XtremeSystems Forums
Go Back   XtremeSystems Forums > Hardware > Intel
Reply
Thread Tools Rating: Thread Rating: 57 votes, 4.56 average. Display Modes
Old 10-18-2008, 06:37 PM   #1
marmott
** Official ** Gigabyte UD3 P45 Series -- EP45-UD3 / EP45-UD3R / EP45-UD3P
This thread is all about the Gigabyte UD3 motherboard with the Intel P45 northbridge.
1- Models
GA-EP45-UD3
view specification
GA-EP45-UD3R
view specification
GA-EP45-UD3P
view specification
2- Differences between models
3- What is UD3 ?
UD3 stands for Ultra Durable 3 and is the association of 4 different items :
2 oz copper PCB :
Gigabyte has increase the amount of copper in the layers of the PCB (1 oz > 2 oz), the result is a better spreading of the heat around the critical areas of the mother board (50°C cooler mesured by Gigabyte).
more informations here
Japanese solid capacitors :
All the Gigabyte UD3 motherboards are equipped with Japanese solid capacitors. These capacitors have an average lifespan of 50,000 hours.
Lower RDS on mosfet :
Gigabyte uses on the UD3 motherboards Lower RDS mosfets, they provide a lower power consumption and a faster switching process.
Ferrite Core Choke :
Gigabyte choose to use Ferrite choke against Iron choke because of the lower EMI interference produced and the better resistance compare ti Iron choke.
more information here
__________________
marmott is offline   Reply With Quote
Old 10-18-2008, 06:38 PM   #2
marmott
4- Tests, articles
GA-EP45-UD3
- CPU3D.com
GA-EP45-UD3R
- Bit-Tech
GA-EP45-UD3P
- Techgage
- Motherboards.org
- TweakTown
- 59Hardware (French)
- GinjFo (French)
__________________
Old 10-18-2008, 06:40 PM   #3
marmott
5- Downloads
GA-EP45-UD3
Bios: on the GA website (latest bios = F4)
Utility: Easy Tune 6 & Dynamic Energy Saver Advanced on the GA website
Driver: for Audio, Chipset, Lan on the GA website
GA-EP45-UD3R
Utility:
GA-EP45-UD3P
Bios:
on the GA website (latest bios = F5)
6- Useful informations
GA-EP45-UD3
Manual: on the GA website
CPU support list: on the GA website
Memory support list: on the GA website
Prices in comparator (smallest price):
North America, UK (92,47£), Germany (116,50€), France (107,50€)
GA-EP45-UD3R
Prices in comparator (smallest price): North America, UK (100,17£), Germany (126,30€), France (122,49€)
GA-EP45-UD3P
Prices in comparator (smallest price): North America, UK (112,527£), Germany (134,90€), France (137,50€)
__________________
Old 10-18-2008, 08:36 PM   #4
zodden
What do you guys make of this with LLC enabled on the UD3P. No upward spikes and long periods of stable volts. Look at the downward spikes, including one below 0.8v: How didn't the machine crash? It would seem impossible to me that it could run and finish the bench yet it did.
__________________
E8400 @ 4.2 Ghz (525x8)
Gigabyte EP45-UD3P
Corsair Dominator 4GB (2 x 2GB) PC2 8500 2.1V
PowerColor 4870x2
150GB Western Digital Raptor
500GB Western Digital 5000AAKS
Westinghouse LVM-37w3 1080p Monitor
Vista64
Cooling: CPU-OCZ Vendetta2+Scythe S-FLEX SFF21F 120mm, Silverstone TJ09 case with 4 120mm yate loons.
zodden is offline   Reply With Quote
Old 10-18-2008, 09:46 PM   #5
v3rax
v3rax's Avatar
Thumbs up
I am happy that you started this thread because I just got this board and an E8400.
My first experiences with OC have resulted in a 3.8 OC thus far.
I know it is capable of going higher, but I am kind of new to overclocking and especially this BIOS.
If anyone out there has began using this board and have been overclocking, I would sure appreciate some pointers on BIOS settings in order to go higher than 3.8.
The area of the BIOS that is used for OC has some things I am not familiar with and I am sure there are combos/settings that will allow me to go higher.
I can't wait to see some more info start showing up on this thread, this is an AWESOME board.
