Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Can't Boot Completely With 2nd Physx Card Installed
    Nov 2003
    NC, US
    Finally got a chance to install my GTX295 with a 9600 gso to handle (some what) physx. Only problem is once I install the 9600 I can't completely boot into Vista. I can get to the loading screen (where the green bar is) but then the screen goes to a bluish color and computer either restarts or just sits at the same screen.
    If I take out the 9600 then I can boot into Vista fine. If I take out the 295 and just install the 9600, I can boot into Vista.
    How I got to this point? I setup a New install of vista 64 with the 9600. Dl 181drivers and changed out the cards adding both the 295 and 9600. Restarted Vista found both cards then installed the drivers. Restarted and could not boot into Vista. Then I tried hooking the monitor side analog to 9600 and dvi to 295 after a restart and still can't boot.
    Later took out the 9600 and dl and install the 9.09 update as a last effort. PSU BFG ES-800 rest in sig.
    Any ideas?
    Nov 2003
    NC, US
    Tried again:
    Took the 9600 out and booted into vista and uninstalled the 181drivers. Installed the 9600 and booted back into vista fine. Reinstalled the 181 drivers and restarted. Once restarted I got to the same Vista loading screen with the Knight Rider bar, fans on both cards spun down to normal. After that back to the black/ bluish screen and can't boot into Vista.
    Nvidia driver problem?
    P5Q Pro; Q6600@3.6mhz; 4GB Corsair 8500; GTX 295 w/9600 GSO
    Xtreme Mentor
    Feb 2007
    Oxford, England
    would guess drivers as 295 is a very new product and I think theres 1 beta and 2 drivers that actually support it, my guess would be emailing nvidia support and see if they can offer any help :/
    "Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
    //James
    Nov 2003
    NC, US
    I found a few people that seem to have the same problem, then other say it work perfect since day one. odd I'll send an email and see what they have to say.
    Did this work for anyone else?
    Aug 2008
    Edmonton, Canada
    Quote Originally Posted by Blazemore View Post
    Well I should have my system running sometime this week LOL just waiting on the damn 920 to get here and then ill tell ya if i have a problem or not.
    have you tried a clean install of vista?
    MOBO------Ramage 2 Extreme 1406
    CPU--------I7 965 (4.5Ghz)
    RAM--------Corsair XMS3 Dominator GT 1800mhz
    GPU--------Evga GTX285
    PHYS-------Evga 9800GT
    SOUND-----X-Fi Titanium Fatal1ty Champion
    HDD--------G.Skill SSD 64gb...Raptor X 150gb
    PWD--------X3 1000w Ultra
    Wet Stuff---Loop 1 EK Supreme...Loop 2 EK X58 mosfets, EK R2E SB/NB
    Nov 2003
    NC, US
    Quote Originally Posted by funk32 View Post
    Yes this was on a clean install of Vista 64. I tried again by uninstalling the drivers then booting into safe mode and using driver sweeper a couple of times. Then installed the latest 181 and the new Physx 9.0 something other drivers.
    Reboot installed the 9600 and this time I booted into Vista but under analog only using the 9600 outputs. The GTX295 monitor outputs would not work. Checked to see if the 181 drivers were installed and they were not according to Vista. So restarted and back to the same blank screen as before.
    Took out the 9600 out and booted in Vista not problems. So the drivers must be the problem.
    Apr 2008
    Down Under
    What PSU are u running? NM. Sporry your got a BFG 800Watt, thats more than enough.
    One more thing, does the 96xx support Physx, i thought only 88xx, 98xx, 26x and over do.
    2700K+H80 - EVGA GTX680 2GB - GIGABYTE G.1 SNIPER M3 Z77 - CORSAIR F3 120GB SSD - CORSAIR AX-850+MMOD BLUE/BLK - CORSAIR VENGENCE BLUE 1600MHZ -
    LIAN LI PC-60FNWX - CORSAIR SP2500S - DELL U2711 - CORSAIR M60 - FILCO MJ2 TKL BROWN
    Aug 2008
    Edmonton, Canada
    Quote Originally Posted by Bertross View Post
    yes the 9600 does support Physx... i was sure anything after the 8800's could do physx
    Apr 2008
    Down Under
    Yeah cool i wasnt sure if a 96xx card could. Anyway all cleared ta.
    May 2006
    Estonia
    Finally got a chance to install my GTX295 with a 9600 gso to handle (some what) physx....
    Got BFG-295 recently. Only HDMI for TV there (and it's not usefull anyway, since not working in multi-gpu mode).
    Exactly same thoughts came to my mind, when I was forced to have a second card for s-video TV-out (as my old TV does not have HDMI at all). Bought Sparkle 9600GSO for TV out and dedicated physx.
    Guess what? I went to sleep at 4am last night. Exactly same problem!
    Started from old Win XP/32 SP3 setup which served me well through couple years - I was blue screened right after adding GSO and setting up drivers for it.
    Formatted XP partition, clean reinstall of XP/32 SP3. All updates. Drivers. Reboot. Oopsie, same problem.
    Then (lucky me, have an MSDN subscription) I tried Win2003 Server (and then - Enterprise) 32 bit with all latest updates: no luck. In Win2K3 there was no blue screen, it was black - and no reboot done automatically at all.
    Put the Vista64 for download at early morning, just to find out your post on this forum.. Jeez... It seem it will not help there too...
