This is for those that were interested in pictures of the upcoming towers we will be releasing soon. Using the same high grade 2mm thick ALU.
Here's some actual shots of the Pinnacle 24
24" Tall, 24" Deep, and 9 inches wide. Essentially half of an Extended Ascension. Options for various radiators on front and top. "Hyper Modular" for panel rotation. Also easily set up for reverse ATX. Just take the security flange put it on the opposite side of the motherboard tray - rotate it 180 degrees on the backwall and swap panels (lef/right).
