Page 1 of 4 1234 LastLast
Results 1 to 25 of 98
Thread: Radiator Sandwich / Stacked Radiators / "SLI-Radiators" Test results
    Jul 2008
    Winterthur, Switzerland
    Lately, I've seen a lot of discussions about stacking two slim, low-cost radiators instead of using one thick, high-end radiator.
    Since high-end radiators like those made by Feser and Thermochill often cost more than twice of what slim, low-cost models cost, radiator-sandwiches could be an economically sound alternative.
    I had the chance to squeeze in some stacked-radiator testing. The emphasis here is on "squeeze in" since I'm really busy with several other testing projects. So forgive me if this isn't as elaborate as you might hope for.
    Test setup:
    In my test setup, I'm using some pretty low-end cooling, which has to do with an article that I built this setup for.
    - Q6600 @ 3.2 GHz with Nexxxos XP Waterblock
    - HD 4850 with EK FC Waterblock
    - XSPC X2O 400 Pump
    - Magicool Slim 360 radiators
    - three Nanoxia fans
    I ran this setup first with just one of the Magicool radiators and then with a radiator sandwich structured as Radiator -> Fans -> Radiator.
    Here are some impressions of the sandwich:
    Testing method:
    I run Furmark to load the GPU and Prime 95 to load the CPU for 45 minutes to warm up. Then I run it for another 20 minutes during wich I log all temperature data in five second intervals. The data of those 20 minutes is then averaged out to get the results.
    Since we're testing radiators here, the most relevant temperature difference is that of water-air.
    Here's the results:
    I tested once with 750rpm and once with 1400rpm. As we can see, the sandwich gains a good two to three Kelvin over the lone radiator. This also translates to lower CPU- and GPU-temperatures.
    As you can see, for the radiator sandwich it doesn't seem to matter what fanspeed is used. Since the T-Balancer, the device I use for temperature-logging has a resolution of only 0.5 degrees, we're certainly not seeing the whole picture here. But I guess we can say that stacked radiators are less sensitive to fan speeds than lone radiators nonetheless.
    As for flowrates, the additional radiator made them drop by 25% in my testing.
    Now, it remains to be seen how the radiator sandwich performs vs. a high-end radiator. I just so happens that I'm testing that as i write...
    Cheers,
    Shane
    EDIT:
    Temperature difference CPU-Ambient:
    Scenarios for further testing:
    In the meantime, a lot of interesting suggestions have come up. Here's a list of all of the ideas that should be tested. Please contribute! :-)
    - Two radiators separately vs. stacked radiators
    - Stacked radiators with a total of six fans
    - Stacked radiators with a total of nine fans? (Overkill?)
    - Stacked radiators vs. PA120.3 (testing in progress on this one)
    - Airflow going from first to second radiator vs. airflow going from second to first radiator (as discussed in posts 29-33)
    - Radiators stacked right on top of each other: Radiator -> Radiator -> Fans
    - Running stacked radiators in paralell
    May 2005
    Nice! The only problem i see is the physical dimensions of that sandwich.
    Jul 2008
    Thanks!
    Well, the dimensions are actually practically the same as with a thick radiator. With the sandwich you have 30mm deep radiators x2 plus 25mm fan = 85mm. Compared to that, a PA12.3 is 64mm deep plus 25mm fan = 89mm!
    Aug 2008
    Great info thanks!
    -sponge
    Banned
    Apr 2008
    Brisbane, Australia
    It would have been great if you could have done the 2 rads separate with their own fan to see how much of a performance hit the sandwich design is. This is the primary argument against such a set up.
    Jul 2007
    Canada
    Interesting. I would have expected the sandwich to yield proportionately larger benefits at 1400rpm fanspeeds, since the air wouldn't get as saturated with heat while passing through the first radiator.
    i7 2600K | ASUS Maximus IV GENE-Z | GTX Titan | Corsair DDR3-2133
    Aug 2005
    Very interesting. But those barbs!
    Fan speeds...why?????
    ASUS A8N32, FX-57, 6800GT's(SLI)
    PCP&C 1kw, Raptors, DDR600
    Jul 2008
    "Fan speeds... why?" What?
