E5200 ON AIR.
MSI P45-P BIOS 1.42B
1.376V 4G OR (12*)
GO(400*10)
TEMP GO TO 70'+....
ON AIR MAX BOOT @ 4.6G
SHANGHAI VERY HOT..SO...
MAX AIR 1M
THE VID 1.125v....
OK NOW TRY LN2
5.5G... 441FSB 1.9*V
MSI P45 VMOD
E5200 ON AIR.
1.376V 4G OR (12*)
GO(400*10)
TEMP GO TO 70'+....
MAX AIR 1M
THE VID 1.125v....
OK NOW TRY LN2
MSI P45 VMOD
Not bad. I tried myself, but it didn't seem to work at all and I was tired, so I didn't bother. Nice clock though.
I KNOW MASSMAN DISLIKES YOU.
Competition ranking: Better than the danes in everything I've ever entered.Originally Posted by saaya
congrats!
mmhh thats a nice multi on that chip...
how much does the missing cache impact perf?
and why 70C on air?
what air? stock heatsink?![]()
and you get 70C load?
damn...
passive cooled?![]()
very very nice chip... most of them does 4GHZ on 1.5V or even more...
2500K @ 5ghz 1.344V + TRUE 120 Black
ASUS P8P67 Pro Rev 3.1
Micron 4GB x 2 1333mhz CL8
Gigabyte GTX 470 SLI + Zalman VF3000
Crucial M4 128gb SSD +
2x Samsung 103SJ, 1x Hitachi 2TB 7K3000
Antec High Current Gamer 900W
Lancool PC-K62WB
These look like fun little OCing chips. What is their max FSB?
Nice job on budget chip
Congrats for new WR![]()
Intel E8600 E0@420x10(H20)/Abit IP35 Pro/Team Xtreem DDR 2 1066mhz D9GKX@420mhz,5-4-4-11-2T /Crucial Ballistx Tracer DDR 2 800mhz 16FD3@420mhz 5-4-4-11-2T/Gigabyte GTX260 SOC@720/1512/1300/LG SATA DVD-RW/WD 320GB +Segate 1TB/Corsair HX520W/Enlight Lian Li OEM PC7A casew/W65A Side panel
Liquid cool: Dtek Fuzion V2,Swiftech MCR220,Swiftech Radbox,Swiftech Micro res,Nirox P2800 modded pump,Generic 1/2" ID tubing,3xYate Loon mid speed
Note:E8500 is 9.5x but cpuz got issue and X2 4600+ is oc with stock cooler,max validation and never push
9.204's PI
ya for that multi gotta get 1 !
[SIGPIC][/SIGPIC]
PENT E8400 batch #814A014 ...4.3 at 1.34v~4.7 at 1.45v
FOXCONN MARS
COOLIT Eliminator 7*c idle~27~38*c load $95bucks !
BUFFALO FireStix's ddr2-800 do 1200 eazy at 2.1v
OCZ 2x2 kit pc2 8500 - 1066 @1069 atm
Quattro 1000W
Radeon 2-4850's in crossfire
OCZ Vertex SSD thanks Tony!
ALL PIPED INTO HOUSE AIRCOND ;}
*QUANTUM FORCE* saaya & sham rocks !
*REAL TEMP*
At least you've got some Xtreme software now for working in Xtreme situations! "Unclewebb" rocks !
*MEMSET* Felix rocks !
*SUPER TEC MAN* UncleJimbo rocks !
OVERCLOCKERS MAG..http://www.xtremesystems.org/forums/...d.php?t=197660
Very nice chip... And your TJ.Max should be 100°C not 105°C so 65°C under load is it![]()
nice overclock!
wooooow nice
wicked monitor.
vn clocks! grats!
Why single channel? It can make quite big difference when using this chip. But CPU is veeery nice![]()
http://www.bartxstore.com/- Standard and Extreme Cooling Components
holy fcuk.... 5.5ghz!!! congrats man, ur a PRO!
Great chip you got man... Congrats![]()
This Multi rocks
did you try a bit more voltage?
Nice work 4GHz @ 1.376v 1.5hrs stable on air and 5.5GHz on LN2 is great for those cpu's.
Ci7 990X::Rampage III Extreme::12GB Corsair Dominator 1866C7GT::2 x EVGA SC Titans in SLI::Corsair AX1200::TJ07::Watercooled
Ci7 920 3849B018::Rampage II Extreme::6GB GSKILL Trident 2000C9 BBSE::EVGA GTX580::Antec Signature SG850::TJ09::Aircooled w/TRUE 120X
whoa! nice 5200! care to share the batch? thanks!![]()
Buildin
Wow, 4GHz. Might consider changing my E4300 for this one. I'm limited to ~400MHz FSB because of RAM (only 800MHz), but extra multi could help
EDIT:
Whoa, only 74 euro for this baby. I'm so gonna upgrade this one even though there is no real need lol.
It's super cheap, probably hits 4GHz easily and it's a 45nm part.
Intel Core i7 920 4 GHz | 18 GB DDR3 1600 MHz | ASUS Rampage II Gene | GIGABYTE HD7950 3GB WindForce 3X | WD Caviar Black 2TB | Creative Sound Blaster Z | Altec Lansing MX5021 | Corsair HX750 | Lian Li PC-V354
Super silent cooling powered by (((Noiseblocker)))
only $84 for e5200, and 4.6ghz+ on air nice
I'm getting my E5200 today if everything goes well. Holding fingers crossed i'll get a good OC'er.
Will report the results
Btw, how come i see these E5200 chips running at >=1,4V, i thought 45nm chips are suppose to run at lower voltages or they die rather fast. Or does that stand just for those with larger L2 cache like E7200 and E8500/E8600 ?
Any idea what's the safe voltage limit for air OC'ing this one?
