Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 109
Thread: some first AMD Deneb teasers on Foxconn A79A-S 790FX
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    Hi,
    maybe it is good to start my own "teaser collection" on my good old Foxconn A79(A)-S and P05 Bios as I just passed 32m 210 HTT 3.9 gig on air.
    3.3 gig undervoltet and running wprime1024 (it passed but so you can see load temps)
    Wprime1024 with only +0.1V on 3.8gig quickly - time is not too bad I can tell you
    4 gig 32m without ACC and some voltage. So far I remark a good scaling.
    4 gig 1m 1.44V CPU
    235 HTT gained 0.5s compared to 20x200 with 1.800mhz nb
    To be continued
    DICE screenshots
    quick 32m here - it goes higher until 1.7V. for more LN2 would be good, this likes cold as hell. I am running against a wall around 5 gig but still awesome
    5 gig Validation DICE
    http://valid.canardpc.com/show_oc.php?id=464809
    LN2 Screenshots
    Validations are finally working!!!! TY CPUz-Support
    http://valid.canardpc.com/show_oc.php?id=466799
    bye,
    SoF
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
    Apr 2008
    Lansing, MI / London / Stinkaypore
    Hmm SoF, is 4Ghz @ 1.44V using ACC?
    Quote Originally Posted by radaja View Post
    so are they launching BD soon or a comic book?
    Jan 2005
    East Blue
    no all results are without ACC as it is not working yet (will not boot as soon as enabled in any way) hope a new bios will fix that
    Dec 2002
    4ghz amd, not everyday you see that.
    4670k 4.6ghz 1.22v watercooled CPU/GPU - Asus Z87-A - 290 1155mhz/1250mhz - Kingston Hyper Blu 8gb -crucial 128gb ssd - EyeFunity 5040x1050 120hz - CM atcs840 - Corsair 750w -sennheiser hd600 headphones - Asus essence stx - G400 and steelseries 6v2 -windows 8 Pro 64bit Best OS used - - 9500p 3dmark11 (one of the 26% that isnt confused on xtreme forums)
    Jan 2005
    East Blue
    finally I can raise HTT a bit up to 235 seems to gain some more performance from that specially in Pi.
    Dec 2007
    Hungary (EU)
    Quote Originally Posted by SoF View Post
    ACC is useless.... unfortunately.
    Xtreme Mentor
    Nov 2005
    Devon
    Thanks to SoF now we know that Phenom II @4GHz will do SuperPi 1M in less than 1 minute .
    Also we can certainly say that SuperPi 32M can be calculated in less than 1 hour on above mentioned CPU !!
    Do you have more teases coming shortly??
    RiG1: Ryzen 7 1700 @4.0GHz 1.39V, Asus X370 Prime, G.Skill RipJaws 2x8GB 3200MHz CL14 Samsung B-die, TuL Vega 56 Stock, Samsung SS805 100GB SLC SDD (OS Drive) + 512GB Evo 850 SSD (2nd OS Drive) + 3TB Seagate + 1TB Seagate, BeQuiet PowerZone 1000W
    RiG2: HTPC AMD A10-7850K APU, 2x8GB Kingstone HyperX 2400C12, AsRock FM2A88M Extreme4+, 128GB SSD + 640GB Samsung 7200, LG Blu-ray Recorder, Thermaltake BACH, Hiper 4M880 880W PSU
    SmartPhone Samsung Galaxy S7 EDGE
    XBONE paired with 55'' Samsung LED 3D TV
    Jun 2003
    nice sub 20 sec 1mb super pi
    looks like around 17-18 sec to be exact between the 20x200 and other setting
    My Heat
    gd-70\955\2x1gbhz1600
    ext-58\920\3x2gb998691
    Expert\170\2x1gbhz
    Apr 2007
    Quote Originally Posted by Oliverda View Post
    BIOS >
    i3 2100, MSI H61M-E33. 8GB G.Skill Ripjaws.
    MSI GTX 460 Twin Frozr II. 1TB Caviar Blue.
    Corsair HX 620, CM 690, Win 7 Ultimate 64bit.
