Not really a work log, but some pics of the finished product.
Stuff used: MM Radical Sandwhich, PA120.3, 6x San Ace 9S1212L401 Silent Series at 7v, DD-CPX, Alphacool Coolplex Pro 25, 3/8 Tygon, Swiftech Coils.
Powered from the xbox, pulling about 2amps (mostly from pump) using the soldered motherboard connection from my previous 360 watercooling mod.
I used a koolance temp sensor that i had lying around (fail, i know) then found out afterwards that it wont read like normal sensors on an LCD panel you need the stupid koolance readers, and couldn't be bothered draining it and removing all that from the loop but i figure it will be well within cool enough to not need a temp sensor and i was right, it runs very very cool.