    I don't understand what you mean. Please clarify?
    The fittings are simply the only 90s that I have. But I can tell you that they have next to no impact on flowrates (less than three percentage points per fitting), so I don't see a real problem with using them.
    Aug 2008
    Nice. I was actually thinking about doing this with the BIP GTS and some heavy blowing fans but figured it would be cheaper/easier to purchase a BIP GTX.
    Intel 8700k
    16GB
    Asus z370 Prime
    1080 Ti
    x2 Samsung 850Evo 500GB
    x 1 500 Samsung 860Evo NVME
    Swiftech Apogee XL2
    Swiftech MCP35X x2
    Full Cover GPU blocks
    360 x1, 280 x1, 240 x1, 120 x1 Radiators
    Apr 2008
    Ottawa, Canada
    Quote Originally Posted by MomijiTMO View Post
    My thoughts exactly. Not exactly fair testing two rads against one alone. Doing a test with two rads separate and then 2 rads sandwiched is what I am looking for here.
    Banned
    Mar 2007
    French Quarter of Grinchville
    another vote for testing the sandwich vs 2 separate radiators to see if the design can work.
    Jul 2008
    Quote Originally Posted by Sadasius View Post
    I don't have the capacity or setup to test the two radiators seperately as well as sandwiched. I'm pretty confident that if they are used seperately, the two radiators do much better than when sandwiched.
    I just wanted to test from a perspective of limited space and finances. Since two radiators separately need lots more space as well as three additional fans it would again be "unfair" to compare them with the rad-sandwich...
    EDIT: If no one else steps up and does the testing, I might be able to fit it in at some later point. ;-)
    Jul 2006
    Usa
    I definitely appreciate your efforts toward this info, so--Thank You! I am contemplating the same basic concept for my dual car rad setup for this summer, and trying to determine if it would be beneficial, the best setup and plumbing or flow course.
    I agree completely, but personally the testing that you've done already offers some benefit to me. However, I think we already knew that 2 rads would beat one, so the value is limited.....
    My car rads are not in a pc (duh!), but the principles should be the same. Personally, I would appreciate any info that results from the configuration below:
    I am working on other things atm, but I have been giving this some thought and the air flow/water flow above--I believe--would produce the best results...for a sandwitched setup. I may be wrong though....
    If you would care to check out that setup.....You could save me some guesswork....
    Either way: Good Effort.....
    May 2008
    Ontario, Canada
    Thanks for doing this Looking forward to more from you
    Xtreme Enthusiast Shocker003's Avatar
    Jul 2007
    Germany
    It was nice of you trying this setup out. Please can you make out time to try Naja002´s idea, i know i once made a proposal about this configuration. The inlet/outlet rad and air direction will play an important role in this setup, in as much as another set of fan will reduce the temp too.
    MAIN RIG--:
    ASUS ROG Strix XG32VQ---:AMD Ryzen 7 5800X--Aquacomputer Cuplex Kryos NEXT--:ASUS Crosshair VIII HERO---
    32GB G-Skill AEGIS F4-3000C16S-8GISB --:MSI RADEON RX 6900 XT---:X-Fi Titanium HD modded
    Inter-Tech Coba Nitrox Nobility CN-800 NS 800W 80+ Silver--:Cyborg RAT 8--:Creative Sound BlasterX Vanguard K08
    Sep 2007
    Germany, Solingen
    @HESmelaugh
    I think you should really think about (better: test ) Naja002s proposal ...
    Unoriginal Macho Energy
    Dec 2002
    x100.. i mean, sure 2 work better than one, but without knowing how well (or dismal) the sandwich works vs the 2 rads separated is the only relevant test here. It's kinda like saying, 2 D5's has more pressure than one.
    Quote Originally Posted by HESmelaugh View Post
    Why not? Never know until you try.
    *:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*'``'*:-.,_,.-:*
    GTZ --> MCW-NBMAX --> EK FC --> PA 120.3 --> PA 160.1 --> 2x DDC Ultras in Series --> Custom Clear Res
    "Artificial intelligence is no match for natural stupidity."
