Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 122
Thread: Phenom II 920 goodness thread
    Jun 2008
    Well...after realizing I was problay crapping all over the "official" Phenom II OC thread I started my own so I can post up on what seems to be a pretty good chip. I'm sure the 940 is going to be great but having this 920 for just a few hours now I can say its performance easily surpasses the 9950 that I have. Running smoothly at 3.22GHz on default vcore is nice.
    I will start filling some more benches later. Just passed a nice 3d06 at 18k, This is about 500 points less than my 9950 ran with crossfireX at 3.5Ghz(4870x2+4870). This is a single card run(4870x2). It "feels" faster...
    Jun 2008
    well...20 minutes plus of Prime95....its running in the back while I post this...snapped a screenie..opened paint...downloaded to my host...and posting here. Im impressed.
    Jun 2008
    Edinburgh
    Do you really think that this results are amazing? The oc potential of deneb core is much higher, try to reach 3.5GHz and more .
    MPOWER|i5 3570K|TRUE Spirit 140|2x4GB+2x2GB|VTX3D 280X|SanDisk Extreme 120GB|HX520W|Arc Midi|G2222HDL|G400s+QcK|Xonar DGX
    F1A75-V EVO|3870K|Venomous X|2x4GB|5830+DeepCool V400|F4EG 2TB|Solid 3 120GB|Silencer MKIII 500W|NZXT Source 210 Elite|IPS226V|Xonar DG
    Overclock yourself, you must!!!
    Jun 2008
    Not amazing...impressive...two different things. For just having the chip for a few hours I can say that this compares well to what ive seen from the 940. Some are running 1.45v+ to reach near 3.7ghz. I have a feeling that is within this chips reach. Im sure if my MB can reach close to 300 HT multi then it will be amazing.
    I guess whats really doing it for me is the fact that I still have Prime running and Im able to still use the computer as if nothing was going on. Over 1 hour now, my 9950 would be having fits.
    Sep 2007
    Munich, DE
    Quote Originally Posted by zif33rs View Post
    He He what cooling do you use?
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    Quote Originally Posted by Stuen4y View Post
    i think that that looks awesome considering that its a locked multi chip, i may have to go p2 when the full am3 ddr3 chips are out
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Xtreme Cruncher
    Jun 2006
    I think the OP is referring to temps at those clocks and voltage needed(stock).It's a nice score for a locked chip,gaining over 400Mhz on stock vcore and staying very cool is pretty impressive.No doubt phenom II 920s will go a lot higher(think 3.6-3.8Ghz on good air cooling),but for a fist "quickie" run ,this is a very good result! Compared to 9950 it uses around 2x less power and is substantially cooler at the stock and OCed frequency while running around 10%(average) faster per clock than Agena.
    Jul 2007
    SF bay area, CA
    i dont see the point of the 920 for acing the 940 black should retail for $75-100 more ($300-330 or so or less) and it looks like it will be worth every penny
    if u can oc like that then use a higher multi it would be 2x amazeing
    Jun 2008
    Now this...this is really amazing...
    still at default on all voltages. and Justapost im on water
    Apr 2008
    Lansing, MI / London / Stinkaypore
    Actually, 4.0 is doable on water regardless of chip I think. :P
    Quote Originally Posted by radaja View Post
    so are they launching BD soon or a comic book?
    Jun 2008
    ok..4.0 it is.. :P I need to sleep though..been fun for now...leave you with 3dmark 06 at 3.5ghz. Needed to add alittle vcore though. Crashed the first time at default...added .5v to vcore and .2v to memory and got this. Have alot of tweaking to do. I havent messed with memory timings or anything at this point. 20k+ should be a snap. On a side note..ORB isnt letting me make these public...imagine that.
    gnight all.
    zif
    Mar 2007
    Uh niice Go for more
    May 2005
    nice that would also be possible on decent air, we already see in europe some 200eur range for this 920, will replace my 9850be real soon.... just a few more days.
    Quote Originally Posted by Movieman View Post
    Fanboyitis..
    Comes in two variations and both deadly.
    There's the green strain and the blue strain on CPU.. There's the red strain and the green strain on GPU..
    Jul 2005
    Norway
    Very nice zif33rs!
    Thanks for sharing.
    3DMarknn - 79506/96025/33499/25592
    Dec 2007
    I'm pretty sure the 920 model will be at least @ 3.7-8 Ghz for 24/7 with good voltages(<1.5v). The 940 will be around 4 easily....
    Cpu:Phenom ΙΙ 965 c3 @ 4.1Ghz/2.8nb (air cooled)
    Mobo: Asus M3a79-T Deluxe
    Ram:A-data 2x2 800+ @ 1000
    Gpu:Asus Hd4850 512mb @ 700/1050(sycthe Musashi)
    Hdd:500gb Seagate 7200.11
    Psu:Corsair Hx620
    Cooling: TRue(dual fan)
    Case: Coolermaster Haf 932...
    Jun 2008
    at 3.65ghz, 2600mhz NB 1.45vcore, 1.4v NB
    Xtreme Cruncher
    Apr 2008
    Ohio
    What ram you using, You should be able to tighten the timings a lil, and I believe you can extrack a better score then that aswell
    Edit, I was going to say get that NB up and well You post fast lol...nice job
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
  18. #18
    Jun 2008
    Nice work ziffers but I think you've still got more room left for core clocking.
    Why didn't you keep the hypertransport matching the nb?
    From what I've seen so far it shouldn't stop clocking on air or water just Dice and such cold things.
  19. #19
    Jun 2006
    Looks like at 3.6Ghz is almost able to catch up with the Q6600 @ 3.2Ghz, good one for AMD
  20. #20
    Dec 2008
    Sweden
    Quote Originally Posted by Demo View Post
    Sigh... http://www.xtremesystems.org/forums/...&postcount=269
    Clearly the Q6600@3,2GHz is not beating the Phenom II@3,6GHz when the Phenom II is equal or better than Kentsfield both at 3,7GHz.
  21. #21
    Jun 2008
    20k+ at 3dmark06 @charged using Kingston HyperX DDR2 6400 I have 3 other sets of ram waiting to test...some OCZ 533 and some G. Skill and Patriot LL 400's
  22. #22
    Jun 2008
    I'm assuming he meant in super pi.
    What type is the G. Skill if it's pi black you should be able to get pretty tight timings.
  23. #23
    Xtreme Mentor
    Nov 2005
    Devon
    Good to see nice clocks from PhII 920!
    It looks like 2.5-2.7GHz NB will be a common thing with these.
    Am I right that you're running Vista x64 zif33rs?
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
  24. #24
    Jun 2006
    Quote Originally Posted by marten_larsson View Post
    http://www.xtremesystems.org/forums/...d.php?t=213200
  25. #25
    Dec 2002
    congrats man, looks awsome......looks like having a locked multi will still give others not getting the BE a great oc......thats awsome to hear
    AMD 1090T@4.0ghz
    Enzotech sapphire/Mo-Ra extreme rad
    Asus Crosshair IV Formula
    ht 2400mhz / nb 2400mhz
    12gb Gskill 1300mhz
    HIS HD5970
    Enermax Evo Galaxy 1250
    case: XCLIO A380PLUS-BK
    4.61ghz water
    4.5ghz superpi 1M 15.585
    http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
    25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
    21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
    Phenom 2 125w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=117414
    Phenom 2 140w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=109214
    Phenom 2 AM2+ 940 cold air results
    http://futuremark.yougamers.com/foru...ad.php?t=97430
    If I dont get every single drop out of my cpu I feel like someone is stealing from me
