I didn't dare put this in news, as it's just my inferences...It brings some stuff to the forefront though that I think others may have been curious about.
First of all, I found myself in the device ID database, in ATI's device ID's. There you will see some interesting registries for RD890 that are not included in RD790.
http://pci-ids.ucw.cz/read/PC/1002Originally Posted by PCI Device Registry
That's curious, isn't it? I wonder if RD890 will go the route of X58rev2 with a Lucid chip on-board with the ability to use it in single (ie 4870x2), 2x16, and 4x8 mode?
UPDATE: Read the Lucid Hydra .PDF and look at scenario 1.
I think it's safe to say RD8xx will have the option to have 2 card (4-gpu) MGPU SUPPORT MIXED AND MATCHED FROM ANY VENDOR. Hydra is an option or standard.
Then, as I was thinking about my curiosities about what the heck the optional "integrated clock generator" that's supposedly so great about SB800. We hear it gets better clocks from misc sources. WTF does that mean?
Well, the World Patent office says that AMD filed a patent for such 'techniques' on 11/27/08, a month ago...Curious.
It says on the front explaination:and includes this pic:Originally Posted by WIPO
dug a little deeper and read this in the detailed description:
Originally Posted by AMD clock gen description
I don't know about you, but that sound/looks like four different clocks meeting to create one signal by the CPU. Yes, It can be used to regulate power/heat surely ala CNQ, but I can't help but believe also independently controlled via Overdrive. Sure as heck also sounds like one of those cores could also very-well be a GPU core in the future by the way it's phrased (remember this clock generator tech being important for FUSION?). I can't help but wonder if this is also the cure for when you have a great cpu, but are held back on stability by, let's say, one core, or heat is limiting the clock so you could downclock another core. Dynamic clock vs threading management perhaps also in the user's hands?
Today's phrase is "quadrature clock signals".
Even if is just my mind wandering aimlessly on a Monday night, it certainly makes me more curious about AMD's coming AM3 platform. I'm going to keep trying to wrap my head around it, you can check it out here:
Here Be Dragons
SYNOPSIS: You can clock each core seperately to achieve whatever your goal is (heat/power/high clockspeed on less cores/)
Of course, I could always be waaaay off.
