in my first thread here i almost completed my project but i was not satisfied with the result : the hot side cooling was insufficient, the temps were not that great and the case was way to heavy to move around. so i decided to go back to the drawing board and came up with what seems to me a better plan. most of the parts i kept from my initial buid, but have improved the cooling, looks and mobility. (for parts list refer to my older thread if you're interrested)
So here it goes: i bought 2 mid tower identical cases (cooler master centurion 590), i picked this model because of its size, (u'll see later on), simplistic looks, and because 2 cases one next to the other would look like a single case.
The i dea is to have a tec chiller in one case and the pc in the other.
The chiller case got stripped of all the unnecessary drive bays, etc, and some additional holes were drilled.
The new cooling harware: 3 360x120 aluminum koolance radiator with 9 schyte ultra kaze 1000 fans. so the total cooling is 3 360x120 rads with fa,s pushing, 1 360x120 rad with fans pulling and 1 240x120 rad in pull. pump is still d5, and the tec heat exchanger is from the previous build.
top
front
top
back
The chiller is almost assembled, as soon as i am done leak testing, i will install the psu, front panel and that's basically it. This build was harder then my first one because i tried to squeze in evrything tightly so plumbing and wiring was insanely hard. I will update with results and any input is very welcome.
This unit is independent of the pc case (apart from a relay to have psus working in sync) and has quick disconnect valves for the cold side loop. so it is much easyer to move aroundthen my firs build, looks better, and working in the pc case became easyer (because i upgrade often it was one of my main concerns)