    Quote Originally Posted by ranker View Post
    Did you just get hit in the head with a heavy object? Because obviously you're failing at reading comprehension.
  18. #18
    Jul 2008
    first, let me say that I really like all the feedback and input I'm getting here! XS sure appreciates it's testers.
    The reason I could only do such a brief test is that I'm currently working on quite an extensive series of testing that will illustrate how best to upgrade a LC setup. After that, I have another CPU-waterblock roundup scheduled and that will eat up a lot of my free time. After that, even more stuff is scheduled, though some of it less pressing.
    I only mention this to explain why I can't deliver the testing you asked for right away: I have only one test-rig and my days are, alas, limited to 24 hours each...
    Having said that, I will get a new bench-table type rig in a few weeks. It will allow lots of flexibility with radiators and make this kind of testing easier. So keep bringing the ideas for what should be tested and I will get to it ASAP.
  19. #19
    Aug 2008
    what about connecting radiators in parallel like car intercoolers. has anyone tried this?
  20. #20
    Xtreme Mentor
    Jul 2004
    Brooklyn, NY
    How does it compare to a single thick radiator like a TC 120.3 with three fans is another suggestion.
    Asus Rampage Formula X48
    Intel Q9650 @ 4.33GHZ
    OCZ Platinum DDR2-800
    Palit 4870x2
    Creative Xi-Fi Extreme Music
    Corsair HX1000
    LL 343B Case
    Thermochill 120.3
    2xMCP355
    KL 350AT
    KL 4870X2 FC WB
    DD Chipset Block
  21. #21
    Chasing After Diety
    Jan 2007
    Absolutely Speachless :O
    why not just paralell them too while your at it.
    And then throw them in a 400 mile wind tunnel to test efficiency.
    ROFL...
    This is why sometimes i keep quiet with my test.
    Great test tho!
    You just proved physics to be correct. :P
    But i would really try a paralell design over a serial and compare that.
    Lind: Dual Gainestown 3.07
    [12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
    Its my fault.. and no im not sorry about it either.
  22. #22
    Never go full retard
    Feb 2008
    Vegas
    Anyone have a spare MCR320 they would be willing to loan me for a comparison test? I already have one, just need #2 for a couple weeks as the other piece of bread in this sandwich.
    edit:
    Or a GTX480, but I figured a MCR320 would be easier.
  23. #23
    Jul 2008
    Quote Originally Posted by mcoffey View Post
    yeah,
    And regardless, I'd need to see what the CPU temps were before and after adjusted to ambiant differnece before the test is of any real use to me.
    And thanks for taking the time to test,
    andyc
    That I can offer:
    I've also finished the first test-run with a PA120.3. It looks like the sandwich performs a little better, but I'm not sure if I really got all the air out, so don't take my word for it just yet.
    My approach to testing this came from reading about two other, similar tests that showed next to no effect for the sandwich vs. just one radiator. It seemed like the air got so warm after the first radiator that it just didn't do anything for the second one anymore.
    That's why my focus was on verifying or disproving the hypothesis: Radiator sandwich is no better than single radiator. I must admit that I just didn't test enough scenarios, but as I said: I'll do more runs when I find the time.
    Oh, and someone send Skinee a radiator! Two sets of data are always better than one (especially when they completely contradict each other?).
  24. #24
    Aug 2005
    Clarification (sorry): To what do you attribute the non-effect of the fan speeds on the "sandwitch" setup?
    As for the barbs, I race sail boats and we spend about two weeks getting the boat ready for spring racing. There's a guy in the fleet that spends all winter working on his boat. Some of the things he does are rather trivial and would only result in a few seconds savings over a 3-4 hour race ...but he does hundreds of them things! and his boat is actually a couple of minutes faster. (So cunning and trickery have to be our tools!)
    Well, I see barbs as being one thing among many too. So, 1% here, 2% there, and pretty soon you're talking about 10°C!
  25. #25
    Aug 2005
    Quote Originally Posted by Naja002 View Post
    Since the deltaT across the water inlet and outlet will likely be less than 0.5°C, I doubt that there would be much difference at all. My only thought though is that the greatest cooling happens when the deltaT between the water and the air is the greatest. ?????
