Results 1 to 25 of 76
Thread: DFI X58 - i7 920 max bclk on AIR = 230Bclk
Threaded View
    Memory Addict
    Aug 2002
    Brisbane, Australia
    Talking DFI X58 - i7 920 max bclk on AIR = 230Bclk NOW 233Bclk
    Max 230Mhz BCLK
    I had all but given up after I found my initial max Bclk 32M Pi stable BCLK of 220Mhz with tight 878mhz 7-7-7-17 timings.
    But I'd like to thank Hazzan (233BCLK) and Solarfall (230BCLK) for their inspiration with their DFI UT X58-T3EH8 max BCLK attempts as this prompted me to keep working at it
    After numerous bios reboots and trying looser timings and a few voltage combinations, I finally surpassed my previous max memtest86+ v2.11 bootable BCLK of 224, moving all the way up to 230-231 memtest bootable.
    Enough for a quick boot into windows for a CPUZ Validation at least
    System specs
    • Intel Core i7 920 3836A756
    • Thermalright Ultra 120 Extreme + LGA1366 Bolt Thru kit + 2x 120x38mm Scythe UltraKaze 2000rpm 87cfm fans in push/pull
    • DFI LP UT X58-T3EH8 R.A51 - 01/06 beta bios
    • 128MB Gainward FX5200 PCI
    • 2x1GB Corsair DDR3-2133C9DF Dominator
    • Ram cooling: 3x 60x25mm Sunon 23.5cfm Maglev fans
    • 750GB Samsung HD753LJ
    • Pioneer DVD-RW
    • 1KW Corsair HX1000 psu
    • WinXP Pro SP3 full nLite updated hotfixes
    01/06 Beta Bios settings used:
    Code:
    Genie BIOS Setting
    CPU Feature
    Set VR Current Limit Max: Disabled
    Thermal Management Control: Disabled
    EIST Function: Disabled
    CxE Function: Disabled
    Execute Disable Bit: Disabled
    Virtualization Technology: Disabled
    TDC Enable: Disabled
    x TDC Limit: 0
    TDP Enable: Disabled
    x TDP Limit: 0
    ***** Logical Processor Setting *****
    Intel HT Technology: Enabled
    Active Processor Cores: All
    DRAM Timing
    Memory Control Setting: AUTO
    Memory LowGap: 1024M
    DRAM Command Rate: AUTO
    CAS Latency Time (tCL): 9
    RAS# to CAS# Delay (tRCD): 9
    RAS# Precharge (tRP): 9
    Precharge Delay (tRAS): 24
    REF to ACT Delay (tRFC): 88
    Write to PRE Delay (tWR): AUTO
    Rank Write to Read (tWTR): 16
    ACT to ACT Delay (tRRD): 6
    Row Cycle Time (tRC): 31
    Read CAS# Precharge (tRTP): 6
    Four ACT WIN Time (tFAW): 31
    Voltage Setting
    O.C. Shut Down Free: Enable O.C.S.D.F
    CPU VID Control: 1.350v
    CPU VID Special Add Limit: Enabled
    CPU VID Special Add: Auto
    Vcore Droop Control: Enabled
    DRAM Bus Voltage: 1.875v
    DRAM PWM Switch Frequency: Nominal
    DRAM PWM Phase Control: 2 Phase Operation
    CPU VTT Special Add: +0.0750v
    CPU VTT Voltage: 1.53v
    VTT PWM Switch Frequency: Nominal
    VTT PWM Phase Control: 2 Phase Operation
    CPU PLL Voltage: 1.80v
    IOH/ICH 1.1V Voltage: 1.27v
    IOH Analog Voltage: 1.25v
    ICH 1.5 Voltage: 1.7v
    ICH 1.05V Voltage: 1.05v
    DIMM 1/2 DQ/DQSTB Bus VREF: -00.0%
    DIMM 3/4 DQ/DQSTB Bus VREF: -00.0%
    DIMM 5/6 DQ/DQSTB Bus VREF: -00.0%
    ADDR/CMD VREF Control: Disabled
    x DIMM 1/2 ADDR/CMD Bus VREF: 110
    x DIMM 3/4 ADDR/CMD Bus VREF: 110
    x DIMM 5/6 ADDR/CMD Bus VREF: 110
    CPU QPI Drive Strength: Normal
    IOH QPI Drive Strength: Normal
    Exit Setup Shut down: Mode 2
    O.C. Fail Retry Counter: Enabled
    O.C. Fail CMOS Reload: Disabled
    PPM Function: Enabled
    Turbo Mode Function: Disabled
    1 core Max Turbo Ratio: 22x
    2 core Max Turbo Ratio: 21x
    3 core Max Turbo Ratio: 21x
    4 core Max Turbo Ratio: 21x
    CPU Non-Turbo Clock Ratio: 17x
    * BCLK/UCLK/QPI Controller Settings *
    QPI Control Settings: Enabled
    QPI Link Fast Mode: Enabled
    QPI Frequency: AUTO
    CPU Base Clock (BCLK): 231 Mhz
    Boot Up CPU Base Clock: AUTO
    PCIE Clock: 103 Mhz
    DRAM Frequency: 6x
    UnCore Frequency: 12x (optimal to keep Uncore at 2x DRAM Frequency)
    CPU Spread Spectrum: Disabled
    Settings highlighted in bold were what I played with to reach 230 BCLK.
Tags for this Thread
