Page 1 of 3 123 LastLast
Results 1 to 25 of 70
Thread: unlocking 4th core
    May 2006
    Philippines
    unlocking 4th core
    Does anyone know how to unlock the 4th core on a 720be on the Gigabyte GA-MA790FXT-UD5P motherboard!
    Feb 2006
    just put acc to auto?
    May 2006
    Philippines
    its on auto no luck!
    May 2006
    Philippines
    Sorted now just got new bios F3b works amazing
    Xtreme Cruncher
    Apr 2008
    Ohio
    Quote Originally Posted by bro20000 View Post
    is that on the website now?.. I can't get it to load at the moment.
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
    May 2007
    Here...
    Set ACC to "per core" and change value of all cores to +0%
    Proven...
    Mar 2007
    I just switched to F3b and now am running four cores 1hr OCCT stable at stock, so I am assuming the fourth core is just fine. I'll do some OC'ing later.
    Mine worked just fine by setting to "auto".
    Asus G73- i7-740QM, Mobility 5870, 6Gb DDR3-1333, OCZ Vertex II 90Gb
    Jan 2005
    Quote Originally Posted by keenan View Post
    Here...
    Proven...
    What is that driver installation screen all about? Do you install phenom drivers like we used to do with the Opteron 64?
    *CPU: Xeon X5650 @ 4.3 Ghz | Cooler: Thermaltake Water 2.0 Extreme
    *Asus Rampage III Formula | RAM: 36GB DDR3 (Tracer LED + Hyper X Savage)
    *Video Cards: Gigabyte Aorus 1080ti
    Sound Card: Sound Blaster Z | PSU: Corsair HX1000W | Display: BenQ PD3200u | JVC RS520 projector
    *Case: CoolerMaster HAF X (932 side panel) | Others: Roccat Kone AIMO | Roccat Alumic | Logitech G15 |Cameras: Sony A7R3 | RX100 V
    May 2007
    Just windows 7 installing the forth core...
    Intel Core i5 750 @ 4.3Ghz H2O
    Gigabyte P55M-UD2
    Sapphire HD4890 Vapor-X @ 950/4800
    2 x 2GB Ripjaw PC16000 @ 9-9-9-24-1T
    2 x 250 WD Raid
    OCZ StealthXtreme 600W
    Jan 2005
    Have you tried Vista 64 or XP compared to Windows 7 and if so, did you notice any of them been better at OCing?
    Mar 2007
    Just wondering, does OCCT show the fourth core for you guys? Both task manager and CPU-Z show fourth core but OCCT does not...
    Xtreme Mentor
    May 2008
    cleveland ohio
    on a side note I read techpowerup says 4mb can go to 6mb with ACC turned on, and some bios on X4 m3 chips with less cache.
    64 bit will probably bsod before getting into windows.
    HAVE NO FEAR!
    "AMD fallen angel"
    Quote Originally Posted by Gamekiller View Post
    You didn't get the memo? 1 hour 'Fugger time' is equal to 12 hours of regular time.
    May 2007
    Quote Originally Posted by iandh View Post
    Try reinstalling it... I guess this is just the down side of unlock the 4th core, but all my temp reading are at 0'C
    Any 64bit OS has less OC headroom, I can get 3.8Ghz 3Dmark06 stable, tested 3.6Ghz prome so far, stable with 1.45V
    Havent even started playing with the NB...
    Gigabyte P55M-UD2
    2 x 250 WD Raid
    Jan 2005
    On my HTPC set up both Vista 64 and Xp SP3 OCed to the same max thought.
    I am going to try both on my phenom as well and perhaps give Windows 7 a try as well.
