Results 1 to 25 of 78
Thread: [Project] Zero Eight
Threaded View
    Dec 2005
    [Project] Zero Eight - CM Cosmos
    Each January for the past three years I've started a new mod project. The past two, I've hacked and chopped my trusty old Lian-Li PC-6000, and beefed up the liquid cooling loop. This year's cooling upgrades would have pushed the space in the Lian-Li to the limit, so I've decided to move on to something new. I've dubbed this one "Project Zero Eight" as in '08 (I know, it's not very creative).
    The new victim is a Cooler Master Cosmos...here's the parts list:
    Bad Axe 2
    Xeon 3070
    8800GTS (G80)
    Cooled by:
    MCR320
    Fuzion (washered and nozzled)
    EK FC-8800
    EK NB-4 Intel
    D5
    The board and proc will be upgraded to an X38/48 and either a Yorkie or Wolfdale at some point this year. The short term goal is 4GHz 24x7 with the Conroe, which I know will be tough.
    Here's a question - should I add a 2x120 rad to the loop? I have a Coolingworks 22T that will come out of the Lian-Li when I break it down.
    So let's get started with the worklog...
    First order of business was to strip the case down and remove all the fans:
    Lots of plastic crap on this case...
    First mods:
    Lower drive tray plate removed (drilled out rivets):
    First cuts complete:
    Radiator test installation...
    I lined the vertical support panel I cut with door edge moulding, and re-riveted it down to the lower panel of the case towards the outside. Adding the rivets brought the rigidity of the case back to where it was before the panel was cut.
    Just enough space between the MCR320 and the power supply:
    The front most fan will blow air up into the upper hard drive bay, which is one flaw of this case in stock form. By the way, I run 1 drive right now, so three trays is plenty (will probably add another drive though).
    More to come during this week - I need to order some more parts from Petra's!
    01/09/2008 - Minor Update
    Tonight I made a mount for the upper radiator and fans. Initially I was going to go all out and fabricate a sheet metal plenum/adapter so that I could use the case's stock "spread bore" mounts for the fans and reduce it down for the radiator. However, due to height constraints inside the case, I didn't want to deal with potential clearance issues afterwards. So, I just did something simple instead...
    The material is .22" (5.58mm) thick acrylic.
    Here's the plate with the fan and case mounting holes drilled:
    Drawing intersecting lines to find the fan hole centers:
    First hole cut...
    Cuts complete and coating removed. Still need to sand all the edges smooth and grind out screw reliefs on the sides for two of the case's side bezel screws.
    Test placement on top. All the holes line up! The lines drawn on the case represent the area that will be removed so the fans will fit in. I might be able to get away with leaving it in, but I'll probably just cut it out...
    Well, that's it for tonight. I'll probably post another small update tomorrow. I'm expecting some parts from a couple different vendors to arrive tomorrow for the work coming this weekend.
    01/23/2008 - Update
    It has been a while since I've been able to make any real progress on the project. Work is kicking my butt.
    Over the weekend I went out and picked up a new board and proc - a brand new E8400 and an abit IP35 Pro. You better believe I am itching to get this thing built and overclocked to see what she can do.
    Also switched out the NB block for an MCW30, so a few pieces have changed.
    Some pics of the CPU:
    That heatsink is wimpy...guess these are supposed to run cool...
    The first thing I did to the board was pull the stock cooling off...
    Prep for the NB block...
    NB block installed.
    I have a SB heatsink coming as well as another that I'll be carving up for use on the power regulation mosfets.
    Making a mounting bracket for the EK res...cut to length and marked the bend points.
    First bracket - came out perfect, but too deep by 1".
    Second try...just right - the res will be centered and in line with the fillport and pump...see below.
    Test placement...sweet.
    Top radiator plate has been clearanced for a couple panel screws and the fillport, all corners rounded and edges lightly chamfered with a Dremel.
    Pump placement, marked mounting location to drill holes for pump mount. This may eventually be soft mounted with Petra's gel stuff, but I'll save that for later.
    Fillport, Reservoir and Pump all centered and inline...
    Pump holes drilled, pump mounted. Upper rad mounted. Of course I broke the freaking upper res mounting bracket during this mock-up, so now I have to order a replacement. Yay.
    Fillport clearance. The fill tube to the reservoir clears the radiator to the left by about 1/4" or so, just right.
    That's all for now. I'm waiting for a few odds and ends to finish up the board's cooling mods, and I have a backplate coming for the FuZion too. I plan to finish the board pieces on Sunday, and will hopefully have the major components installed then as well. If all goes well, she should be fully functional by Feb 8-9 (I have to head into the office Saturday and will be out of commission late next week for a couple days, so not much time to work on it between now and then).
    Project Zero Eight
    CM Cosmos
    abit IP35 Pro - MCW30
    E8400 @ 4GHz (8x500) - Fuzion
    2GB Patriot 6400LL @ DDR1000
    8800GTS 640MB - EK FC8800
    D5, MCR320 & CW 22T
