Results 1 to 7 of 7
Thread: MSI DKA790GX a day of testing
    Dec 2002
    Well after looking at all the threads of the different mobos out I did finally decide to purchase this mobo
    Here are my findings
    Pros:
    excellent packaging (like most higher end mobos)
    overclock cpufsb up to 280mhz so far
    overclock HT link and nb frequency up to 2500mhz
    overclock cpu to 3.1ghz@1.29v (stock) 100mhz increase over sb600 @ same V (but I got a good cpu)
    sb750 3.4ghz@1.45v / sb600 3.4ghz@1.55+v
    cons so far: (may be user error until someone steps in to help)
    cpu voltage only goes to 1.45v
    have to lower cpu speed with higher nb/ht speeds(270+) again due to low cpu voltage
    Havent seen any difference using ACC but Im still testing its been set at +2 for all overclocking so far.
    heres some validations
    http://valid.x86-secret.com/show_oc.php?id=436625
    http://valid.x86-secret.com/show_oc.php?id=436885
    Ill be posting more validations and begin testing in 3dm06, superpi (Useless @3.2ghz)
    so if you see something that can be modified to give me better results please add in, also how to get higher volts in bios settings.
    Thanks in advanced
    more pics to come
    AMD 1090T@4.0ghz
    Enzotech sapphire/Mo-Ra extreme rad
    Asus Crosshair IV Formula
    ht 2400mhz / nb 2400mhz
    12gb Gskill 1300mhz
    HIS HD5970
    Enermax Evo Galaxy 1250
    case: XCLIO A380PLUS-BK
    4.61ghz water
    4.5ghz superpi 1M 15.585
    http://i271.photobucket.com/albums/j...rpi4500mhz.jpg
    25,396 06 Phenom 965@ 4.4ghz HIS 5970@960/1260
    21,893 Vantage, Phenom 965 4.2ghz HIS 5970 @960/1260
    Phenom 2 125w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=117414
    Phenom 2 140w 965 test results
    http://futuremark.yougamers.com/foru...d.php?t=109214
    Phenom 2 AM2+ 940 cold air results
    http://futuremark.yougamers.com/foru...ad.php?t=97430
    If I dont get every single drop out of my cpu I feel like someone is stealing from me
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    You can change a setting in AOD's configuration file to allow higher voltages than 1.45V. However, you should be careful as 1.45V is not considered "low cpu voltage" for an X4. It's rather high already.
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
    Jul 2007
    Hmm i may be on 2 something if your willing to try....
    Ok If your BIOS looks like Below then try adjusting Values@STOCK CPU CLOCKS to find how the Volts scales....
    Im cleaning my loop and will check back later, This should work , Use Stock CLOCKS so you Know youll stay cool while testing
    1st ,,
    CPU VDD and CPUNB VDD should set or Raise VID values when VDD is raised...
    The Higher the CPU VDD the Higher you Can raise your Volts while ADDING CPU Voltage (V)...
    If you run the CPU @ 1.4volts the VDD should be raised to say 1.35 - 1.4VID then you add CPU VOLTAGE or needed Vcore...
    2nd,,
    CORETEMP will show VID value OR AOD..
    I use CORE TEMP to see VID and HWmonitor to see Vcore value...
    If i know im gonna use more than 1.4volts for CPU i set CPU VDD to where my VID reads 1.4vid in CORETEMP @ STOCK CLOCKS ... Then i ADD VCORE(in your Case CPU VOLTAGE(V) ).
    What ever VID shows in CORETEMP as you raise value of CPU VDD the NBVDD will raise at the same rate...
    So if you Raise The NBVDD it will raise the VID values just like CPUVDD does...
    Im on water but i Know the Max VID is to be 1.55vid ..I use this for Both...
    Remeber,,
    Set the CPU @ stock CPU CLOCKS set VDD values for BOTH CPU/NB to Read 1.35vid in coretemp..(The VDD value is same for both,, if you Need more VID Raise the CPUVDD ONLY use CPU VOLTAGE(V) if Xtra Vcore is needed..
    Note:
    The NB VDD does not need to go above 1.35vid unless you are pushing The NB over 2400mhz...
    IF you Set NBVDD higher than CPUVDD it will self adjust to NBVDD(VID values)NBVID will not adjust higher than CPUVID it will default to what you set for NBVDD(VID value) value.
    If your worried about the Voltage going through the roof it wont!
    Keep Vcore set @1.31v while you raise the VDD youll see what i mean.. As you Raise the VDD it should Raise your Vcore too and well above if needed...This should enable you too increase Volts above 1.45volts While using CPU Voltage(V) to dial in cores once the VID is where you want it. I believe im on the right track for ya..
    790GX/3 and this Mobo adjust the same way Seeing they Did not implement VID seperate in Bioses this works for now.
    I usually raise the VID to be with in .500v or my CPU vcore..
    Example ,,
    1.45v for CPU i would Set Default value for Vcore then Raise the VDD to get 1.45 vid = 1.45vcore...Then you add more CPU Voltage(V) to go above 1.45v.
    I hope this does it..Watch your Temps,,They should not go up much or any @Stock Clocks.
    Small steps and If all goes good then start Clocking that thing.
    "AMD...Like the perfect Storm,...Everything needs to be just right"
    X555x4SuperCore@4450mhz@1.64v..........
    RYZEN 7 1800x/ ASUS ROG STRIX VEGA64/ =EK NICKEL WB, Feser THC 2x360 1x480
    X470 Gigabyte Aorus7, Patriot 3400mhz 16gb dual2x8
    SSD Samsung 970pro,,860EVO
    Dec 2002
    Quote Originally Posted by Particle View Post
    Hey thanks for the reply this cpu been up to 1.59v on my K9A2 Plat and completed 3dm06@ over3.4ghz @1.55v. cooling is more than adaquate so Im not really worried.
    Is this where you change the value?<CPUVID>130000</CPUVID>, What do I change it to??
    Quote Originally Posted by gOtVoltage View Post
    1st ,,
    Ok got it
    2nd,,
    Ok I noticed this in the bios both raise at the same rate
    Remeber,,
    Note:
    ok I been up to 2500mhz and used 1.4v
    yes it seems I was doing the same thing and you are confirming it
    Example ,,
    this is where the problem is,once it goes past 1.45v it sets to auto as there are novalues above 1.45v
    Ok Ill try it this way
    AMD 1090T@4.0ghz
    12gb Gskill 1300mhz
    HIS HD5970
    4.61ghz water
    Dec 2002
    so how I do I get the higher voltages in AOD?? what do I change?? Is this where you change the value?<CPUVID>130000</CPUVID>, What do I change it to??
    AMD 1090T@4.0ghz
    12gb Gskill 1300mhz
    HIS HD5970
    4.61ghz water
    Dec 2002
    Im stuck here till I can get higher voltages
    heres validation at 270fsb 3.25ghz
    http://valid.x86-secret.com/show_oc.php?id=437028
    AMD 1090T@4.0ghz
    12gb Gskill 1300mhz
    HIS HD5970
    4.61ghz water
    Dec 2002
    all stock voltages
    AMD 1090T@4.0ghz
    12gb Gskill 1300mhz
    HIS HD5970
    4.61ghz water
