Like the post says, im switching over from intel ( spec in sig ) I was gonna go i7 but the dang DDR3 is way too much. So what I would like to do is take the 940 to 3.8ghz for 24/7 use at least! I would really like 4.0ghz 24/7 use on air. Right now I have the tuniq 120. I wont go water till a good cheap system can be had for $150.
Ok now the board that I need has to be a really good overclocker. The cheaper the better but as u can tell from my DFI LP UT P35 I can spend a bit extra.
Suggestions need really fast gonna make a purchase by Friday Jan. 9th or go to microcenter depending on the board you guys suggest.