    NooB MOD
    Jan 2006
    South Africa
    Hmmm, low HT walls or did you not test higher? If that's the wall it doesn't look good for locked multiplier chips but at the expected pricing it doesn't really matter
    Xtreme SUPERCOMPUTER
    Nov 1 - Nov 8 Join Now!
    Quote Originally Posted by Jowy Atreides View Post
    Intel is about to get athlon'd
    Athlon64 3700+ KACAE 0605APAW @ 3455MHz 314x11 1.92v/Vapochill || Core 2 Duo E8500 Q807 @ 6060MHz 638x9.5 1.95v LN2 @ -120'c || Athlon64 FX-55 CABCE 0516WPMW @ 3916MHz 261x15 1.802v/LN2 @ -40c || DFI LP UT CFX3200-DR || DFI LP UT NF4 SLI-DR || DFI LP UT NF4 Ultra D || Sapphire X1950XT || 2x256MB Kingston HyperX BH-5 @ 290MHz 2-2-2-5 3.94v || 2x256MB G.Skill TCCD @ 350MHz 3-4-4-8 3.1v || 2x256MB Kingston HyperX BH-5 @ 294MHz 2-2-2-5 3.94v
    Xtreme Enthusiast TheBlueChanell's Avatar
    Dec 2006
    Any possibility that 790GX is gonna be better for HTT overclocking, than the 790FX cause of the smaller process?
    And to any body's who's actually sat down and overclocked one of these, does the HTT work in a similar fashion as the X2's and Opty's, or is it similar to Phenom 1 where you can't do much in the way of HTT?
    Main: 900D - Prime 1000T - Asus Crosshair VI Extreme - R7 1700X @ 4.0ghz - RX Vega 64? - 32GB DDR4 3466 - 1TB 960 Pro -
    --- XSPC AX360 x3 - HK IV Pro - HK RX480 - HK 200 D5 - BP Compression ---
    HTPC: 250D - Prime 850T - Gigabyte G1 ITX - i7 6700K @ 4.5ghz - GTX 1080 Ti - 16GB 3200 - 1TB 960 Pro -
    --- ST30 x UT60 - Kyros HF - KryoGraphics 1080 - HK100 DDC - Monsoon Compression ---
    HV01: Define XL R2 - Prime 1200P - Asus Zenith Extreme - TR 1950X - RX580CF - 128GB DDR4 ECC - 512GB 960P - 4x 2TB RE
    HV02: Node 804 - Prime 850T - SuperMicro X1SSH - E3-1230 v6 - Vega FE - 64GB ECC - 512GB 960 Pro - 4x 6TB Gold -
    Sep 2008
    Romania
    Quote Originally Posted by Oj101 View Post
    +1
    SoF, can you please (if you have time) try to OC with HT only? It would be interesting how far you reach, I was planning on getting the locked 920...
    the state is universally evil, there is no good country only good people
    Jan 2005
    East Blue
    so far it maxes out ~240 htt. primed yesterday shortly (~30min) 3.6gig with 1.4V fine.
    Apr 2008
    Thank You SoF Have you been able to talk to any one over at Foxconn about getting us A79A-s user an bios update for Phenom 2 940 cpu . I have
    e-mail support and ask if there going to support the Phenom 2 940 cpu and they can not even tell me a yes or no answer .
    Phenom II 965 C3 @ 4 Mhz @1.4375v prime95 stable
    Asus CrossHair III Formula
    Cooler Master Aquagate Max cpu cooler
    Patriot AMD Black ED. ddr3-1333 OC 1600 8-8-8-20-28 (2x2GB)
    2600NB@1.350v 2200HT@1.206v
    2 Asus 5850s running in crossfire
    2 WD 320gig SATA-2 hard drives raid-0
    PC Power & Cooling 750w Silencer Crossfire ED.
    Asus DVD Burner
    Cooler Master HAF932 AMD Limited ED. case
    Acer 21.5" LCD 1920x1080P
    windows 7-64 bit
    Xtreme Cruncher
    Apr 2008
    Ohio
    My 790GX MA790GP-DS4H would max at 240 on my 9950, The M3A79-T Asus will go well above that..So maybe the locked chips still look promosing on the right bios/board..
