HD4870x2 CrossfireX with i7 920 still on TRUE120 air cooling
System specs
- Intel Core i7 920 3836A756
- Thermalright Ultra 120 Extreme + LGA1366 Bolt Thru kit + 2x 120x38mm Scythe UltraKaze 2000rpm 87cfm fans in push/pull
- DFI LP UT X58-T3EH8 R.A51 - 01/06 beta bios
- HIS HD4870x2 + Gigabyte HD4870x2 both flashed to Asus TOP bios - CAT 8.12 Official Drivers
- 3x1GB Samsung HCF0 based - 2x1GB Corsair DDR3-2133C9DF Dominator + 1GB G.Skill PC3-12800HZ
- Ram cooling: 3x 60x25mm Sunon 23.5cfm Maglev fans
- 750GB Samsung HD753LJ
- 4x32GB OCZ Core V1 SSD Raid 0 + Highpoint RR3520LF PCI-E Raid controller 256MB Cache
- Pioneer DVD-RW
- 1KW Corsair HX1000 psu
- Vista Ultimate SP2 Beta 64bit vLite'd
While my HIS HD4870x2 can do 850-860Mhz on GPU, my Gigabyte HD4870x2 hits a wall at <840Mhz, so settled for 837Mhz on GPU in CrossfireX. Weird GPUZ v0.31 isn't registering my ATI CCC set GPU/MEM clocks ??
System peak wattage draw = ~915 watts! (probably need a beefier psu ? )
- 3dmark06 @837/985 = 29,412
- 3dmark05 @837/995 = 37,175
- 3dmark2003 @837/1000 = 127,708 <- some reason I haven't been able to publish 3dmark2003 results with HD4870x2 lately ??
- 3dmark vantage = unable to bench keep getting create pixel shader failed message in cpu tests even at stock cpu/gpu settings ? Vista SP2 Beta 64bit related ?
