Results 1 to 22 of 22
Thread: Anyone with an HD 4830?
    Aug 2005
    Just curious, have anyone tried flashing their HD 4830 with an HD 4850 BIOS?
    Maybe it's a better chance with the HIS cards?
    .:: Gaming PC Specs ::.
    Case: Antec Nine Hundred
    CPU: Intel Core i7-2600K @ 4.6 GHz, 1.44v (cooled by Xigmatek GAIA) [IntelBurnTest{Linpack} stable]
    GPU/Monitor: VisionTek HD 6950 @ 6970, 950 MHz/1375 MHz 1.30v + Sony BRAVIA 32EX400 1080p
    Motherboard: GIGABYTE Z68XP-UD4 F5
    Memory: 16 GB (4x 4 GB) Corsair Vengeance LP DDR3 1600
    Hard Drive: 2x Seagate 500 GB 7200.11 RAID 0 & RAID 1 (Matrix RAID) + 1x WD Caviar Black 640 GB
    Sound: Creative SB X-Fi Fatal1ty Profess1onal, Logitech X-530
    PSU: Corsair AX-1200 (1500W PSU!)
    O/S: Microsoft® Windows 7 Ultimate SP1 X64
    Aug 2005
    Is no one interested in this?
    Feb 2006
    Quote Originally Posted by AgentGOD View Post
    Seems there is no chance! I heard SP enabler is separate software that will modify BIOS ... but still not sure
    www.HotOverclock.com Founder & Editor in Chief
    Upgrading to X58 ...
    Q6600 G0 @ 3.8GHz FSB 423MHz w/Swiftech H2O 120 Compact Dual 120mm fan Last OC Details Here
    abit IX38 QuadGT Rev1.0 (X38 Rev.01)
    4x1GB Patriot +SL PC2-6400 Based on Aeneon AET760UD00-25D Chips! @ 1:1 1000MHz 5-4-4-8 2.0v
    Sapphire Radeon HD 4850 A2 Normal Edition @ Core 820MHz Mem 2100MHz
    Display 19" LG FLATRON L1960TR LCD Contrast 3000:1 Response Time 2ms Lightning Fast!! w/f-Engine Chip and DFC Technology
    HDD 250GB Seagate Barracuda 7200.10 ST3250820AS
    HDD 120GB Maxtor Max.10 6L120M0
    PSU Zalman ZM1000-HP 1000 Watt Six 12v Rail and Dual Seperate Board
    A4Tech X7 Gaming Mouse X-750BF Dual Laser Engin w/2500DPI
    More about my Memory : it can do 950MHz 4-4-4-8 2.0v Stable and 1100MHz 5-7-7-12 2.2v Stable and 1200MHz 6-8-8-21 2.3v not Stable!
    Dec 2005
    Victoria, Australia
    hey AG ...... that's one mighty rig u got there for playin BF2
    Asus A8N-E, x2 3800+ 2.7Ghz@1.488v RmClk, TT Big Typhoon lapped, Zalman NB-47J, XFX 9500gt, Corsair 2Gb, Sony DVD, Samsung 1TB, Coolermaster Cavalier, Enermax 620w, Benq G2400WD, Logitech X-230, WIN7 64.
    There is a cure.... it's called Prevention. .. And remember - the story being told is not always the one that best reflects reality….
    Jun 2007
    I hope it is possible. I mean just look at them
    http://www.sapphiretech.com/us/produ...gpid=249&grp=3
    http://www.sapphiretech.com/us/produ...gpid=261&grp=3
    Almost the same. :P
    Mar 2005
    Trinidad and Tobago
    that would be good if possible
    i might buy 1 jus to try it
    Rig 1 Asus ROG Strix B550-F WiFi, R7 5800x, 64GB Vengeance LPX 4*16GB, Zotac GTX 1070Ti, X-Fi Titanium, Enermax Revolution D.F. 850w, SSDs 768GB, HDD 3TB, CM 912HAF, NH D-15 Black.cr
    Rig 2 Asus Maximus VI Hero, i7 4770K@4000, 32GB Ballistix VLP 4*8GB, Gigabyte GTX 970, eVGA G3 850, SSD 512GB, HDD 2TB, TT Element-T, NH D-14.
    Aug 2005
    Quote Originally Posted by xman01 View Post
    Do it For the community!