    Regards
    May 2007
    Try Windows 7048, great performance increase over 7000
    Gigabyte P55M-UD2
    2 x 250 WD Raid
    Apr 2004
    Socal
    Hmmm...I thought some of the cores weren't stable (the locked ones)
    ASUS Maximus VI Hero
    Intel 4770K Delidded @ 4.7GHz
    Swiftech DDC w/Petras Top
    EK Supremacy Direct to Die/MCW80 GPU
    XSPC 120.4
    2x8GB G.Skill
    MSI 6950 2GB 975/1400
    Samsung 830 2x128GB RAID0/WD 2x3TB RAID1
    Corsair 800D with AX850W PSU
    Dell U3011 30" LCD
    D.F.I Pimp Daddy
    Jan 2007
    Still Lost At The Dead Show Parking Lot
    why are you guys so hell bent on doing this? Obviously its been disabled for a very good reason
    SuperMicro X8SAX
    Xeon 5620
    12GB - Crucial ECC DDR3 1333
    Intel 520 180GB Cherryville
    Areca 1231ML ~ 2~ 250GB Seagate ES.2 ~ Raid 0 ~ 4~ Hitachi 5K3000 2TB ~ Raid 6 ~
  18. #18
    Xtreme Guru
    Jan 2005
    waukegan
    the spirit of overclocking is essentially get the cheapest crap and o/c the hell out of it .... or so i thought?
    so ontop of o/cing the hell out of it, we're also unlocking extra cpus like ppl did with 6200 nvidia cards to get 6600 performance ( 4 to 8 shaders )
    mobo: strix b350f
    gpu: rx580 1366/2000
    cpu: ryzen 1700 @ 3.8ghz
    ram: 32 gb gskill 2400 @ 3000
    psu: coarsair 1kw
    hdd's: samsung 500gb ssd 1tb & 3tb hdd
  19. #19
    D.F.I Pimp Daddy
    Jan 2007
    Quote Originally Posted by i found nemo View Post
    Yes but Even "Cheap Crap" as you put it does not have a Performance level when its Broke
    SuperMicro X8SAX
    Xeon 5620
  20. #20
    Xtreme Cruncher
    Apr 2008
    Ohio
    3.9ghz 2600nb 3d stable 4 cores
    Finally got the validation to work. I would say this 4th core is a fully functional one I tried the f4g bios on this MA790FXT-UD5P but 4 cores not possible for me. F3B works like a charm.
    ~1~
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ~2~
    Asus Prime X399-A
    AMD RX 5700 XT
  21. #21
    D.F.I Pimp Daddy
    Jan 2007
    Just so you guys Know....AMD has made request to Mobo Makers to remove that feature capability from Bios.
    SuperMicro X8SAX
    Xeon 5620
  22. #22
    Mar 2007
    Quote Originally Posted by Brother Esau View Post
    I am not hell bent, I just spent about 30 seconds updating the bios, another 30 seconds changing ACC to "auto", and another 30 seconds starting OCCT.
    I've had this mobo/cpu for weeks and this is the first time I've made an attempt to unlock it. I purchased them together on release day before unlocking was even known. I did this just out of sheer curiousity.
    It looks so far that I got one of the good chips that just has a disabled core to be sold as an X3, which is further confirmed by how many have had luck with 0904's.
    If I have a good fourth core that I can enable with little to no effort and no negative consequence, can you give me a good reason why I should not enable it?
    Obviously that didn't matter to Gigabyte because yesterday they just added bios F3b "Update ACC code for Phenom X3 CPU" that enables unlocking.
    edit: Also, nobody ever seemed to be upset about people unlocking geforce 6800's via bios mod, how is this any different?
  23. #23
    Sep 2007
    Ditto. Have 4x @3.2GHz stable.
    AMD FX-8350, Gigabyte 990XA-UD3
    8Gb Kingston HyperX Blu DDR3 1600,
    ASUS GTX670, 120Gb Samsung 840 SSD
    Corsair HX520, Antec P182, Noctua fans, Scythe Shurikan
  24. #24
    Mar 2007
    Quote Originally Posted by mnemonix View Post
    Nice little bonus isn't it!
    Do you know your stepping?
  25. #25
    D.F.I Pimp Daddy
    Jan 2007
    Relax killer it was not a personal attack against you or anyone else in this thread! I am merely stating the obvious
    SuperMicro X8SAX
    Xeon 5620