    My setup:
    PSU: Chieftech 1000 Wt (tried it with 3 * 280 at my friend's PC)
    MB: Asus P5B Deluxe WiFi/AP (16x PCI-E #1 + 4x PCI-E #2)
    RAM: A-Data 1066+ (2 * 2 GB @ 400Mhz)
    CPU: C2D 6850 @ 3.6Ghz (9 * 400)
    ps. gonna try 9500 GT tonight .. maybe it's only GSO related?
    i7 920@3.8, 6GB @ 1540, 2 * 295@630, P6T, 1Kwt, 24" LCD.
    May 2006
    Estonia
    I found a few people that seem to have the same problem, then other say it work perfect since day one. odd I'll send an email and see what they have to say...
    If you can - please collect an information about "faulty" and "allrighty" systems they have. My guess, it can be related even with motherboard model... (me and you both have intel chipset, thought yours is newer than mine).
    ps. I had 260 + 8800GTS-512 in my system before 295, worked fine (8800 for physx). But 8800 moved to my office pc for.. mmm... work, I guess And 260 is already sold, so I cant try config like 295 + 260 or 295 + 8800 at the moment. Thought, I might bring 8800 (and one 9500 GT) from office tonight.
    Nov 2003
    NC, US
    Quote Originally Posted by yury2808 View Post
    Glad to see I'm not the only one (if thats a good thing). See you made it over to the Nvidia forums, there was a couple of people there that said it does work and their using it right now. I can't seem to find the post thou.
    May 2006
    Estonia
    I've got one lucky on russian (ixbt) forum, who confirm that his system works fine too, and he have... drumms... 975 chipset on mobo. SLI certified by nVidia.
    Same way, as you can see in funk32 signature couple messages above in this thread: X58, 295 + 9800...
    I've got "strange" feeling about it Drivers seem to fail on non-SLI motherboards, while works fine on SLI-capable, eventhought you don't build SLI between different cards, but having SLI-like dual GPU one already...
    Nov 2003
    NC, US
    I did notice once I install the drivers and 9600 the p5q does a restart, like I changed the bios systems or something. Yeah our luck your right about the non-sli boards not working. Really the only true reason why I even got the 295 and if physx ever really takes off.
    Nvidia wants me to submit some info and we will see what they have to say.
    May 2006
    Estonia
    The worst thing about it is that we are not using that second card in SLI mode at all... For me, it was just a chance to get s-video out (well, physx nice, thought).
    But now, I'm forced to get ATI card to handle it, LOL. Too good I'm mainly at XP/W2K3, so I can use mixed-vendor cards at all, not like in Vista
    May 2006
    Estonia
    Update: thanx to nVidia, I had to dump the fresh 9600GSO and buy ATI 3850 as secondary for my TV out. Works nice. No PhysX on dedicated card, thought, but I'll definetely live with 295 for it.
    Nov 2003
    NC, US
    Nvidia Reply:
    Your case is being escalated to our Level 2 Tech Support group. The Level 2 agents will review the case notes. As this process may take some time we ask that you be patient and a Level 2 tech will contact you as soon they can to help resolve your issue.
    Best regards,
    XOXO
    NVIDIA Customer Care
    Bad part is now I'm having problems with the 295. This card runs hotter then I have imaged. I'm getting lock-ups after an 1-2 hours of gaming in Quake Wars with everything maxed at 1680. Temps reach and hang around 80-85c with the fan on auto and no o/c. I've read where others can reach higher temps and no problems but there are a few that once their temps reach this area problem lockups start happening.
    Rest of the temps look good...q6600 @ 55-60c
  18. #18
    Mar 2008
    UK
    Is it not possible to dedicate one GPU from a dual gpu card to physx then?
    I have two of them, i would rather use 3 gpu's for rendering and one for physx if possible, or do i have to dedicated the whole second card to it?
    TJ07 | Corsair HX1000W | Gigabyte EX58 Extreme | i7 930 @ 4ghz | Ek Supreme | Thermochill PA 120.3 | Laing DDC 12v w/ mod plexi top | 3x2gb Corsair 1600mhz | GTX 680 | Raid 0 300gb Velociraptor x 2 | Razer Lachesis & Lycosa | Win7 HP x64 | fluffy dice.
  19. #19
    Nov 2003
    NC, US
    nm read post wrong
  20. #20
    Apr 2005
    Houston, TX
    PhysX works fine in my rig, see sig.
    C2Q Q9550 @ 4.03Ghz/4GB OCZ DDR 1066 @ 902Mhz /BFG GTX 260/Gigabyte GA-EP45-UD3P/2 X Samsung F1 1TB/Samsung F1 750GB/Samsung SH-S223Q/Corsair TX650/X-Fi Titanium Fata1ity/Swiftech H20-220/Logitech Z5300 Speakers/Samsung SyncMaster 2253BW Monitor/Win 7 Ultimate x64
  21. #21
    Nov 2003
    NC, US
    Quote Originally Posted by Major_A View Post
    True but you don't have a 295
  22. #22
    Apr 2005
    Houston, TX
    Did you update to the latest beta drivers posted yesterday?
  23. #23
    Nov 2003
    NC, US
    I did but haven't tried to install the 9600. Trying to figure if cooling was the problem with the 295 as said in above post.
    Off topic: did set the fan to 65 and after and hour of Quake Wars maxed out, the temps got to 80-85c for both cores. Didn't lock thou.
  24. #24
    Feb 2008
    uk , bristol
    did you try connecting the monitor dvi to the other gfx card to see if made any difference ? if you you dont ...try a secondary screen/ even a hdtv and see if that works .....do you need .net 2.0 framework installed by any chance.
  25. #25
    Nov 2003
    NC, US
    Different monitor configs didn't help once after the driver restart. Still haven't tried after installing the beta drivers thou.