    Aug 2005
    Anyone else? :P
    Nov 2004
    im interestetedededded
    Aug 2006
    The Netherlands, Friesland
    Even without modding the bios these cards are not bad in crossfire, and dirt cheap.
    >i5-3570K
    >Asrock Z77E-ITX Wifi
    >Asus GTX 670 Mini
    >Cooltek Coolcube Black
    >CM Silent Pro M700
    >Crucial M4 128Gb Msata
    >Cooler Master Seidon 120M
    Hell yes its a mini-ITX gaming rig!
    May 2006
    Romania
    Any news about a modded bios for this card?
    Jul 2008
    US
    I started working on the bios that came on my Asus EAH4830 with RBE this evening. The stock voltage is 1.082v. I found that I get higher stable clocks an about 10w extra power draw at the wall (measured as 302w @ 1.082v/700Mhz vs 312w @ 1.15av/700Mhz) under furmark if I increase the voltage to the maximum of 1.158v. That little bump brings my 3dmark06 passable core clock up from 700Mhz to 740Mhz. I see 86C and artifacts every few seconds under furmark at that clock and voltage, but I'm still on the stock cooler. I also have to turn my ram clock down to 1040 from 1060 to get through 3dmark06 at 740 without lots of artifacts and an eventual crash. I'll probably slap one of my Accelero S1's and some swiftech ramsinks on it tomorrow if I have a chance. Hopefully that will get me a bit further. Anyone have any ideas on getting past the max voltage that RBE lists, or am I going to need a hardmod?
    --Matt
    My Rig :
    Core i5 4570S - ASUS Z87I-DELUXE - 16GB Mushkin Blackline DDR3-2400 - 256GB Plextor M5 Pro Xtreme
    Jul 2008
    US
    I just noticed that I can type numbers into the fields where the voltage drop-downs are. I'll give that a try tomorrow.
    --Matt
    My Rig :
    Jul 2008
    US
    I just get a blank screen when I push past 1.158v in the bios. :-/ Back to the drawing board on that one...
    Here's what I'm getting so far at 750/1080 with the Accelero S1 installed:
    Vantage - 7109:
    http://www.hwbot.org/compare.do?resultId=822172
    3dmark06 - 13861:
    http://www.hwbot.org/compare.do?resultId=822173
    3dmark05 - 25081:
    http://www.hwbot.org/compare.do?resultId=822175
    --Matt
    My Rig :
    Jul 2008
    US
    Anyone else have better luck with theirs? I dropped my idle clock to 200mhz and the idle voltage to .892v. Those two changes cut 10W off of my PC's power consumption at idle (as measured by a kill-a-watt).
    --Matt
    My Rig :
    Jul 2008
    US
    I hardmodded my card for 1.4v this afternoon. I'm getting better scores now. Here's what I see at 810/1080:
    Vantage - 7533:
    http://www.hwbot.org/compare.do?resultId=822505
    3dmark06 - 14053:
    http://www.hwbot.org/compare.do?resultId=822500
    3dmark05 - 25483:
    http://www.hwbot.org/compare.do?resultId=822497
    --Matt
    My Rig :
    Nov 2007
    Pencil Mod MSI 4830 OC @ 1.45 VGPU
  18. #18
    Jul 2008
    US
    Wow! That's quite a clock! What cooling was used?
    --Matt
    My Rig :
  19. #19
    Nov 2007
    Accelero S1 Rev 2 + 2 120mm Fans
  20. #20
    Jul 2008
    US
    Yikes. That card is quite a clocker indeed! Is the card still running at that clock/voltage? What were you able to run without a vmod?
    --Matt
    My Rig :
  21. #21
    May 2006
    Romania
    any new 4830 bios mods?
  22. #22
    Jan 2008
    Hi,
    I just got MSI HD4830 OC 512MB card, did a pencil mod getting 800/2280. Now I want to unlock the rest of SP. I was thinkink about flashing it with MSI HD4850 BIOS. They look the same.
    http://www.msi.com/index.php?func=pr...0&prod_no=1659
    http://www.msi.com/index.php?func=pr...0&prod_no=1665
    Only the cooler has a different colour, but I didnt manage to find any other difference. I dont wanna destroy my card though so I am asking first. Has anybody tried this yet? Is it even theoretically possible? Which BIOS shuld I use from these?
    http://www.techpowerup.com/vgabios/i...-E&memSize=512 (I think the newest one).
    Any help appreciated.