__________________
Gigabyte MA790X-UD4
Phenom II 940 @ 3.5ghz
4gb Mushkin 1066
MSI HD 4870 1mb
1 WD Velociraptor
1 Seagate 7200.10 320gb
1 Seagate 7200.10 250gb
Asus DVD Burner
8 120mm Case Fans
v3rax is offline   Reply With Quote
Old 10-19-2008, 12:00 AM   #6
GAR
Xtreme Guru
Send a message via AIM to GAR
I had trouble getting prime blend to pass at 475, but 450 seems solid.
GAR is offline   Reply With Quote
Old 10-19-2008, 02:48 AM   #7
dannyuk32
It's interesting Gigabyte chose to produce these boards.
Marketing or are the original p45's flawed? I was going to buy the GA-EP45-DS3 and now a board with exactly the same features almost gets released but has UD on the end of it. (GA-EP45-UD3) - The layouts are different.
Confused .... regarding the base model anyway.
dannyuk32 is offline   Reply With Quote
Old 10-19-2008, 08:26 AM   #8
RPGWiZaRD
Xtreme Mentor
RPGWiZaRD's Avatar
Send a message via MSN to RPGWiZaRD
The only reason is the Ultra Durable 3 with 2oz copper layer in the PCB, you really want to choose these over the normal DS3x boards.
__________________
Intel® Core i7-860 @ 4.1 GHz | Gigabyte GA-P55-UD5 | G.Skill Ripjaws 2x2GB @ DDR3-2340 9-10-9-24 | EVGA GTX 280 1GB @ 729/1512/2592 MHz | Corsair HX 750W | ViewSonic VX2268wm 120Hz LCD | CoolerMaster Hyper 212 Plus | Creative SoundBlaster Audigy w/ kX Audio drivers | Logitech X-530 5.1 | Sennheiser HD 212 Pro | Logitech MX-518 | Everglide Titan MonsterMat | Windows XP Professional SP3 | Windows 7 x64 Professional | HDD: 4x300GB, 500GB, 640GB, 750GB & 1.5TB
RPGWiZaRD is online now   Reply With Quote
Old 10-19-2008, 09:34 AM   #9
HousERaT
HousERaT's Avatar
So who will be first to post some stable settings for dual and quadcore cpus?
__________________
The little air system that could.
HousERaT is offline   Reply With Quote
Old 10-19-2008, 09:55 AM   #10
v3rax
v3rax's Avatar
Well, I am running 3.8 stable ATM, but haven't put together documentation. I will try and get that up today, but I am still trying to figure out what some of these new BIOS settings are.
E8400 @ 3.8 (423x9)
__________________
Gigabyte MA790X-UD4
4gb Mushkin 1066
MSI HD 4870 1mb
1 WD Velociraptor
Asus DVD Burner
8 120mm Case Fans
Old 10-19-2008, 09:57 AM   #11
systemviper
Phazers on Stun
systemviper's Avatar
Send a message via Yahoo to systemviper
The only thing ran was 3D06 , but the board hasn't crashed yet.
I just popped in my QX6850 an a few tweaks and i was over 500fsb, i have to say that was easy, i can't wait to put my
Q9650 on it, and maybe even get a E8600 to play with. I also have a great Q6600 i might try to pus on this board,
I just starting o learn this bios,to see what really can be done.
CPUz
__________________
HEAT
systemviper is offline   Reply With Quote
Old 10-19-2008, 10:48 AM   #12
RVWinkle
I'm trying to decide between the UD3P and UD3R. I'm not a fan of multiple video cards so I'm looking at the other features. Can anyone explain what 'Ultra TPM' is?
__________________
Opteron 165 3ghz (still tweaking)
DFI NF4 Ultra-D
2x512mb Kingston HyperX (oldschool BH-5)
8800GT
Antec P180 modded
Watercooled
RVWinkle is offline   Reply With Quote
Old 10-19-2008, 10:53 AM   #13
zodden
Are you guys running the latest beta bios?
Bios F5A
http://www.savefile.com/files/1844049
(it was posted in the pre-testing thread a few days ago)
Something you guys should know. If you have bios profiles saved they will all be deleted when you flash to the new bios. The good news is that there is an option in the new bios (didn't notice it in the original) to save your profiles to a floppy or USB stick. So I guess write down your important settings before you flash to the new beta
__________________
Gigabyte EP45-UD3P
PowerColor 4870x2
Vista64
Old 10-19-2008, 11:20 AM   #14
systemviper
Phazers on Stun
Bios F5A
thanks.... need it
__________________
HEAT
Old 10-19-2008, 11:23 AM   #15
HousERaT
HousERaT's Avatar
any benefits in flashing to the beta bios thus far?
