Combo
    SouthBridge Water Block: Enzotech SNBW Rev.A
    Northbridge Waterblock:XSPC X2O Delta Chipset Waterblock-
    Tube: Saint-Gobain Tygon R-3603 Clear Tubing 20' 3/8" ID -
    Radiator for GPUs:Black IceŽ GT Stealth 120 Highest Performance Radiator
    Radiator for CPU, NB & SB - XSPC RS240 Radiator
    PSU:Antec NeoPower 650 Watt Blue LED PSU
    OS:Windows 7 Ultimate x64 - Fan Controller Panel:Sunbeam RHK-EX-BA Rheobus-Extreme
    Logitech Black Wired Ultra-thin Illuminated Keyboard
    Logitech G9x Black Two modes scroll USB Wired Laser 5700 dpi Gaming Mouse
    Logitech G13 USB Advanced Gameboard
    Logitech ClearChat PC Wireless USB Supra-aural Headset
    Mar 2003
    The Netherlands
    This looks better than the GTX200 heatsink I have around here... that one was flimsy at best... very lightweight and a vrm spot was missing
    But then again this one is practically 3 times heavier and better looking imho
    lol... This forum requires that you wait 70 seconds between posts. Please try again in 8 seconds.
    *phone rings*
    Friend: Do you have a spare PSU lying around?
    Me: No why?
    Friend: My PSU just blew up, I think the second 8800GTX might have been too much for it to handle
    Me: what PSU was that again?
    Friend: Antec 480w
    Me:........
    Oct 2008
    The Mid East
    Quote Originally Posted by babalouj View Post
    Umm I'm not sure if you understood the questions correctly, I was asking if the Swiftech GPU cooler is better than the Koolance GPU cooler (as I am using the koolance one). From my experience the Koolance GPU block lowered my Idle temps by 5c which to me is amazing . So I wanted to know if the Swiftech would be any better
  18. #18
    Sep 2008
    Perth, Aus
    I'd be interested to know if it fits a GTX275. If so, consider it sold!
  19. #19
    Mr Swiftech
    Dec 2002
    Long Beach, CA
    Quote Originally Posted by Garrett View Post
    the GTX200 was our first forray into the unisink business. it was an off-the- shelf extrusion. Then we made the caldera for 4870x2, and it had to be CNC... horribly expensive..
    The GTX285 is our own extrusion design, and we intend to re-use for many cards to come.
    CEO Swiftech
  20. #20
    Xtremely High Voltage Sparky's Avatar
    Mar 2006
    Ohio, USA
    Looks great and KILLER price too! I like this route, instead of a fullcover requiring replacement every upgrade (expensive), just change the heatsink base (much cheaper, on the order of a couple ramsink kits).
    If I had a 285 you bet I'd be on top of this
    The Cardboard Master
    Intel Core i7 2600k @ 4.5GHz, 16GB DDR3-1600, Radeon 7950 @ 1000/1250, Win 10 Pro x64
  21. #21
    Jul 2007
    Canada
    Glad to hear it! Too late for me this time around, but ever since the cost of full-covers has gone through the roof, I've been thinking real hard about going to core-only blocks next time around.
    i7 2600K | ASUS Maximus IV GENE-Z | GTX Titan | Corsair DDR3-2133
  22. #22
    Feb 2008
    Will this fit the 275 or is that version on its way Gabe?
    "Overclocking is a Nerds way of sticking it to The Man,
    I'm no Nerd,
    but I love sticking it to The Man"
  23. #23
    Xtreme Cruncher
    Jul 2006
    Overland Park, KS
    im still wondering why there isnt or hasnt been any ati heatsinks like this. i would really go for a GPU only block, most likely a swiftech MCW60, when paired with a matching but separate full-cover passive heatsink. unless i missed that explanation somewhere else but im fairly certain ive kept up...
    for the glory of bardob!
  24. #24
    Dec 2005
    Quote Originally Posted by Freaky Freezer View Post
    I'd also like to know if this will fit the 275...very interested in this solution instead of another FC.
    Project Zero Eight
    CM Cosmos
    abit IP35 Pro - MCW30
    E8400 @ 4GHz (8x500) - Fuzion
    2GB Patriot 6400LL @ DDR1000
    8800GTS 640MB - EK FC8800
    D5, MCR320 & CW 22T
  25. #25
    Jun 2007
    Bloomington, IN
    Quote Originally Posted by brinox View Post
    It probably has something to do with the fact that ATI cards don't follow the reference design more than Nvidia cards so it much easier to have a product that fits the majority of cards for Nvidia where as for ATI it would be difficult.
