Results 1 to 25 of 220
Thread: Project: Aluchill[Scratch build]
Threaded View
    Oct 2006
    Sweden
    Sponsored by:
    Alphacool
    Sifvert
    And a special thanks to Tom @ ChilledPC
    Links:
    Update #1 (Frame constructing and diy)
    Update #2 (Frame finished)
    Update #3 (Panel cutting)
    Update #4 (Panel cutting & mockup)
    Update #5 (Panel cutting & mounting)
    Update #6 (Panel mouting, PSU opening, tray slide)
    Update #7 (Back panel finished & WC stuff)
    Update #8 (Shape complete, outer panel cut and bent)
    Update #9 (5,25 Holder and diy)
    Update #10 (Front Construcion)
    Update #11 (Front Completed)
    Update #12 (Rad mount and internal cover)
    Update #13 (Fan grills and LCD-bezel)
    Update #14 (Details before powder coat)
    Update #15 (HDD-suspension and details)
    Update #16 (Powder Coat & set back)
    Update #17 (Finally! Assembly line)
    Update #18 (Assembly continues)
    Update #19 (EYE CANDY!)
    About the project:
    So guys, this is my first scratch build ever. I've always felt quite unpleased by modding a pre-made case so this should be very exciting.
    As you have probably already realised by its name, this mod is going to be built using aluminum materials only. It's a nice material to work with, and its fairly light weight.
    It is going to be packed with high-end water cooling and some nice components.
    Hardware:
    XFX 780i SLI motherboard
    Intel QX9650 CPU
    4x 1gb OCZ FlexXLC 9200 memory
    2x 8800Ultra in SLI graphics cards
    Corsair HX1000 power supply
    Creative X-fi Fatal1ty Titanium sound card
    WD 36gb 10k raptor
    Samsing 400gb harddrive
    Watercooling:
    EK Supreme CPU
    2x EK-FC8800 GTX/Ultra - Acetal
    EK-NB 780i - Acetal
    EK 780i Mosfet block
    Thermochill PA120.2
    Thermochill PA120.3
    2x DDC3.2 with XSPC laing top
    Feser compression fittings
