HTPC coolermaster 690 sempron 140, Gigabyte UD3H, ddr3 1600mhz, 650 ps, 160gb hard drive currently running windows vista 64 bit (30 days)
AMD Green & black dragon GODZILLA get it it's now classic XD
foxconn destroyer revived Thermaltake Xaser IV case (bought)
285gtx 2gbs need to save cash now
Errr? You have already posted a guide for the mod haven't you? It looks perfectly valid if that's what you wanted to know.
Yes, that's it. I don't have a card to test it right now... so I'm not sure if it is working fine, and I'm not sure about the measure points and wich one is a good ground point to solder.
__________________ Giga 790FX-UD5 | PhII 955 @ 3.85Ghz CnQ NB 2.7Ghz| HD5850 @950Mhz | 2x 2GB G. Skill 1600Mhz C6-8-7 1.7V | LG 32' S-IPS | CorSair 650W |
I can say those measuring points are valid.
And you don't even have to solder the ground, just clamp the wire onto the grounded ring around any of the screw holes.
__________________
You were not supposed to see this.
I will make i tonight and i wil search for the vmem also i will post later
__________________
The man with the littel Barebone!
And proud Crew of!!!
Octeamdenmark.com
Shuttle SX38P2Pro Barebone E8600cpu and HD4870X2 gfx and 2gig Crusial Ballistix PC8500 Cl5 and 2x150gig Raptor in raid 0 and 1x750 gig seagate
Msi 790FX-GD70 Mobo Amd 955-965 PHII cpus and 2gig Crucial value PC10600@800mhz 7-5-5-15 1T
And 4x500GB Seagate 7200.12 in raid0
4xHD5770 in CFQ.
Here is a Full vmod guide for the new Ati HD4670 gfx card
I have a His HD4670 512mb turbo 3 at 780/2000mhz and with vmod and stock air i can easely run at these speeds. 890/1251mhz and it gave me a 3. place in Hwbot.org in 3Dmark01
More pictures to come
P.S. the 3. place is done with my trusty old Shuttle barebone nice!!!
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
Update now the 2. place in 3Dmark 2003 is taken...
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
Here is some pics of the setup in the Shuttle barebone.
Here is pics of the vmod it self.
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
:o
Are those VRs glued on the cards or do they actually just hang in there by the legs?
That last pic would imply there is no glue... I personally wouldn't dare tuning them VRs if they were not fastened somehow.
__________________
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
no way maby 1000mhz the fan is only doing about 800-1000rmp at max
__________________
Octeamdenmark.com
4xHD5770 in CFQ.