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
    Oct 2005
    EvE-Online, Tranquility
    Pretty awesome regarding temps. What cooling was this on though? I mean... air cooling can still be anything
    Without ACC 4Ghz, very nice. Maybe PhII indeed doesnt benefit from ACC but looks like we'll have to wait a bit more to be sure.
    Synaptic Overflow
    CPU:
    -Intel Core i7 920 3841A522
    --CPU: 4200Mhz| Vcore: +120mV| Uncore: 3200Mhz| VTT: +100mV| Turbo: On| HT: Off
    ---CPU block: EK Supreme Acetal| Radiator: TCF X-Changer 480mm
    Motherboard:
    -Foxconn Bloodrage P06
    --Blck: 200Mhz| QPI: 3600Mhz
    Graphics:
    -Sapphire Radeon HD 4870X2
    --GPU: 750Mhz| GDDR: 900Mhz
    RAM:
    -3x 2GB Mushkin XP3-12800
    --Mhz: 800Mhz| Vdimm: 1.65V| Timings: 7-8-7-20-1T
    Storage:
    -3Ware 9650SE-2LP RAID controller
    --2x Western Digital 74GB Raptor RAID 0
    PSU:
    -Enermax Revolution 85+ 1250W
    OS:
    -Windows Vista Business x64
    ORDERED: Sapphire HD 5970 OC
    LOOKING FOR: 2x G.Skill Falcon II 128GB SSD, Windows 7
    Dec 2007
    Hungary (EU)
    Quote Originally Posted by charged3800z24 View Post
    http://valid.canardpc.com/show_oc.php?id=423653
  18. #18
    NooB MOD
    Jan 2006
    South Africa
    Quote Originally Posted by azraeel101 View Post
    +1
    There isn't a HUGE price difference, grab a 940 or 945 when it arrives
  19. #19
    Xtreme Cruncher
    Apr 2008
    Ohio
    Oh, ya,. i remember your post you were hitting higher HT reference then me on my 790GP. I just couldn't get more then 240 stable....
    ~1~
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ~2~
    Asus Prime X399-A
    AMD RX 5700 XT
  20. #20
    Nov 2007
    @SoF
    Why you don't upgrade your bios? your current aren't old?
    WAITING FOR SOMETHING...
    FULL LIQUID BY YBRIS
    Ybris A.C.S. FULL CHROME Limited Edition N°058 | Ybris A.C.S.-G FULL CHROME Limited Edition N°058 | SANSO PDH-054 12V A.F. | Feser Xchanger Q.R. 480 with Feser Xtender blue\Scythe Ultra Kaze 3000rpm | Tecnofront Bay Trap | Tygon R-3606 3\8" 1\2"
  21. #21
    Jan 2005
    East Blue
    Quote Originally Posted by merkk1 View Post
    i am waiting for some infos about the bios. they seem to already have something anyway p05 does fine with my one
  22. #22
    Sep 2008
    Romania
    Well I gotta get a motherboard for it too, I don't know if I'll afford the 940..
    The fact that I'm from Romania, a third world country where hardware is way overpriced doesn't help either...
  23. #23
    Jan 2005
    East Blue
    4050 1m - time is getting really good for AMD now with some more MHZ that could give a little surprise
  24. #24
    Xtreme Cruncher
    Apr 2008
    Ohio
    Can't see the pic, and no link to large..or not working..
    ~1~
    AMD Ryzen 9 3900X
    AMD Radeon VII
    ~2~
    Asus Prime X399-A
    AMD RX 5700 XT
  25. #25
    Xtreme Cruncher
    Jun 2006
    You are hinting at the increase in speed per clock that HTT overclocking is giving you ?
    When you increase HTT and leave northbridge multi at a fixed value,you increase NB/L3 clock speed and decrease the latency of a very large and already very effective L3 cache significantly .This is the source of the better results with higher HTT.NB clocks could be a not so secret "secret" weapon .If it can net even 5% over default,it will be awesome,but i guess it can be even better since this time it should even scale better than Agena in that respect.
