Om nom nom tastey!
Lol I have an awesome pic of my mates watercooling... Copper + aluminum + anti-corosive + 1 CPU @ 110c = YUCK!
I didn't build this or take any part in the purchase of his PC...
Block got clogged, CPU overheated, acrylic cracked because it got so hot - thankfully the corrosion was so bad it was too thick to seep out the block - instead, it was slowly growing from the inside-out! :P
Om nom nom. Might try and take the acrylic and copper apart and take some samples to see how thick it is under there! There's a bit bit floating about in the tubes (it's beside the rad header in that photo)
~Bex
- You may not post replies
- You may not edit your posts
Forum Rules