__________________
Old 10-19-2008, 11:45 AM   #16
dannyuk32
Thanks for reply RPG' .. thing is the base model has such minimal heatsink it seems pointless anyway?
Do any of you guys know if these Boards work with G.Skill memory, also do they have that CrazyCool thing on the back?
Thanks, Danny.
Old 10-19-2008, 02:35 PM   #17
Peakr
Peakr's Avatar
Gigabyte Mainboard Ultra TPM (Trusted Platform Module) B8.0516.1 Windows 2000/XP(x32/x64)/Vista(x32/x64).
With a Trusted Platform Module (TPM) chip built-in, the GIGABYTE Ultra Secure motherboards provide TPM hardware-based encryption and decryption with digital signature keys to ensure a maximum level of data protection with 2048 bit encryption.
GIGABTE's Ultra TPM provides an added layer of security by allowing users to store their digital signature key on a USB thumb drive, so that when they step away from their system, they can take the key with them, locking up their data and preventing unauthorized access while they are away. If keys become lost or misplaced, GIGABTE's Ultra TPM gives users the option to pre-save a backup of the key on their BIOS, helping them to quickly access their data and provide effortless data protection.
__________________
i7 920
DFI DK X58-T3eH6
6Gb OCZ Reaper 1866
BFG GTX280
X25-M 160GB G2
2XWD2002FYPS
LG-GGW H20L
X-Fi Xtreme Music
GATEWAY FHD-2400
Peakr is offline   Reply With Quote
Old 10-19-2008, 03:25 PM   #18
Revv23
I am Xtreme
Revv23's Avatar
Send a message via AIM to Revv23
Sweet; nice thread, I'm really interested in this board.
Revv23 is offline   Reply With Quote
Old 10-19-2008, 04:38 PM   #19
Flinch
Cheese Head
Flinch's Avatar
I posted this in another Gigabyte thread as well.
With my UD3P and ReaperX 8000 you can not boot into Windows at it's rated speed of 1000. This has also been confirmed by another guy at OCZ's forums with the same board and ram, just a heads up.
I've also used the stock bios and f5a which didn't resolve the issue. Patriot Vipers solved the problem.
Flinch is offline   Reply With Quote
Old 10-19-2008, 05:04 PM   #20
Trouffman
Trouffman's Avatar
Location: Somewhere on earth between Paris and Montreal
Send a message via MSN to Trouffman Send a message via Skype™ to Trouffman
nice thread
__________________
Overclocking-TV Staff
Originally Posted by hipro5 View Post
Ha, ha, ha.....NO WAY.....When I show someone preparing to take a shot, I hided the cigarette....
Trouffman is offline   Reply With Quote
Old 10-19-2008, 05:09 PM   #21
marmott
thanks
I am looking for a North American price comparator to put prices in the 3rd post, anyone have a good link ?
__________________
Old 10-19-2008, 06:18 PM   #22
GAR
Xtreme Guru
anyone have a bios templete??
Old 10-19-2008, 06:25 PM   #23
dinos22
...you two characters
dinos22's Avatar
clearly that is not possible >> 4GHz at 0.8v hehehe
must be the application going a bit crazy heheheh
__________________
Team.AU
Got tube?
Originally Posted by Gautam View Post
In the old days, LN2 benching was "cheating". Then LOD was "cheating". And so on and so forth...
dinos22 is offline   Reply With Quote
Old 10-19-2008, 06:35 PM   #24
Flinch
Cheese Head
Flinch's Avatar
I'm noticing some voltage oddities with my Q9650 and UD3P.
I set the voltage in the bios at 1.33 and at the desktop with cpu-z it shows 1.23-1.24, somethings just not right with that picture.
I was googling for some answers and came across a guy at [H] that's seeing the same huge drop from the bios settings to what cpu-z is showing
Old 10-19-2008, 06:49 PM   #25
dinos22
dinos22's Avatar
that sound like vdroop and vdrop that you would commonly see on boards
what about LLC enabled?
__________________
Team.AU
Got tube?
Reply
Tags
cpu, gigabyte, overclocking, p45, ud3
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
